katou wrote:
It appears from AussieJester's build log for his HXT chopper: viewtopic.php?f=28&t=12810&start=300
That he also tried it out. I didn't follow the thread long enough (104 pages) to figure out what happened with that effort.
Did he end up using them? If not, why?
1000w wrote:This setup of mine has been faultless for about 2500km and the teeth show basically no wear at all. The load is shared by many teeth all the time.
http://www.endless-sphere.com/forums/vi ... 7&start=15
Cheers,
Matt.P.
I've no experience of water jet cutting. How feasible is it to get something like this cut with kerf-taper compensation?bobc wrote:top picture is the blank you'd get water jet cut in 25mm ally
John in CR wrote:Do the large diameter pulleys really need teeth?
Miles, I like the lantern gear rig, though I think I'd go double sided with the disk for almost no extra work. If the epoxy route didn't seem so easy, I'd give that a go.
recumpence wrote:John in CR wrote:Do the large diameter pulleys really need teeth?
That depends on the belt tension, pulley diameter, belt wrap, belt and pulley material, and torque applied. Most clothes dryers use a stupidly thin (maybe 8mm or so) ribbed belt wrapped directly around the smooth drum. They hold fine with proper belt tension.
Matt
recumpence wrote:Hmm, 12 inches is a decent amount of surface.
I would say for a Neoprene belt, it would be worth a shot.
Matt
For wider belts, I'd do something like this:John in CR wrote:Miles, I like the lantern gear rig, though I think I'd go double sided with the disk for almost no extra work.
Localised bending reducing belt life was what I was worried about but you're right, if you miss out teeth it will affect the pitch but not otherwise. On the last two designs I posted, I modelled the pulley channel so that it supports the belt teeth (as you suggest).John in CR wrote:Miles,
With the lantern type, especially the skip tooth, without some curved support at the end of the belt's teeth, won't the belt try to make a straight line between each "rung" effectively changing the spacing, or is it not enough difference to worry about?
That, and of course simplicity in fabrication, is why I really like the idea of starting with a smooth pulley and using thin bolts or rod as the teeth right at the pulley's flat surface. Then the belt teeth still rest on the flat surface of the pulley and we can probably get away with skipping 3-4 teeth. Spacing and starting with the correct diameter pulley is still critical, but with the ability to skip most of the teeth, it could be even easier (and maybe better) than the epoxy method.
Users browsing this forum: comradegerry and 13 guests
