I wonder if anyone know this controller, mainly if it is somehow speed limited. I run this with throttle and had to disconnect yellow wire outside the controller to make it work on throttle without pas (I broke the PAS sensor, so I diconnected it). I tried to disconnect the white wire inside the controller, but i had to solder it back together, because it was not running at all disconnected.
It runs 25-26 km/h on throttle only in that way, that the power is fading - not that you can feel that it disconnects power right after it reaches 25kmh or so. It is paired with 36v 10ah battery and motor is rear hub 8fun branded (in 26 wheel), but I could not find more specific info on it.
