Hi All
Thanks for advice in posting pictures. Decided on another approach, since i have website I might as well use it. This page is not shown in navigation of website and will be used only for showing info as required. It is not meant for general public consumption or for commercial gain please.
This link has pics and additional comments.
http://elationebikes.com.au/Hidden_Detail.htm
A big problem adding a chain drive system is the effective mounting of the equipment while not crushing the fragile bike tube, but still being able to control the twisting effect from torque.
IMO I don't think it is best to insert a 'barrier' between mounting parts. By this I mean rubber, tubing, pipe, etc. It can worsen the problem.
With the eLation system we approached this problem by using a number of methods that combine to offer a better assembly, alignment and torque control than other systems available. At least we believe so
With eLation we decided on designing a mount system that would handle simple round tubes, right through to a few 'exotic' triangular tubes. Part of this was achieved by using 10mm chain with stainless threaded 'posts' at each end. ES users could use normal bolts with a hole drilled through the head and then the head filed down in one dimension to fit head into chain space. Refer to link above for pics.
With the current elliptical tubes, that change size and orientation as they approach the bottom bracket we have found our mount system to be great. We achieved this by having two plates. The bike plate attaches to the bike frame and has elongated holes to allow the chain clamps to hug the tube even if width changes down the tube. The second plate attaches the motor to the bike plate via a recess in the bike plate. This assists control torque while allowing for left/right alignment. See above link for pics.
The final part of torque control is the use of a barrel type turn-buckle. This is attached to the bike plate at one end and the bike seat post at the other end. By having it act under tension rather than compression, it does not have to be large.
Overall we feel we have overcome mounting and torque issues with this approach. Part of out testing involved a 800W motor and a one metre length of chain. One end of the chain was secured to the bench. The motor was powered at full power causing the chain to come to 'slamming stop' when it ran out of length. On a couple of occasions the chain broke
Using a Dial Indicator (and a few over test methods) we where able to see any deflection or twisting that occurred. The results were conclusive enough to show it works effectively.
Hope this helps some people see an alternate philosophy to controlling torque. Others may see it as a 'commercial', but is hard to show what we have achieved without taking pride in it.
Cheers
Allan
PS. Additional pictures are available here http://elationebikes.com.au/videos_and_pictures.htm
