neptronix wrote:I run my 500w motor at 1500-1600w constant with no incident. It doesn't even get warm. No babying it, 5 mile hills, jackrabbit starts. I do pedal but only to increase my top speed to about 28-29mph or so.
DrkAngel wrote:At 500 watts, a 36v hub motor draws approximately 25 amps.
At 1500 watts, a 36v hub motor would draw approximately 75 amps.
That means that your Turnigy 20ah 36v pack would propel you for only 16 minutes, maybe 8 miles?
Your old 5ah Lipo, about 4 minutes, it could take you, less than, 2 miles.
If you are going to make stuff up ... try to be a little more realistic.
DrkAngel wrote:neptronix wrote:I run my 500w motor at 1500-1600w constant with no incident. It doesn't even get warm. No babying it, 5 mile hills, jackrabbit starts. I do pedal but only to increase my top speed to about 28-29mph or so.
stanz wrote:
Huh? Neptronix said he was running 41.4V, if he is pushing 1500W into his motor that means he's using 36.23 amps, not 75. W = V x A right?
I have pushed 837W through my 500W hub motor when my SLA pack was at 39 volts. If I was running more voltage I could provide more watts, my controller limits me to around 21 amps.
DrkAngel wrote:neptronix wrote:We run our hub motors at 2-10 times their watt rating on here, whereas you have to worry about an additional few hundred watts blowing your eZip motor.
That is crazy!
You are saying that you'all run your 36v hub motors at 72v - 360v!neptronix wrote:I run my 500w motor at 1500-1600w constant with no incident. It doesn't even get warm. No babying it, 5 mile hills, jackrabbit starts. I do pedal but only to increase my top speed to about 28-29mph or so.
So ... you run your 36v hub motor at 108v - 115v!!!
I do exactly the same speed with my 37v EZip!
Faster ... actually ... 30+MPH!
Either you have a very vivid imagination,
or you just don't have any idea what you are talking about!
gogo wrote:There is a couple in their 70's that live across the street from my parents in AZ. They ride their eZips all over and seem to love riding them.
Nehmo wrote:I now have the bike, but I didn't get the Currie SLA battery. I used 2 U1(lawnmower) 12Vs in series. It's heavy at 105 pounds. Where did you, DrkAngel, get the cheap Li batteries?
`~- Nehmo
Solcar wrote:DrkAngel wrote:vanilla ice wrote:I think you can use "SPORTS20" to get $55 off too. You have to use an Amazon credit card though. Coupon should be valid until June 15th.
Noisy motor, but if you don't mind the noise its pretty good otherwise.
True ... The 2008 model was noticeably noisy.
By comparison, the 2009 model was, nearly silent!
Hopefully, the newer models, improved, even more. ... ?
I am guessing that this is a clearance price, on the 2010 model.
I've read that adding a plastic spacer inside the gearbox can quiet it down a lot.
icecube57 wrote:
2-10 times their watt rating. Meaning a legal 750w kit Double that is 1500w. 10 times that is 7500w. In no way did he say anything about 100+ volts or 72-360 volts
icecube57 wrote:But from a stand still the motor will draw whatever the motor wants as long as the controller current limit isnt hit. In a stall situation or coming off the line the 9x7 motor will draw up to 130A max at 36v at that point the windings can no longer accept any amps because its being limited by the resistance of the windings.
icecube57 wrote:So the increase in amp does increase wattage output up to the limitation of the winding in extreme cases.
DrkAngel wrote:The only way to increase watt output on a hub motor is to increase the volt input!
Unless you rewind it?
Volts is pressure, higher pressure = more power.
Volts x Amps = Watts
You can't force in more amps unless you up the volts..
Hillhater wrote: Errr ? .. have you never heard of the controller limiting the amps ???
a simple change of controller can double the power output from some stock Ebikes.
DrkAngel wrote:...
You can't force in more amps unless you up the volts...
icecube57 wrote:I can post the results for a 5303 that will clearly show an upgrade in amps clearly increases output power...
Users browsing this forum: No registered users and 4 guests
