Warren's 350 MAC mid-drive (finally) recumbent
Re: mid-drive questions
Postby pdf » Sat Sep 24, 2011 12:05 pm
Warren wrote:Folks,
OK. This puppy is done. And I love it. I know that most of you guys are not the aerobic type. But for those, like me, who would rather bicycle than drive any vehicle, this is the dream machine.
Put up pics when you have them. I love my mid-drive upright (Stokemonkey). Ride it nearly everyday. I did fix up a high-turn (2810) hub motor for my son and am amazed at how well it performs on hills at 72 volts though. On the other hand, it is really tempting not to pedal at all on a powerful hub setup. It really depends on what you are trying to accomplish
Jamis Commuter 1.0/Xtracycle Stokemonkey 36V LiFePO4, 15 ahr
Giant Boulder 9C 6x10, 18s1p LiPO, 5 ahr, 18FET Lyen edition
pdf
Postby Warren » Sun Sep 25, 2011 1:14 am
pdf,
I will put up pix soon.
Yes, mopeds, and scooters are great fun. But we are all inherently conservative of our energy...lazy. Ultimately we end up with coal fired SUVs. A human/electric hybrid is Methadone for energy junkies.
Warren
Warren
Postby Warren » Mon Oct 03, 2011 8:55 am
Warren
Postby amberwolf » Mon Oct 03, 2011 4:21 pm
Unfortunately it will not allow non-registered guests to see them. :(
Posting pics here is easy, if you are attaching them like they appear to be there:
When posting, there is a section of the page called "Upload attachment", below the box you type your post in. Use the Browse button to find the file on your computer, select it, and click OK. Then click Add the file button on the posting page. The popup will upload it and let you know when it's done (by going away).
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby Warren » Mon Oct 03, 2011 11:17 pm
Amberwolf,
Thanks. Now I have to figure out how to shrink the file. Too big for this site.
Up to 285 miles now. Did 37 miles in overcast ,53 degree weather today. Voltage was down about a half a volt from the 70-80 degree weather we have been having. Still averaged 22.4 mph. :-)
Warren
Warren
Postby amberwolf » Tue Oct 04, 2011 12:48 am
If you use Windows, just open the file in Paint, then use this key sequence:
Ctrl-A
Ctrl-W
type 25 in each of the first two boxes (for 25% of original size. Use a different number if you want a different final size)
click OK
File-Save As
type in the filename you want (don't save as the same file name or you destroy your original)
and pick the file type (defaults to whatever it started as, usually that's fine)
amberwolf
Postby Warren » Thu Oct 06, 2011 6:30 pm
Thanks Amberwolf. Here goes.
Warren
Postby amberwolf » Fri Oct 07, 2011 2:15 am
Well, the good news is the resized pix did save small enough to upload and view successfully, but the bad news is that there must be something wrong with your original pix if they have that much whitespace in them (there shouldn't be *any*).
I edited the whitespace out and reposted them below, without any other resizing:
(180.47 KiB) Downloaded 3 times
(209.89 KiB) Downloaded 3 times
amberwolf
Postby Warren » Fri Oct 07, 2011 8:23 am
Amberwolf,
Thanks. I have 325 miles on now. I will have most of next week off. I hope to do an 80 mile ride Monday...calling for sunny and 80 degrees.
Since I have been riding with the broken pedelec sensor, I have decided to take it off. As a motor vehicle operator, I feel like a boor blowing stop signs, which I always did on my bike. I shift into low before stopping, and a little throttle makes getting the pedal into position for my foot a lot easier.
The only problem I have now is some EMF interference messing up my maximum speed reading on the CA. I tried shielding part of the controller-to-motor cable with aluminum foil. That seemed to help. I went about ten miles before it messed up again. It usually goes to 600+ mph!
Warren
Warren
Postby amberwolf » Fri Oct 07, 2011 5:36 pm
With my SA CA, I had an intermittently broken wire (thanks to my dogs) in the speedo cable that caused a similar problem. You might want to recheck the speedo wire. Put a continuity meter across it's CA end, and a magnet on the sensor end to force it's circuit closed. Wiggle the wire around along it's length and if the buzzing stops at all you have found the problem.
amberwolf
Postby Warren » Sat Oct 08, 2011 8:26 pm
Amberwolf,
Justin mentioned squealing brakes causing vibration of the reed switch. This makes sense, as it started after I switched brake pads, which now squeal. Will try getting rid of the squeal first.
Did another thirty before dinner tonight...21.8 average, 11.6 Wh/mi. Climbing lots of hills in the teens means flying for miles at 25-28 to get that average. :-) I am loving this bike.
Warren
Warren
Postby Rassy » Sat Oct 08, 2011 10:38 pm
Warren, nice and clean looking build. Sounds like it performs up to your expectations.
I find it interesting how many ways there are to tie a mid-drive into a system. Without even going into rc builds, you have yours set up more like a Stoke Monkey driving the left side of the crank, LIghtcycle has his driving the IGH directly with a second sprokett, and mine pulls directly on the main chain. Still they all accomplish the same goal, of having a multi-geared motor.
Anyone that has hills to get up and finds that a regular hub motor either runs out of power or overheats should take a good look at multi-gear systems.
Of course Dogman's solution of just having a bike for each type of terrain is pretty cool to. :D
-Rassy-
Two Tadpole Trikes, 6X10 9C mid drive, NuVinci CVT Auto Shift, 48V LiFePO4
viewtopic.php?f=28&t=18606
viewtopic.php?f=28&t=47043
Rassy
Postby Warren » Fri Oct 14, 2011 11:45 pm
477 miles so far....94.7 miles off this charge at 20.15 mph average. That is to 80% DoD on a 1.1 kWh pack.
It has been raining all week. Looks like most of next week too. :-(
Warren
Postby Warren » Wed Oct 19, 2011 6:02 pm
Monday, I put clipless pedals on the electric, and went on an 80 mile ride. Three hours, 50 minutes riding, at 20.9 average, 70% of my charge. The weirdest thing was that, for nearly the whole ride, I had people following me for miles. Mostly pickup and SUV drivers!? They were apparently amazed that you could travel at reasonable speed without 2 tons of steel around you.
Warren
Postby Hillhater » Wed Oct 19, 2011 6:36 pm
It maybe just a visual distortion, but it seems to me your hands /bars are strangely close to the pedals ???
Can you actually straighten your legs when sat back on the seat, pedalling and holding the bars comfortably. ?
Hillhater
1.21 GW
1.21 GW
Postby Warren » Wed Oct 19, 2011 9:37 pm
"Can you actually straighten your legs when sat back on the seat, pedalling and holding the bars comfortably. ?"
My bike is laid out just like this.
http://www.rans.com/itr83image/TannerXS.jpg
Several of these finished very well in the RAAM. It is as comfortable as you can get, and still exercise.
Warren
Postby Hillhater » Thu Oct 20, 2011 7:06 pm
Warren wrote:My bike is laid out just like this.
http://www.rans.com/itr83image/TannerXS.jpg.
sorry, but the layout , relative position of the seat, angle of seat, bars and pedals,...appear very different on that bike compared to yours.
I will take your word that it is a comfortable ride, but it just seems odd to have your knees up between the bars !
Note to self: ... must arrange a test ride on a recumbent ! :wink:
Hillhater
1.21 GW
1.21 GW
Postby Warren » Fri Oct 21, 2011 4:44 pm
"sorry, but the layout , relative position of the seat, angle of seat, bars and pedals,...appear very different on that bike compared to yours."
Yeah, right! You just wanted to see my legs. :-)
Warren's Electric Bike 2.jpg (166.48 KiB) Viewed 1072 times
Warren
Postby Warren » Fri Oct 21, 2011 9:30 pm
Seriously though, I am using the same bars, and riser. But you see the six inch telescoping portion of the riser just ahead of the bars on the yellow bike? That is there so they can lay the seat further back, and still reach the bars. This creates a lot of tiller effect. Also his shoulders are almost over the rear axle, putting more weight on the rear wheel. If I were racing, this would be more aero.
But for riding around in traffic, I'd rather be a little more upright. Also, if I end up running a front Zzipper this winter, that will make up for the aero difference, and reduce wind noise, and windchill.
And, yes, you should try a recumbent. For fast, long distance riding, nothing beats the recumbent position. That goes for bicycles, e-bikes, and motorcycles too.
Warren
Warren
Postby Warren » Fri Oct 28, 2011 9:20 am
753 miles so far. Did two 62.5 mile rides, the last two days, to town for lunch, lots of climbing and descending, lots of curves.
22.5 average, 11.9 Wh/mi the first day....22.7 average, 12.0 Wh/mile the next. At least I am consistent. :-)
I was followed out of town by two different cops the second day. Shifted down into 6th to keep it at 20-21 mph. Move along...nothing of interest here.
Calling for highs in the 50's and low 60's...time to get that Zzipper.
For reference: I did my 16.2 mile loop the other day, on my carbon roadbike...16.4 mph average...best time in a year. Ten years ago I would average 20 mph around there.
Warren
Re: Warren's 350 MAC bottom bracket drive recumbent
Postby Warren » Fri Nov 18, 2011 5:24 pm
Well, I thought I would rename this thread, as my questions have all been answered, and now it's just rolling on the miles. We were out of town for the three nicest days all month. :-( Its been cold and rainy since we got back. It was 46 degrees today, but at least the it was sunny, and calm. So I did a short 36 mile ride to get the odometer to roll over to 1001 miles!!
Its been pretty uneventful. No cooked Hall sensors, magnets, or cells. No tires ripped off the rim. But I've gotten lots of exercise, and seen deer, hawks, even a baby copperhead. And I get to laugh at dogs now. :-)
Warren
Re: Crystalyte mid-drive questions
Postby dumbass » Fri Nov 18, 2011 5:49 pm
jbond wrote:
katou wrote:First stage: motor to left side Bottom Bracket cog
Second Stage: right side cog to rear cluster
Where are the freewheels in this config? Does that mean the pedals have to move under motor power?
How ever you build it be sure you have a good freewhee between the motor and your peddles. Never have the peddles turn from the motor. You can really get hurt that way.
I use a jack shaft setup between my motor and the rear wheel. This give a good oppertunity for gear reduction plus a great place to mount a freewheel. You can also replace the peddle shaft with a longer one and install a freewhell directly on the peddle shaft.
Bob
dumbass
Postby Warren » Fri Nov 18, 2011 9:30 pm
Bob,
"Never have the pedals turn from the motor. You can really get hurt that way."
Stokemonkey has been doing this for 8 years with no problems. There could only be a problem if your motor is geared higher than you can pedal comfortably. Are you imagining the throttle hanging wide open? So what? I ride with mine wide open at all times. The pedals turn about 80 rpm. I can clip in and out of my pedals, as they go around, at that speed.
Warren
Warren
Postby dumbass » Sat Nov 19, 2011 1:15 pm
Warren wrote:Bob,
Warren
Warren,
I would certainly never tell anyone how to equipt their bike. But sorry I don't think that having the motor powering the peddle chain without a freewheel to protect you is not safe. But if your comfy with it that's cool.
Bob
dumbass
Postby Warren » Fri Dec 09, 2011 9:49 am
Made a Y cable to run my two 5 amp chargers in parallel. The setup works great. Reduces a full 936 Wh charge, into my 1170 Wh pack to two and a half hours! And the BMS stays cool the whole time.
This will allow me to do some really long rides now. No more of these wimpy 80 mile days. I can hammer out 75 miles in three and a half hours, then charge, and ride another 75. :-)
1197 miles, so far.
Dang! It was cold this afternoon...in the 40's. 1259 miles now.
Warren
PreviousNext
Who is online
Users browsing this forum: No registered users and 10 guests
