Build No. 2 - Reduction Drive - now w/ NEW video
Re: Build No. 2 - Reduction Drive - now w/ NEW video
Postby mauimart » Fri Dec 30, 2011 3:36 pm
I'm getting some strange behavior on the current reading from my cycle analyst. When I power up the device the current reading is close to zero as it should be yet when I enable the controller (Kelly) the current jumps to -1A or so. When I put my multimeter across the shunt the current reading falls back into line at about 200mA or so both on the CA and the meter. It seems that if I just have the positive lead of the multimeter connected to the the high side of the shunt or I simply touch the high side of the shunt the CA reads correctly. The "Set Range" parameter on the CA is set to Low (0.01A). Has anyone experience such behavior? Thanks.
mauimart
Postby Jay64 » Fri Dec 30, 2011 4:15 pm
mauimart wrote:Another freshly uploaded video of what I have now named "The Vortex". Must get more batteries so I can ride longer...
Man, that video brings back some memories. As little kids we used to charge down that road on our skateboards with long pipes for stability and then after college me and my buddy used to ride our motorcycles up and down that road all the time.
I think your CA question has something to do with trying to read regen or something. I vaguely remember something along those lines when I set mine up a few years ago. Hit up Justin, he would definitely be able to answer it for you.
Johnson64.Com "The stone age didn't end because we ran out of stones."
EV Bikes:
'13 Zero S 11.4kwh.
GS500, ME0913, Sevcon Size 6 Controller, 90v40ah Lipo, GSXR suspension..
'87 Hurricane 600, ME0709, 48v/50a SLA, Kelly KD72400, Magura Throttle, High Current Cycle Analyst.
http://www.evalbum.com/2275
Raleigh beach cruiser: 9C rear hub, stock controller, 48v10ah lithium, Cycle Analyst.
Phat Chopper: 9C front hub, stock controller, 48v12ah a123s, Cycle Analyst.
Jay64
1 GW
1 GW
Postby mauimart » Fri Dec 30, 2011 4:56 pm
Jay64 wrote:Man, that video brings back some memories. As little kids we used to charge down that road on our skateboards with long pipes for stability and then after college me and my buddy used to ride our motorcycles up and down that road all the time.
So that was you coming down the road at night with the full moon lighting your way and with pipe in tow. I remember looking out my window at night and seeing the sparks from the pipe. That's hilarious! The kids continue to do that now with their longboards but without the pipe. They haul-ass at crazy speeds often with no protective gear or helmets. Simply nuts.
Just found this vid:
http://www.youtube.com/watch?v=u4QW7dB2 ... er&list=UL
mauimart
Postby Jay64 » Fri Dec 30, 2011 5:31 pm
Yeah, we used to make it rain sparks. But I don't think the kids you saw was me. I was doing this about 30 years ago. :lol: :lol: Those kids are charging, our equipment was nothing like what they are using now.
After I watched that vid you posted I saw one of them charging on Poli Poli. That seems even more insane, rougher road with smaller lanes.
EV Bikes:
'13 Zero S 11.4kwh.
Jay64
1 GW
1 GW
Postby mauimart » Mon Jan 09, 2012 2:43 am
I changed the gearing on my bike by swapping out the 24T chain ring to a 30T chain ring for some added speed. I can also now pedal beyond 20MPH as a result. The overall gearing is as follows:
Motor to Jack Shaft --> 9T:54T
Jack Shaft to Bottom Bracket --> 14T:48T
Bottom Bracket to Rear Cassette --> 30T:32T (first gear); 30T:12T (7th gear)
Now I can climb 20% + grades and reach at least 35 MPH on the flats.
Here is a crappy video (thought the camera was pointed a bit closer to horizontal) with some stats recorded on the CA.
At 34 MPH climbing a roughly 2% grade I saw just under 2000W. I later did some steep off-road hill climbing (not on video) and recorded max power at about 4500W. Motor was warm to the touch and no noticeable increase in temp on the Kelly controller (see controller settings).
mauimart
Postby mauimart » Sun Jan 15, 2012 11:21 pm
Spent most of the day drilling holes. I must say that I am very pleased with the outcome. Looks a lot better and I saved a whopping 10 oz (255g) :D .
Before
First pass.
Almost there.
The result.
CAD
sprocket 3da.jpg (70.83 KiB) Viewed 977 times
mauimart
Postby motomoto » Mon Jan 16, 2012 12:48 am
Nice job on your build. I think that this is the best way to do the mid drive thing. A couple of reductions, and you
have all the gears in the back to match all the conditions. Uphill, downhill, it doesn't matter, you have the right
gear for the occasion.
motomoto
Postby Whiplash » Mon Jan 16, 2012 9:18 am
Exactly! !
Power is a fascinating thing, the more you have, the more you want, but the real power is having the restraint not to use it all at once...............Um...Yeah..
The harder you work.....The luckier you get!!
"People who say it can't be done are often interrupted by those that have already figured out how to do it!"
Email me @ currentcycles@gmail.com
OR check out http://www.CurrentCycles.net
Whiplash
Postby mauimart » Mon Jan 16, 2012 3:30 pm
motomoto wrote:Nice job on your build. I think that this is the best way to do the mid drive thing. A couple of reductions, and you
Whiplash wrote:Exactly! !
Indeed. This build is quite versatile:
Full suspension, albeit crappy stock shocks.
Full range of gears. I can effortlessly climb 15% grade without pedaling and reach 37 mph on the flats. I could probably do 40 mph if my shifter would get the chain on the smallest cog on the rear... I have still yet to sort out the shifting to get through all 8 gears.
I can pedal upwards of 20 mph with reasonable cadence because of the low kV wind on the motor.
One of the things I don't like is that with the 3 chains and 2 freewheels in the setup, there if quite a bit of slack or play between motor spinning and back wheel spinning. I measured it to be half a revolution of the motor to pick up all the slack in the chains and freewheels. This causes significant lag when applying power and makes for somewhat jerky performance when under small loads.
In the mean time I would like to upgrade the front fork to something better. Does anyone have any recommendations (brand and source) for a decent shock that works well for light to moderate off-road use, and will not break the bank????
mauimart
Incredible build Mai. Fantastic.
Postby Uteanooga » Mon Jan 16, 2012 10:22 pm
:D
Uteanooga
Postby mauimart » Mon Jan 23, 2012 3:18 am
Just swapped out the Kelly for a cheap Hual Tong controller for some testing. Details at this thread:
viewtopic.php?f=2&t=29469&start=585
mauimart
Postby mauimart » Mon Jan 30, 2012 4:12 am
Some improvements to the build over the weekend:
After testing the modded Hua Tong 38A/72V controller I decided to abandon it as it provided violent surges at about 25% throttle threshold- very jumpy to say the least and if I was not expecting it would have thrown me off the back. I was able to get over 2000W continuous and 2900W peak from it once it settled in at WOT. Anyway I ditched the seat post controller mount and moved the Kelly controller into the battery box. I also added a 50A fuse.
Hua Tong Test video:
Hua Tong on its way in battery box.
AGU 50A Fuse
(186.97 KiB) Downloaded 4 times
Kelly in with batteries.
(243.77 KiB) Downloaded 4 times
No more seat post rack.
Other side.
mauimart
Postby mauimart » Wed Apr 11, 2012 3:27 am
Here's a brief update on the project:
I decided on the generic 20C lipos instead of the nano-techs. Based on the higher cost of the nano's and the fact that I would rarely exceed 8C the 20C cells made the most sense. So I have 6 pieces of the 6S/5Ah bricks configures as a 18S/10Ah pack. Full-up bike weight is 65lbs. I seem to have one cell in one of the bricks that is not 'playing nice' and it looks like I'll be returning that one to Hobby King.
I have been riding the bike almost daily and my normal commute consists of a 7 mile climb of approx 1700 feet elevation gain. I do a fair amount of pedal assist and end up spending just over 4Ah or 300Wh on average. The deepest discharge to date was 7.1Ah or 490Wh with an Amax of 77A (all according to the CA). I have not exceeded a motor temp of 100C at this point yet I think I could easily do this with no pedal assist and a heavy throttle. My guess it that I can sustain approx. 2000W input power without the motor reaching critical temperatures. I have also verified that the motor can take 5000W input power for short bursts. I am amazed at the power output of this tiny motor yet not surprised that it struggles to dissipate the heat. I have some future plans to do some testing on flatter terrain to see how it performs. The current gearing allows me to hit 38mph. My goal is to change the gearing, at least temporarily, to see if I can hit 50mph on the flats with this setup. I think it may be in the cards. I also have a stock wound motor with a significantly higher kv that would get me there assuming the Kelly could handle it. Has anyone hit 50mph with the C80-100 outrunner?
The best part of riding this bike is letting cars pass you and then accelerating and hanging on their tail. The double-takes in the rear view mirror are priceless...
Martin
Wire Harness
Charged Pack Ready for Install
Lots of Wires - Put the cover on so no one sees them...
Contoller Wired and Ready for Install
Stinker
mauimart
Postby mauimart » Mon Apr 23, 2012 2:46 am
Thouht I'd try for a 50 mph run today so I removed the crank and replaced the 30T chainring with 44T. Theoretical max speed would be 53mph. I charged up the Lipo to 4.2V/cell to get every ounce of power and energy - I normally charge to 5.15V/cell. Hooked up the DIY arduino-based Cycle Analyst data logger and the arduino GPS logger. I then took the bike out to the nearest flat stretch of road I could find (12 feet of decline in 1/4 mile according to google earth) and with a slight cross wind I hit 50mph according to the CA. Unfortunately I forgot to insert the SD card into the GPS logger so no gps confirmation at this point. I was on my fourth attempt when the fuse blew (50A AGU). I will upgrade to a 80A fuse, dial up the controller to 11, and try another time. I may even have to strap on the stock wound, 130kV C80100 as I have run out of gears. That motor will most likely fry my controller so maybe not. This bike really has no business going over 40 mph anyway. Oh well... For now, here is some data.
44T Big Bertha
Instrumentation
High-tech mounting
The data (hi-res)
(110.83 KiB) Downloaded 4 times
Speed run plot
mauimart
Postby mauimart » Thu Jun 07, 2012 3:06 am
Update:
I went for a 36 mile ride the other day and on the way back my C80100 "threw" a bearing. Needless to say I was in limp-home mode for the last 5 miles.
Here's the carnage:
Busted Bearing
After I replaced the bearing I thought I would do a little more work on the bike. I added a chain tensioner to the first stage reduction - long overdue. I used the nylon wheel from a screen door roller as the tensioner and it works ok. Eventually I would like to use some sort of roller with a bearing in it to reduce friction and noise. Here's a brief video of the tensioner in action.
I then noticed an old bike that's been sitting dormant since when my son was young and I decided to replace my 26" back wheel with the 24" from the kids bike. Here is the result:
24" Rear Wheel
Other side
I think it looks bad-ass. A quick power test was now in order, just to make sure everything was "operational". Here's what a front tire slick with 60 psi will get you when riding in loose gravel.
Road rash
Video of crash to follow...
mauimart
Postby mauimart » Thu Jun 07, 2012 12:51 pm
Here is the crash video. The only damage to the bike was a busted pedal.
mauimart
Postby bzhwindtalker » Thu Jun 07, 2012 2:41 pm
That thing seems to push! Apart form you wearing a hawaian shirt and no helmet, the crash was kinda lame haha, I crash like that 2-3 times per ride ;)
bzhwindtalker
Postby mauimart » Sat Jun 23, 2012 11:54 pm
Some updates to the bike:
New set of Vuelta wheels with hubs for disk brakes.
Avid Elixir 3 hydraulic disc brakes.
SRAM X7 Shifter
SRAM X9 Derailleur
SRAM 9-speed cassette (11-34)
SRAM chain
Hinged battery box cover with magnet latching.
All that's missing now is a fork upgrade....
mauimart
Postby mauimart » Sat Jul 07, 2012 8:50 pm
Here's a new video shot entirely on my new RD32II ($119 US) in 1080P/30fsp. I'm quite satisfied with its performance thus far.
EDIT: Version that will play on mobile devices: http://www.youtube.com/watch?v=agWOH5dl9VQ
Here's how I mounted it to the bike. The v-brake bosses made for convenient attach points.
mauimart
Postby mauimart » Fri Jul 20, 2012 1:26 am
With my recent upgrade of shifting components, I can now shift under WOT. Sounds a bit like an F1 car, at a lower frequency of course... :D
mauimart
Postby h0tr0d » Tue Jul 24, 2012 8:17 am
How wide is your alu box?
And how that in terms of pedalling comfort?
Great build and vids!!
Congrats!
Thank you Justin! Life is so much sweeter with this forum... ;)
Making a C120-110 RC motor, 20 kW
Scott Gambler, 150 km/h objective, wish me luck!
h0tr0d
Postby mauimart » Wed Jul 25, 2012 5:29 pm
The width of the battery box is right around 17cm (6.7 in). I made it that width to comfortably hold 3-wide of the Turnigy 6S 5000mAh packs. I do quite a bit of pedaling on this bike and have had no issues with the battery box getting in the way (no chafing). I did add a longer spindle (158mm IIRC) in the bottom bracket to allow for clearance between the crank and the reduction gears on the jack shaft.
I am currently in the process of upgrading to a 'real' suspension fork. Pictures when done...
mauimart
Postby crossbreak » Thu Jul 26, 2012 8:51 am
nice bike and vids! the setup reminds me of my first build, which is disassembled cause it drew my bat empty in minutes :D. thanks for posting this stuff!
i hope your sprocket cassette holds up longer than mine. I used a shimano 9-speed cassette 32T-11T with shimano chain on my 1000W middrive test setup. It holded up for about 300km till the 11T sprocket started to slip. The 12T slipped followed 600km later, then I bought a 9-speed SRAM gear hub. It holds up well (about 1500km-2000km yet, my odo sadly was reset).
I hope you have an odometer on your bike. Could you be so keen to keep an eye on how many miles your cassette/chain survives under these circumstances? I plan for another bike with derailleur, that's why I ask. I plan to only use 13T and larger because of my bad experiences. Maybe your SRAM cassette is better quality?
I bought a RST Peak 130mm fork at the bay for 40 bucks a year ago, the oil damper of the forks works really sensitive and adjustable at a wide ratio. I'm very content about it, didn't expect that. It's a bit more heavy then the expensive forks but almost impossible to break. I can only recommend.
My first hub conversion middrive (decommissioned): http://endless-sphere.com/forums/viewtopic.php?f=3&t=34146#p495887
. . . Why not, make something that lasts?
crossbreak
Postby pff7 » Thu Jul 26, 2012 1:50 pm
Love it, love it!!!! so nice----by the looks of it seems like it would pedal just like a regular bike w/o power? Excluding weight of motor, drivetrain,battery,ect. seems your freewheel would make the bike pedal just normally, am I right?
pff7
Postby mauimart » Thu Jul 26, 2012 2:01 pm
I actually worry more about the chain (crank to cassette) failing as it's not designed for these loads. Hopefully the SRAM cassette proves better than what you experienced with the shimano. Most of the time I try to keep the acceleration levels low so as not to over stress the already over stressed components. I always pedal first when starting. I also rarely use the 11T - only when doing speed runs and I need to exceed 45mph. Although none of these precautions has prevented me from getting 100A peaks on the CA.
I do keep records (dist, Ah, Whr, etc.) of each trip and I might post some data once I have a few more cycles on the bike. For the most part I am only keeping track of mileage when the bike is powered by the motor. My morning commute is all downhill so I don't even turn anything on, including the CA.
mauimart
PreviousNext
Who is online
Users browsing this forum: competitions, kifukarider, kudos and 8 guests
