Air Cooling my x5
Re: Air Cooling my x5
Postby Chalo » Wed May 02, 2012 1:10 pm
As a former aerospace guy, I have strong doubts about the practical value of tangentially angling the holes through the side covers in the absence of external scoops or vanes. I'm guessing the strongest effect in terms of through flow will be from center to edge due to centrifugal force, though the hub doesn't really turn all that fast.
It might be most effective to have a decent size scoop fixed to each fork leg, or to each side of the frame, that ducts air into a series of holes near the armature as they rotate by. An approach like that would make fan-forced air easier to implement, too. Heated air could then escape through any or all of the other holes, with no need to entrain the air passing across the surface of the side cover.
Chalo
Chalo
Postby John in CR » Wed May 02, 2012 4:35 pm
Chalo,
The air inside is already spinning, the holes at the exhaust aren't the blades like for a squirrel cage fan. They're angled in that manner to reduce the negative influence of the air outside as each hole starts at zero speed relative to the outside world when the hole is lined up with the tire contact patch, and accelerates in an arc to it's fatest speed 180º from there and decelerates back to zero on the way back down the other half of the arc. The mod isn't for the rated power crew, but instead for those running higher power and speeds, and a 20cm diameter centrifugal blower can move a lot of air even at just a few hundred rpm, and relatively small flow makes a huge difference compared to the stock sealed motor with hot air inside that must transfer the heat through the outer shell to the outside world.
Of course there's nothing wrong with scoop-like blades at the intake other than the increased potential of scooping grit and sand into the motor. I left my option open to doing exactly that on the first one I ventilated in case the cooling effect fell short. It worked well enough for me that I haven't bothered with scoops.
If my latest version falls short, because I want to take it to pretty extreme power, the motor is too difficult after my wire harness mod to remove the intake cover, so instead I plan to add one large stationary scoop to the bike frame that would funnel air toward the ring of intake holes. This would increase the air pressure there outside of the intake holes, and prevent air from flowing fast by the holes. Both of those effects should help create more flow without increasing the chances of small debris entering too much.
Doubters can doubt all they want, but when I've got identical motors, one sealed and the other not, running at the same voltage in the same size wheel at the same speeds, there is no doubt. Loaded down only enough to push consumption at about 70wh/mile the sealed motor gets hot enough to concern me because I can't hold my fingers on the surface between the spoke flanges for more than a few seconds. Loaded down much more for the same climb, the ventilated motor consumed 167wh/mile, and at the top was only slightly warm between the spoke flanges. We waited for a minute or two and the temp didn't rise and we couldn't feel hot air rising from the upper vents, so the stator couldn't have been terribly hot either.
That's proof enough for me, and actually better than only measuring and comparing stator temps, because that's just part of the system and the magnets have a lower heat threshold than the windings. Better cooling won't save a motor pushed too far into stator saturation, or bogged down to too low a speed on hills, so avoid those situations.
John
John in CR
Postby auraslip » Wed May 02, 2012 5:03 pm
that's a pretty good idea
auraslip
1.21 GW
1.21 GW
Postby John in CR » Wed May 02, 2012 6:54 pm
Yes, I missed that part of the post on the first pass, sorry Chalo. In PMs one of the guys mentioned something just like that which get more air going into the centrifugally vented brake discs of F1 race cars. Bring the route of that structure toward the intake area from below, and greatly reduce the chances of foreign matter bouncing in.
John in CR
Postby voicecoils » Thu May 03, 2012 3:48 am
Here's how ventilated drum brakes in old race motorcycles did it:
(it should be fairly obvious which parts stay stationary and which move.. scoop at the front, mesh vent near the shoe linkages).
Overall, they're an excellent study for hubmotor users on a number of levels. Large diameter hub that generate a lot of heat...sounds familiar 8)
voicecoils
Postby Hyena » Thu May 03, 2012 5:06 am
voicecoils wrote:Here's how ventilated drum brakes in old race motorcycles did it
Ah, good point!
Interestingly all seem to have just the one large opening or cluster of holes/slots in one spot
Alternatively something like this is something that could be made aftermarket, as a complete cover replacement.
www.HyenaElectricBikes.com
Aussie high powered and custom e-bike kits
My build and HD video thread__. My youtube channel
Hyena
Postby itchynackers » Thu May 03, 2012 12:18 pm
None of those holes are angled. It'll never work (sarcasm).
9c 9x7f w/ 12awg phases
9c 8x8r w/ 10awg phases, temp sensor, vented
9c 6x10r w/ 10awg phases, temp sensor, liquid cooled, 3rd Place Pikes Peak 2012!
"Don't argue with the galactically stupid...they drag you down to their level and beat you with experience"
itchynackers
Postby hillzofvalp » Thu May 03, 2012 10:29 pm
remember that that will be rotating ;) (probably pointing out obvious).
I would really love to do some custom side covers for say my cromotor. I don't know if it will ever get hot, though. If you guys want to juggle some cad around, I wouldn't mind CNC milling out some covers for any of you guys to try... I have a lot of extra time in the lab this summer. I could make some pretty damn pretty covers, too... :)
If any of you have covers that are off blown motors, but are covers that others on ES could use, I could also spiffy them up
hillzofvalp
Previous
Return to E-Bike Technical
Who is online
Users browsing this forum: No registered users and 23 guests
