Finally got my Castle ICE 160A HV today, so was all excited about getting home and trying it. The thing surely is small. Can only appreciate how small once in your hand:
Together with my Astro 8150 I was also planning for a lightweight powerful package at 1.6kg:
So I hooked the ESC to the motor, connected a powered servo tester, and my 48V Meanwell. Since the Meanwell is current limited I thought that was a better safety measure than a battery pack.
But instead of running the motor just vibrated a little bit back and forth, while the Meanwell was clearly struggling (cutting out).
Tried two different batteries, first a 12V then a 36V. Same result. Tried another motor. Same result.
Measured resistance between power and phase leads. Shorted between power+ and white phase. Bummer
Could I have somehow caused this?
Or have others gotten broken Castle controllers?
I bought it from rchobby experts in Fl over ebay.
I guess neither them nor Castle are open Fri late night...
What should I expect? Return to seller or get warrantly from Castle?
