Dolphin battery case connector
oldwahoo54
Does anyone happen to know the name, part number, or other id of the connector used in the Dolphin packs to connect the battery with the dock? Spent an hour at least googling to no avail.
Thanks
I mucked around with this for hours without complete success. Molex connectors were as close as it came.
Contact em3ev, they assisted me with mine.
It's called a "two pin air connector", and I bought mine originally from elifebike.com, changed name to pswpower.com and don't carry it, Maybe you can try this seller.
http://www.topbikekit.com/2-pins-air-male-connector-p-307.html
I bought mine because I wanted to use my Dolphin in a saddlebag without the cradle. The air connector is not quite the same size. The male end will not fit in the cradle, but the male end fit in my battery. The male end is a plug anyway, not a panel connector like the one in the cradle.
