John in CR wrote:itchynackers wrote:I would suggest being a bit more diplomatic in your responses.
I'd suggest not starting crap with a smart ass post that includes me as a target.
For the perimeter holes I like to use a multiple of the number of bolt holes, so none of the exhaust vent holes get too close to the bolt holes. I also place them as close to the perimeter as physically possible without cutting into the inside edge of the retaining lip.
Go ahead and write inside the cover, which is which for left and right, and think the angles through several times before actually drilling. A center punch to make a divot so the drill bit doesn't walk when starting the hole is a huge help.
itchynackers wrote:Where did I start a smart ass post please?
itchynackers wrote:I'm just tired of you belittling people for their cooling efforts. Tired of the "mine is better" type responses. Tired of the "youre all doing it wrong" type responses. Shall I list the posts? The list is long.
Hyena wrote:That's some crazy thick casting in the middle of those hubs John! I guess being made for scooters they're designed to take a heavier load. Did you ever weigh one ?
Hyena wrote:What are your thoughts on having both intake and exhaust holes on each side cover ? I tend to have intake on one side and exhaust on the other. I also have mixed feelings on the size and placement of the holes. I usually do it the same as you (albeit with fewer, bigger exhaust holes) but part of me says go with bigger holes right over the windings to have more air blowing directly over the hot spot and to allow more heat to radiate out when going slowly (or stopped)
It might be most effective to have a decent size scoop fixed to each fork leg, or to each side of the frame, that ducts air into a series of holes near the armature as they rotate by. An approach like that would make fan-forced air easier to implement, too. Heated air could then escape through any or all of the other holes, with no need to entrain the air passing across the surface of the side cover.
auraslip wrote:It might be most effective to have a decent size scoop fixed to each fork leg, or to each side of the frame, that ducts air into a series of holes near the armature as they rotate by. An approach like that would make fan-forced air easier to implement, too. Heated air could then escape through any or all of the other holes, with no need to entrain the air passing across the surface of the side cover.
that's a pretty good idea
voicecoils wrote:Here's how ventilated drum brakes in old race motorcycles did it
Users browsing this forum: AussieJester, fluid2150, muskoka, Sam-Q and 8 guests
