There’s a common link between the bikes we’ve reviewed so far this issue: they all use internal hub gears – and not just any hub gears, but the newest and latest from Shimano, Rohloff and NuVinci. As I’d also fitted the new SRAM 9-speed to my town bike, the stage was set for a four-way shoot-out.
I'm sure the Nexus hubs can handle the power. There's a guy with a bike shop down in San Diego (Rusty Spokes, in Pacific Beach...) who custom builds chopper-style motor bikes, using Etek and Mars motors. He uses these same Nexus 3-speed hubs with these beasts, and they have worked flawlessly, even pumping 15 hp through them. Instead of chain, hoever, his bikes are belt driven, using regular toothless v-belts. There's a little bit of "slippage" when starting out, which is like a clutch. Works great, he says, and these things can hit close to 60 in just 2nd gear. Anyway, he's never had a single problem with any of the Nexus hubs.
Miles wrote:The output torque would be the input torque divided by 0.66, minus the losses. So, if the max. input torque was 100Nm, the max. output torque would be 151.5 Nm less about 5% = 144 Nm [for 3:2 ratio: 150 Nm - losses]
swbluto wrote:That's probably not the rohloff's gear ratio, heh heh.
Ok, dude, I totally need to find out the nexus-3's lowest gear ratio
rkosiorek wrote:i have had a little experience with the NuVinci and more with the Nexus.
sturdy as the Nexus hubs are i think that the NuVinci will handle more torque reliably. now it comes down to price. Nexus is well undet $200. and the NuVinci is near double that.
rick
Miles wrote:I think the low gear on the Nexus 3 is 0.64.
I should imagine the Rohloff is conservatively rated. I doubt the Nexus 3 is tougher....
11 Speed Alfine IGH Specs: wrote:jumps: 2 x 17% and 8 x 13%
Toorbough ULL-Zeveigh wrote:is there anything preventing the other IGH from stacking the deck in there favour the same way with a double chainring or a hammerschmidt/schlumpf?
don't think i've never seen it done by an oem although i'm sure someone must have.
GGoodrum wrote:I think the strongest Nexus hub is either the "red stripe" Nexus-8, or the newer Alfine, which is also an 8-speed hub. From what I've read, these are the ones the DH guys and other "heavy users" have used. The Alfine has a disc brake mount, which I'm guessing is, or should be important to you.…
swbluto wrote:I was hoping since the nexus 3 would've likely devoted "more space" to each gear than the nexus 8, it would actually have significantly better durability but this doesn't seem to be the case.
liveforphysics wrote:The engineer side of me struggles to see how an 8spd hub could could come near the torque holding ability of a 3spd hub, assuming both designs try to make use of available space in the hub for he gearing. But, if you say it's the toughest, I will get it…
GGoodrum wrote:The 8-speed hubs are about twice the diameter, so from what I understand, the parts are beefier, even with 8 speeds.
GGoodrum wrote:Which 3220 wind do you have? With my 7-turn, it has a kV in wye mode of 97. Assuming you are running a 12s LiPo setup, and 12t/100t gearing with a 20" wheel, what I get with the S-A and/or the Nexus-3, is a top speed of 20 in 1st, 27 in 2nd and 37 in 3rd. With a 26" wheel, the numbers go up to 27/38/48, respectively.
I can also tell you that with my setup (20"/3220-7t/11t-94t/12s3p Turnigy LiPo...), it has enough low-end torque in first that it flips me right off the back end, with no problem.
-- Gary
Users browsing this forum: Bing [Bot], mwkeefer, shenzhen_ex and 12 guests
