Kepler wrote:
You are using a Hall effect throttle where a 5K was used just by putting in a jumper? You have gone from a resistive change to a voltage change. This needs more explanation on how this works..
Sorry Kep' im no sparky just a "suck it and see" idiot with a hot soldering iron !
The shop that sold me the throttles said they were Hall effect so i simply hooked up the wiring ,black to -ve, red to +ve and white to "S" inputs on the servo tester and then "jumped the "S" input pin to the mid socket of the pot location.
( note, on the Turnigy Servo tester inputs, +ve and -ve both link direct to the other pot sockets, and the "S" pin is not connected to the board circuits)
The end result seems to work fine , but i will check with a tach' to be sure i am not missing any range.
Kepler wrote:You didnt tell us this when you were talking about sync issues. I wonder if your setup has lost resolution and pulse width is increasing too quickly at the lower end of your throttle range now.
Unfortunately, the "sync " issues were there before i wired up the throttle...just using the servo tester "au naturale" , and they persist unchanged after install.
I have to peddle up to about 20kph before powering up the drive, to have any chance of avoiding "sync failure"
I guess i am going to have to try another motor...or ESC !!
