RC Greyborg build thread
Re: RC Greyborg build thread
Postby comradegerry » Mon Sep 12, 2011 3:28 pm
I have been too busy working to really get thing nudged along much further and my new parts are still in transit...
I do find when i finish my head is always racing with ideas for the bike, it is an obsession, my Mrs is not too happy with it.
I think I have decided how to configure the batteries, making a decision is a good step in the right direction. After reading the "Headway builders thread", big thank you to all that have helped post great information in it. I have decided that i will be hot glueing my pack together 48v 20 ah to squeeze it into the forward compartment. It seems like if done vertically I can keep the width down to 145mm. I read Hals thread on his Albino where he reckoned 160mm wide in the horizontal configuration was a tad wide for comfort. All things are a compromise and to shoehorn in the power I need, weight and bulk is added. I looked at splitting the pack into the 2 battery bays 3 cells wide, which would work but I cannot get the ah I need. This configuration allows the top half of the lower section above the Astro to fit another 10ah at 48v at a later date. I will need 30ah to even have a chance at Pikes Peak, I am already thinking of the "long range " booster pack and it's integration.
I will have to stretch the canopy a tad but that will be fun and a learning curve too!! Does carbon fiber stick to plastic without a primer? :)
48v 20 ah duct tape config.jpg (106.87 KiB) Viewed 1441 times
48v 20 ah top view.jpg (114.53 KiB) Viewed 1441 times
comradegerry
Postby comradegerry » Fri Sep 16, 2011 2:37 am
Front chain ring arrived in the post, stainless steel Surly 46t 130BCD, I hope that does the trick. I took the freewheel adapter disc to a local metal shop here in Pula, the idea was to rebate 2mm off the edge to allow the Gates cog to sit a little further fro the frame as it just rubs. My idea was lost a little in the translation process and the entire assembly was reduced to 3mm thick. great weight saving but I now need to pack out the disc to move the Gates cog 2 mm away from the frame to stop the rub. New bushings arrived for the shock so that will be mounted next. So close to being a rolling chassis... Once she peddles I can start working on the chain alignment for the RC drive and motor mounting solution.
Crankset Outside.jpg (122.35 KiB) Viewed 1383 times
Crankset Inside.jpg (121.35 KiB) Viewed 1383 times
comradegerry
Postby Philistine » Sat Sep 17, 2011 3:31 am
Looking good ComradeGerry, definately going to be the most interesting greyborg on here sofar. Looking forward to seeing it going.
I have been getting awesome service out of mine. Apart from blowing up my 9C 8x8 (my fault) and then also adding extra torque arms, I haven't had a single issue since the build, and I ride it every day.
Philistine
Postby Spacey » Sat Sep 17, 2011 3:59 am
I think the next version of the frame should have the dimensions changed a bit.
I've found that it is very easy to make the bike seat too high with a good suspension unit, but when I put in a smaller one the pedals hit the ground a bit to easily.
I really need to finish off my build, have the covers held on with duct tape at the moment and does not look pretty. But it does soak up the miles far better than a normal bike... I kind of like the weight of it.
After the Lipo's fail I will probably try to fit some A123 pouches in there, love the fact that the batteries are hidden from sight.... love my Greyborg :D
Spacey
Postby Philistine » Sat Sep 17, 2011 5:02 am
That's dead true spacey. Because I run a Rock Shox rear which is small, if you go into the slightest corner with a peddle down on the inside, it slams into the ground and I have nearly had a few prangs from it. It's the first thing I warn people about when they first ride it. The other issue/problem I have found with the canopy, is that if you have triple clamp forks like the Boxxers, they hit the front part of the canopy when you turn the handle bars all one way, restricting the potential turning circle by about 1-2 inches. I see no way to account for that with triple clamps, unless you cut out that very front part of the canopy or something. It's a shame because I don't even use that space at the very front of the canopy as my battery box stops before that point. Those are my only gripes.
Philistine
Postby comradegerry » Sun Sep 18, 2011 3:22 am
Mounted the chainwheel and used 1 washer behind the WI Freewheel to just move the inner Gates cog away from the frame, no rub any more. Elongated the holes in the torque plate to allow belt tension, not quite as much as I would have preferred. Gates recomend a tension that 5-10lb of weight at the mid point on the belt will create 1/2" of deflection, so that is what I aimed for.I used an Alan key wedged between the frame and the flat of the axle as a guage to tension the belt. 6mm seemed just too much and 5mm was not quite enough. I now need to remake the torque plate with the idea of the sliding tension arrangement, 12mm of adjustment should be all that is required and should account for any growth in the belt over time. I will probably make a matched pair to strenghen things up and for asthetics. Moving the wheel back in the drop outs 5.5mm seems to give the right belt tension, I think, maybe 6 or 6.5 maybe the magic number but I do not have that ammount of adjustment yet.
The only problem I foresee with this setup is changing a rear tyre will be a PITA as it will need the chain from the motor disconecting to allow the removal of the crank ring, before the belt can be removed. I just need to add a front brake, connect the Shimano gear cable, stick the pedals on and see what happens with some proper loading on the drive train. I have noticed a significant a mount of wobble in the freewheel at no load, spread over a wide chain ring this looks like 1/4" of play, which may be too much to live with since all the tolerances are quite tight. The Greyborg will definately be a moving bicycle this week.
Chailine Holes Elongated.jpg (83.94 KiB) Viewed 1278 times
Chainline Tightened.jpg (127.94 KiB) Viewed 1278 times
Chainline Deflection Test.jpg (125.29 KiB) Viewed 1278 times
comradegerry
Postby comradegerry » Mon Sep 19, 2011 1:23 am
Managed to get the last couple of small jobs ticked off the list to make the rolling chassis. Front brake mounted, rear hub gear selector connected and taken for a spin round the local car park. I need to play with the gear cable settings to get all 11 gears to operate as they should but that should not be a biggy. I was happy to see it get this far at least :D I am chuffed with the clean belt drive line, without having to install an idler, hopefully it does not grow significantly. The bike has 165mm crank arms, instead of the more standard 175mm variety, if ground clearance becomes an issue, it will be getting a 29er up forward. It does already remind me a bit of my old DT175 when straddleing the frame. I think I will get away with widening the canopy up forward, but close to the seat just rubs the tops of my inner leg, I might try to reduce that part of the canopy for comfort when pedaling.
Next on the list are motor mounting, battery building, enclosure modding, rear brake and sorting out the wobble that exists on the chain ring. It seems like the ISIS bottom bracket is bent slightly but it is brand new.
Front Brake Mounted.jpg (181.23 KiB) Viewed 1233 times
Maiden Voyage Pedal.jpg (180.1 KiB) Viewed 1233 times
Rolling Chassis.jpg (191.47 KiB) Viewed 1233 times
comradegerry
Postby Philistine » Mon Sep 19, 2011 7:51 am
Looking good mate. I can't wait to see it going with the RC drive, where are you going to put the motor/drive (apologies if you already explained this)?
Philistine
Postby comradegerry » Tue Sep 20, 2011 1:34 am
Hi Phil
Great question and one to which I do not have the answer set in stone yet.... I had originally dry fit the motor and reduction in the bottom of the frame, which seemed to fit snugly, that was before I had the chainline setup. The adapter that holds the motor freewheel onto the redtucion drive protrudes about 1/2" past the teeth that the chain runs on, this stops it being used within the arc of the pedals. It could fit in the middle of the canopy but this spoils the space for the booster battery by splitting it. This leaves the very top of the lower frame section, which is the location I am leaning towards. It has a longer chain run, which might mean I can get away without an idler on the drive chain? I started making a mockup bracket in hammer bent ally last night but I did not quite get it right. I am going to try to have the drive unit mounted on a plate with horizontal elongated holes so that I can fine tune the drive line. this palte would then be mounted to another plate with elongated vertical holes to tension the chain. It's the next thing on the list that needs sorting.
comradegerry
Postby rodgah » Wed Sep 21, 2011 4:59 am
comradegerry wrote:sorting out the wobble that exists on the chain ring
if this isnt a product of the adaptor you had made from the freewheel to chain ring, I have noticed (and others have to) that the thread of the cranks is never quite centered. thus when freewheeling the chain runs smooth, but when the cranks are turning the chain changes length. This is with expensive Echo cranks so...... :roll:
Cheers
Common Sense isn't so common........
Image Image Image
rodgah
Postby comradegerry » Wed Sep 21, 2011 5:16 am
The adapter I made is flat, definatlely after it was machined at least, if I had the freewheel slightly off center I would expect it to oscilate a little up and down, not left to right... When I turn the crank arms backwards and it is freewheeling, the adapter is stationary but wobbles right to left as the crank arms turn. With the rear wheel off the floor and the crank arms turning forward the same wobble exists. It seems like either the bottom bracket spindle or as you sugest the thread on the crank arms, both were new and a bit spendy... I do have another set of ISIS crank arms I can fit and try to eliminate or confirm the spindle as the possible problem. Thank you for your input.
comradegerry
Postby recumpence » Wed Sep 21, 2011 7:03 am
Yup, my expensive Echo cranks were threaded a tiny bit off as well. I got that sode to side "Wheel out of true" type of wobble on mine as well.
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
recumpence
Location: On Earth right now. That can change at any time, though..........
Postby rodgah » Wed Sep 21, 2011 5:17 pm
sorry yes thats what I ment (its been a while since I looked at them).....yeah its like a buckled wheel as matt said, i would put money on the cranks. This still isnt a problem when you are motoring as the wobble wont exist if the cranks are stationary.
Image Image Image
rodgah
Postby Spacey » Fri Sep 23, 2011 2:10 pm
Yours looks so much tidier than mine....but I have done over 2,000 miles on mine in crappy UK weather :)
It's a shame the triple forks hit the body when turning tight. But it does ride like a Limousin...funny I see you have the same rear suspension that I had on my Greyborg....I took it off for a much cheaper but not so high one as my riding position was hurting my wrists. Now the pedals are too low doh!
Think I might cut off the seat and have it like a motorcycle seat that runs up the crossbar?
Nearly finished.jpg (141.66 KiB) Viewed 993 times
Spacey
Postby comradegerry » Sat Oct 22, 2011 2:41 pm
And the slow plod continues....
Made what I think will be the motor and reduction drive mount, much bashing and drilling of Ti plate.
Having done the dry fit today, I now realise I have to chop a little bit of battery frame holder on one side and cut a hole in the mounting plate for the chain part of the reduction gear.
If it works like I hope I can likely sqeeze in another 10ah at 48v below the motor to give a 30 ah total which is the goal.
I am not 100% happy with the chain line and may try again to squeeze it into to the lowest part of the frame but this seems like it might work and I am just keen to get it powered up at this stage.
Frame mount 5.jpg (107.48 KiB) Viewed 820 times
Frame mount 1.jpg (82.08 KiB) Viewed 820 times
Frame mount 2.jpg (94.64 KiB) Viewed 820 times
Frame mount 3.jpg (89.63 KiB) Viewed 820 times
Frame mount 4.jpg (108.96 KiB) Viewed 820 times
comradegerry
Postby comradegerry » Mon Oct 24, 2011 2:12 am
Spent the day trying to sort out the last few snags on the motor mount but did not quite get it done. Had to cut out a space for the chain driven part of the reduction gear, then elongated the mounting holes for the U shaped track to allow 10mm or 11mm of up and down motion to get the drive chain to the right length without an idler. Once the motor assembly moved upward I found that the belt pulley restricts the full movement do there will need to be some more frame filing tomorrow. Got it all together then found I had not made a hole for the motor wires to come out cleanly from the compartment, grrr. 8 hours spent drilling, filing and cursing for not much progress, it was an infuriating day. I think I might have to add a "power bulge" on the canopy just to conceal the chain wheel reduction, it is just too close.
Chain Reduction Line.jpg (101.77 KiB) Viewed 1239 times
Motor Frame Mount 4.jpg (106.19 KiB) Viewed 1239 times
comradegerry
Postby comradegerry » Sat Oct 29, 2011 1:31 pm
Managed to get the motor finally mounted and lighten up one of the reduction wheels. I think it should work, I can turn the motor over by hand and the rear wheel turns so things look promising. Batteries next up on the to do list. Happy Halloween! :twisted:
Lightning 1.jpg (96.33 KiB) Viewed 1168 times
Lightening 2.jpg (77.35 KiB) Viewed 1168 times
Right Side Motor.jpg (121.95 KiB) Viewed 1168 times
Left Side Motor.jpg (127.46 KiB) Viewed 1168 times
comradegerry
Postby HAL9000v2.0 » Sat Oct 29, 2011 2:26 pm
This is great. Love how high you have monted it. Defintly better to put batteise below.
Why didn't you go with just belts?
HAL9000v2.0
Postby recumpence » Sat Oct 29, 2011 2:50 pm
HAL9000v2.0 wrote:This is great. Love how high you have monted it. Defintly better to put batteise below.
Belts are wider than a chain for the same torque loading. So, as far as the drive system goes, that I why I went with a chain for the second stage. :)
Matt
recumpence
Postby HAL9000v2.0 » Sat Oct 29, 2011 3:07 pm
That is a good reason. :oops: :D
HAL9000v2.0
Postby comradegerry » Mon Oct 31, 2011 2:37 am
Since the drive train seems OK, the batteries are the next on the to do list. I had an old duct tape pack from my old frock that is going to be sacrificed as the guinea pig and trial unit. Using a dremel with a cut off disc I broke the pack up into units of 3. I figure I can squeeze 3S 16p into the space below the motor for 48v and 9ah. After fitting the trial block and doing a bit more thinking I can see 4S 16P as being possible, so that is what I will aim for this evening. The old pack had welded tabs, the flap after cutting them open is where I plan to solder some bits of wire to reconnect it all again. Then hide the entire thing in more duct tape. It is a trial, if it works, sweet, if it does not, then I have the form mapped out can get a new battery made up. The top battery section will be a seperate 48v, 20ah cell block made of 38120 lifePo4 cells with 2 24v BMS.
What I do not know yet is how to switch between the packs on the fly but hopefully somebody smarter than me knows how to do it?
How to charge everything without having to take the canopy off. I was thinking of some kind of XLR connector flush mounted but could not find any weatherproof ones?
How to Isolate the batteries without taking off the covers and switching between them for charging?
I have a left handed half turn throttle and 3 position switch but do not know how to program the CA to set 3 current limits for legal/economy settings and "Off Road" applications. I was thinking 400w, 800w and 1200w as being the preferred set points, if that can be done like that? Controller is a 12 fet Lyen but have no clue if that is programable at some level?
Some sort of key to help stop the pikeys stealing it and zipping off with it when I have it leant against the wall of my favorite pub.
Old Battery.jpg (151.48 KiB) Viewed 1103 times
Battery Trial Configuration.jpg (124.52 KiB) Viewed 1103 times
comradegerry
Postby recumpence » Mon Oct 31, 2011 8:33 am
Looks really snug. I love it! No wasted space.
Matt
recumpence
Postby Andje » Mon Oct 31, 2011 2:11 pm
will you be using the CA as your throttle control? If so then you can have a top speed or top amperage programmed in. If you also have one of the programmable lyens conrollers, then msg him for the software link or grab the freeware from the forum (search keywin). Inside the software there is a speed section where you set your max speed (as a %) and then can set the three speed switch to three different %'s of that original total %. The total speed is just the kv of your motor* the volts of your battery=rpm*circumference of your wheel/ distance. The switch can be set from anything between 0 and 120%.
I love it too! Chain clearance seems pretty tight... but if it's solid and won't torque in the frame then it'll be great!
Norco 125 Dirt Jumper
100v 15ah Lipo Backpack
lyens 18 fet, 100v 100 amps, R12 Regen
x5304- 95km/h
http://endless-sphere.com/forums/viewtopic.php?f=3&t=24594
Norco A-Line Park 2009
144v Kelly 300amp
5403/ future HS60
http://endless-sphere.com/forums/viewtopic.php?f=6&t=35652
Andje
Postby comradegerry » Wed Nov 09, 2011 4:14 pm
I will be using the CA as throttle control with top amperage programmed in as Andje sugests, probably 20 amps to start with.
I will be trying to program the Lyen controller and the 3 speed switch too, my head started to hurt when I read that thread, way over my head unfortunately, it will require reading a few times, slowly to sink in.
Built up the other pack to the format it will be, insulation tape in red and black at the ends of the cells to stop me making a booboo wiring them and also to just open the cells up a small bit for cooling plus to act as a barrier against chafing, these were all then hot glued together into 2 packs. The hot glue was just blobbed about 3/4" at either end on the tape but it seems pretty sturdy without going nuts. It is still possible to pull them apart if required as the insulation tape is the weak link, I already tested that when I assembled 1 slightly wrong. I Fluke tested all the voltages and they were real close which was great as they have been sat in my wardrobe 6 months already. The 2 packs mate together but are not bonded, the idea is 2 x 24v, 20ah each with an 8 channel BMS. Bought a copper sheet 12x12 on ebay and will make up the connection strips and shrink wrap what I can. Should get it wired this week, hopefully.
These cells were from Armin at LifeTech, he was a pleasure to deal with, very helpful and the quality of the cells seems top notch at least on first inspection. I just did not have the space to use the cell blocks and copper strips that came with them due to my space constraints.
I will be stretching the canopy up forward to 150mm wide to hide the batteries but since it is well clear of my knees I hope it is still comfortable to pedal.
Final Battery Layout 1.jpg (115.36 KiB) Viewed 953 times
Final Battery Layout 2.jpg (122.03 KiB) Viewed 953 times
comradegerry
Postby comradegerry » Sun Nov 13, 2011 3:58 pm
Started wiring the batteries with some plate copper, slow work, got the first half done and will be working on the other half through the week.
After the rough fit and voltage test started to remove the excess copper with a file to lighten things up a little. Thank God copper is easy to file. :)
Batt wire 1.jpg (102.53 KiB) Viewed 872 times
Batt wire 2.jpg (109.4 KiB) Viewed 872 times
Batt wire 3.jpg (120.54 KiB) Viewed 872 times
comradegerry
PreviousNext
Who is online
Users browsing this forum: Bing [Bot] and 10 guests
