wardo
- Joined
- Feb 26, 2018
- Messages
- 21
Hello all,
I started a thread over here: https://endless-sphere.com/forums/viewtopic.php?p=1361223#p1361223, on a e-assist bakfiet cargo bike I am scratch building. I think I have settled on a Cyclone mid drive from Luna Cycles. There are clearance issues with the Bafang BBSxx motors as there is only 12mm between the motor and bottom bracket, which although I think I could get to work, is challenging with a wood frame. The Cyclone gives me more flexibility in mounting and I can fabricate custom mounts if necessary. I am going to use a 100mm bottom bracket to add rigidity in the area and ease construction a bit. There will likely be a Nuvinci n380 on the rear. The load will be in the 350 pound range, but we don't need quick acceleration or big bursts of power. with that in mind, I wont require all 3000w, so plan to run a 52v battery, and possibly further detune through a Cycle Analyst. Since batteries are such a large part of the budget, and I want at least 30 miles of range, I am looking at alternatives. I've looked at various R/C options such as running two of these: https://hobbyking.com/en_us/multistar-high-capacity-6s-20000mah-multi-rotor-lipo-pack.html, or other options such as 4 of these: https://www.aliexpress.com/item/Sunway-24V-25-9V-29-4V-10Ah-18650-lithium-battery-pack-electric-bicycle-light-weight-ebike/32836998508.html?spm=2114.search0104.6.6.57d118acgIReCg&s=p. The first option only gives my 44v, the later 52v. They both would give me 20 ah for under $300. Since I am new to the "e" side of an e-bicycle, I may be totally off base. If so, feel free to (gently?) set me straight.
Thanks in advance for your input,
Ward
Ward
