j3tch1u
The goal of this project is to mate a magnetic clutch (for brake regen) with a compact planetary drive--two 75 series Matex gears (total 12:1 reduction) powered by a 10-turn Astro 3210. The mid-drive system is mounted on the swing-arm and uses a dual freewheel threaded onto the clutch hub that drives a Nuvinci CVP dev kit servo controlled gear hub. The Nuvinci lets you store 5 shift maps selectable by push-button for various pedal or motor configurations. I plan to run: 1-pedal only, 2-pedal assist, 3-hill climb, 4-high torque, 5-high speed. The first prototype was a no-go--holding power of the clutch wasn't strong enough for the torque of the motor. Now modifying my design to use a wet type multi-plate clutch that should be good for 25 Nm. There is still much more in the works including complete frame redesign to integrate the batteries. More details to follow.
