the gloves are off now!
(now to slip on the raceing gauntlets.....I am off to cycle my stored batteries)
Amberwolf, Never figured you for a trouble maker!
Alan B wrote:It is an awful long way for Thud to travel. Probably not a worthwhile trip for him.
Thud wrote:
I am 85% on making the trip again. Just need a few guys to call me "chicken" or 'poser" & its ON!
Re: (OUTLAW) Electric Bicycle Road Racing
by safe on Mon Jan 16, 2012 2:57 pm
SAFE MIGHT HAVE TO SHUT UP
Finally !!!
edit out redundant quote from above
Not precisely a 1000 Watt input limited class but I'm happy that the regular folks get to play now.
Geez... at this rate I might actually get accepted back in the ebike world.
(we will see)
Since I would be using near road racing sized tires (24" x 3") I would likely run into troubles with the tire rules if I won too easily, so in order to compensate I would stay in a self imposed 1000 Watt input limit which should make it very sporting. My corner speeds will probably be the fastest of any bike on the track.
People should expect top speeds of at least 40 mph. (50 mph if you push these limits to the max)
AussieJester wrote:ROFLMFAO@safes rambling post...question though, according to Safe liveforphysics was killed on his high powered e-bike, so how I ask is it still possible for him to poison the minds of other 'Sphererites'. Are you doing it from beyond the grave Luke? impressive stuff anyways buddy LMAO
KiM
P.s. Give it shit THudSTeR go go go Team THuD!!!!
liveforphysics wrote:
Yes, i just poke my hand up out of the dirt with my phone when I post.
liveforphysics wrote:My bicycle is on Pirelli's now. HOLY CHIT! This makes the biggest difference in handling I've ever experienced from a single change.
The steering wildness of the machine is gone now, it feels down right tame to ride. No more wander, no more bucking and shuttering in corners, no more chattering under heavy braking, just smooth delightful stickiness and effortless corner transitions. After ripping for long enough that a set of hookworms would be destroyed, the tires look new still! Hardly even scuffed after an hour of ripping hard!
Unfortunately.... the pedals hit the ground really badly if they aren't carefully clocked for each impending corner entry, which I don't really see being safe for road racing.
I'm building an all new frame though... Full suspension this time, setup with 1" of sag front and rear, and 1" of travel after the sag, so 2" total travel front and rear. Needle bearing pivots and linkage. All batteries and motor tucked into the front triangle. And for road racing, I only need about 1/5th the power of my current bike, so a smaller drivetrain as well.
Thud wrote:We are coming full circle.
Safe says:Re: (OUTLAW) Electric Bicycle Road Racing
That said,
Everyone is welcome at the races. The more the merrier!
Your tires are perfectly leagle...your confidence is inspiring. let the fat jokes fly.
Hope to see you at a race someday.
Not anonomously.
T
liveforphysics wrote:I'm building an all new frame though... Full suspension this time, setup with 1" of sag front and rear, and 1" of travel after the sag, so 2" total travel front and rear. Needle bearing pivots and linkage. All batteries and motor tucked into the front triangle. And for road racing, I only need about 1/5th the power of my current bike, so a smaller drivetrain as well.
GCinDC wrote:liveforphysics wrote:I'm building an all new frame though... Full suspension this time, setup with 1" of sag front and rear, and 1" of travel after the sag, so 2" total travel front and rear. Needle bearing pivots and linkage. All batteries and motor tucked into the front triangle. And for road racing, I only need about 1/5th the power of my current bike, so a smaller drivetrain as well.
very interesting... link to thread pls..![]()
April, huh? I do need a couple days away...
Thud wrote:Neil,
PIRELLI ML75'S 2.5-16" (on 20" bicycle rims with bicycle hubs & bicycle spokes)
Leagle for compitition or not.....just say yes or no please. (that "If" you posted raised my eyebrows)
My only real gripe on the bicycle stuff is, it's way overpriced....the Ml75's cost me a 1/3 less than hookworms.
If I am going to blow $800.00 (& a weeks vacation) on a trip out west, The fewer suprises the better.
Stevil_Knevil wrote:Not sure if this is the place to cast my vote, but YES for allowing >2.5" moped tires at MBR events!!
Users browsing this forum: No registered users and 1 guest
