fizzit wrote:Hmmm... what to do???
Hillhater, are you saying that the bearing flange will bend between the bearing and the bolt or the bolt threads will strip? Because that's the only way I can really see it flexing, barring the spacers deforming. The chain loads will be completely pulling towards one of the bolts on one side and away from that bolt on the other, the only reason the bearings are rotated 45 degrees on the mockup is because I countersunk the wrong side the first time I drilled the bolt holes![]()
AJ, I wish it were that easy! The pictures don't show it, but the tube is oval shaped
fizzit wrote:Does anyone have any idea how I can get a 11-or-so-tooth bike chain sprocket onto a .5" shaft? I'm open for any ideas, even for having someone machine another #40 sprocket for me. however, I want to keep it under $25 if I can, and with that budget I think machining is out
dequinox wrote:Lol not bad looking for a dull hack saw. I think it will work! The idea behind the sandwich plate, though, is that you bring it down far enough to mount the other bearing to. Cut a hole in it for the motor...or just leave a corner off or something like that.
dequinox wrote:$9.60 at McMaster-Carr: http://www.mcmaster.com/#drive-sprockets/=9jxfxz
or $13.44 if you want hardened teeth. I don't know what shipping is... but they even have 9 tooth sprockets for a 1/2" shaft.
Miles wrote:#40 chain has the same pitch & roller dia. as bicycle chain but it is much wider.
Dimensions here: http://www.gizmology.net/sprockets.htm
spinningmagnets wrote:Similar to one of Thuds projects? whether you are driving the Bottom-Bracket or rear wheel, I am seeing more of these boxed RC-single-stage reductions.
This is Mud2005's RC-MTB:
fizzit wrote:This is what my bike looks like right now. It is hanging from the ceiling, I'm not really sure why.
Users browsing this forum: MagerPain, tonyontopofabighill and 3 guests
