flyinmonkie wrote:@byte
It's called liquid tape. I'm sure it is the same as the tool handle dip stuff. It's alright, but not fantastic. It will be a pain if I ever have to remove it.
Not sure about the 15 pin plugs. The DB25's aren't all that big.
Clay
flyinmonkie wrote:Thanks Kim,
Hope you had a good time on holiday and ticked everything off the list you gave us... several times.
Are we going to see some bike work from you now? I know you won't be in the shop everyday.
Clay
flyinmonkie wrote:It's been ages. I've been in and out checking on what is happening, but not doing much work on the bike.
I finally sorted the one plug charge plug, but something is amiss. When I plugged it in to check it, the charger was not reading the balance taps. Then some smoke started coming out of the charger near the main output plugs. I immediately unplugged the pack and turned the charger off. The charger seems to be working correctly, but I think I should open it up and see what smoked. I guess I'll have to recheck all my connections in the charge plugs and make sure there are no shorts. I can't think of what else would cause the smoke. I am not sure why the balance taps aren't being read either. I can only guess that the connection to the Goodrum LVC boards isn't making a connection.
Clay
flyinmonkie wrote:Thanks Snow,
I tested continuity on all the wires on each side of the plug and triple checked everything went to its mate between plugs. I think the balance leads aren't getting a good connection right from the LVC boards. the wires are pretty small.
I have been to busy moving this week and weekend to look any more. Only going a short distance, like around the block. Unfortunately I will no longer have a garage. Good think I am almost finished with this bike.
I'll have to test my output leads from the charge plug and make sure the polarity is correct. I'll also pop open my charger to see what was melting. I am guessing it was just a bit of insulation on a wire, or at least I am hoping it is. Still seems very odd to me that it would smoke at all. It is a hyperion 1420i, so I would guess it has a reverse polarity warning.
Anyway, this will all happen after I have finished moving this weekend. It is warming up, so I need to sort it soon. I want to get back on the bike for commuting this summer.
Clay
I thought about that, but I wasn't sure where to measure the voltage. You put one lead from the meter on the pin of the balance plug, and where doest the other lead from the charger go?
Clay
Users browsing this forum: cheekybloke and 11 guests
