Belt driven off road bike (Giant Reign)
Re: Belt driven off road bike (Giant Reign)
Postby 1000w » Mon Feb 06, 2012 11:59 pm
GITech wrote:I wonder what can be done for ventalation of that motor?
I was thinking the same thing, however I think I will leave it as is and see how it all goes.
etard wrote:I pray for your swingarm survival, those little loops for the bottom pivot scare me the most.
How come the loops worry you? They are unmodified.
AussieJester wrote: I seriously doubt the strength of the extensions will be an issue
its that over engineered...
Cheers Kim, I hope you are right.
If putting this rear end in the oven on high for 7 hours will help strengthen it up, I will do it.
I need to find more info on normalising Aluxx SL aluminium. I found this in a search "AluxX SL starts with a 6061 alloy but mixes in a trace amount of copper to form a stiffer alloy"
1000w
Postby carl2.0 » Tue Feb 07, 2012 2:46 pm
Wow great mechanical design n craftsmanship. I NEED to see the finished product !
48v Kawaski zx600 :109 ft-lb, geared to 72KPH **
http://endless-sphere.com/forums/viewtopic.php?f=10&t=28479
Project PIWI- Vintage Styled Electric Bicycle
http://endless-sphere.com/forums/viewtopic.php?t=33720
carl2.0
Postby 1000w » Tue May 22, 2012 11:52 pm
Ok this has been on the back burner for quite a while.
I just got the rear triangle back from the powder coaters, done in satin black.
I have done a quick assembly to see how it will look. The next stage is to mount the battery and controller and make a cover for them out of lexan.
1000w
Postby hillzofvalp » Wed May 23, 2012 12:26 am
That is pretty. How much does it weigh at this point?
hillzofvalp
Postby 1000w » Wed May 23, 2012 12:59 am
hillzofvalp wrote:That is pretty. How much does it weigh at this point?
Cheers hillzo, it's19kg as is.
1000w
Postby sn0wchyld » Wed May 23, 2012 1:26 am
HA thats looking good mate! and pretty light too! I forget, but was this one going to be pedal-able?
Got questions? hit up the wiki!
http://www.endless-sphere.com/w/index.php/Main_Page
My builds:
http://endless-sphere.com/forums/viewtopic.php?f=3&t=29373
Norko Aline Park DH - Clyte HT3525 - 24s lipo
http://endless-sphere.com/forums/viewtopic.php?f=28&t=33657&p=534823#p534823
'02ish Avanti D8 - 8085 170kv - 5s 40ah lipo - ple80 recution
abject failure in september
http://endless-sphere.com/forums/viewtopic.php?f=12&t=43143
RC driven Electric mountainboard - New vids up!
sn0wchyld
Postby 1000w » Wed May 23, 2012 5:30 am
sn0wchyld wrote: I forget, but was this one going to be pedal-able?
No pedals are planned at this point, it will be my off road bike.
1000w
Postby voicecoils » Wed May 23, 2012 5:46 am
Damn. Somehow you've managed to make 20" wheels on a full susser look good! Congrats 8)
Looks like it will be a fun ride & a wheelie machine!
voicecoils
Postby sico » Wed May 23, 2012 8:13 am
Its looking great mate and should be a plush ride. :)
That pully looks a bit vulnerable in case of a right side down dumping, but I guess that will never happen :wink:
Simon
sico
Postby 1000w » Fri May 25, 2012 12:36 am
Cheers guys.
Here are those pedals, well, lets call them foot pegs.
I welded a bottom bracket cup and the threaded end of a steel crank to a 80mm length of 38mm stainless tube.
1000w
Postby AussieJester » Fri May 25, 2012 2:38 am
Nice work Matt, i been holidaying in Bali just got back beginning of week... Shall
give you a buzz over the weekend..
Keep up the good work...
KiM
AussieJester
Postby Danny Mayes » Tue May 29, 2012 5:48 am
That looks very cool Mat, i like it.
Can't wait to see it going.
D
Unlike puppets we have the possibility of stopping in our movements,
looking up and perceiving the machinery by which we have been moved. In this
act lies the first steps towards freedom.
- PETER BERGER Sociologist
Danny Mayes
Postby 1000w » Tue Jun 05, 2012 12:28 am
I've made some progress with the battery and controller mounting. I'm using the same lexan material and set up that I used on my Giant NRS build.
1000w
Postby dnmun » Tue Jun 05, 2012 3:02 am
wow. too original. so sweet, luxomatic ride.
dnmun
Postby AussieJester » Tue Jun 05, 2012 4:20 am
pimpin' Matt ... Bring her around for a closer inspection please tehehe
Spoke to Tony yesterday, called me about frame, told him 2 weeks and its his
so i have to get my ass into gear and strip the 2 speed cruiser and get the new frame made :: gulp ::
Lookin forward to seeing this rip buddy ;-)
KiM
AussieJester
Postby 1000w » Fri Jun 15, 2012 12:22 am
I have basically finished the battery box now, other than covering it with the carbon fibre vinyl which should be in the post.
The box appears fairly large however it all feels fine between my legs, not too wide.
1000w
Postby AussieJester » Fri Jun 15, 2012 11:09 pm
When the CF is on she will look the business...really looking forward to seeing her rip, turn the juice up on that 24Fet and the EV grin well be HUUUUUGE.... LOL
KiM
AussieJester
Postby 1000w » Thu Jul 12, 2012 10:14 am
I have now got this bike running, well thrown together, so I can test the belt drive and idler pulleys.
The original set up with an idler on both sides of the belt proved to be no good. I couldn't get the belt to track correctly and stay on the drive pulley so the tension side(top) pulley had to go.
So I had this.
And now I have this.
This involved some more modification to the top chain stay so I could get a straight belt line.
Some material removal.
And some material addition, this is some 6mm plate shaped to fit inside the chain stay.
Plate inside the chain stay.
This is welded in and partly ground smooth, still a little rough here.
I decide to add some material to the outside as well, this is 4mm plate bent 90 deg and shaped.
Then welded up.
Now I have a straight belt line.
This is how it all looks in testing mode.
Now how does a Cyclone 3000watt motor go on 66volts and 100amps?
Unbelievable! This thing is a monster at 6500watts. The front wheel was lifting just with throttle ie with no help from me pulling back.
Loads of torque, it doesn't seem to slow down on hills and the speed is right where I calculated, 50kmh or just over, I'll put a speedo on soon.
I have only ridden it for about 10min tonight so I still have some small things to sort out, but it gave me a sizeable EV grin.
Cheers,
1000w
Postby grindz145 » Thu Jul 12, 2012 11:18 am
Sick! Nice job!
Where do you source your belt-drive components? (minus the custom giant sprocket :)
http://www.endless-sphere.com/forums/viewtopic.php?f=18&t=19548 - Ebike Nerd Podcast
Thanks to Justin @ ebikes.ca! Go there, buy stuff. Support the Revolution :D
grindz145
Postby 1000w » Thu Jul 12, 2012 7:05 pm
grindz145 wrote:Sick! Nice job!
From here: https://sdp-si.com/eStore/
Cheers,
1000w
Postby grindz145 » Thu Jul 12, 2012 7:08 pm
Sweet thanks!
grindz145
Postby boostjuice » Mon Jul 16, 2012 11:05 pm
1000w wrote:Now how does a Cyclone 3000watt motor go on 66volts and 100amps?
Cheers,
This is all very exciting! Im curious to know the saturation point for these motors (and whether or not you've surpassed it), as well as what sort of power bursts you find the motor can handle repetitively though a full battery's worth of technical trail riding (safe thermal equilibrium point)
BTW, Nicely resolved dropout clearance issue... alu welding certainly opens up possibilities. should be more efficient too. Beaut job!
boostjuice
Postby bzhwindtalker » Tue Jul 17, 2012 12:55 pm
I like this bike!
This motor sure looks interesting, plenty of power to boot and rugged build. Testing it to destruction for us? :)
I see you did a motorcycle type brake levers setup, should be standard on all wheelie prone bikes :roll:
bzhwindtalker
Postby Tommy L » Thu Apr 18, 2013 6:15 am
Sweeeeeeeeet!
Tommy L sends......Image
http://www.rawvelocity.com
- 4th Hoolagan FS Mtn 9C-2810 with 128v nom 9.2ah A123 40S40P(1.2Kw) - Lyen 18Fet 4115 - 77.8kph :)
viewtopic.php?f=4&t=39480
- 3rd Catrike 700 Bionx PL350 Velo build
http://www.youtube.com/watch?v=rYdnkaAhVtI
- 2nd 150lbs Pusher Trailer
http://www.youtube.com/watch?v=Q1qTc4sjORY
- 1st Sears NS mtn bike - Rigid 10a drill 800rpm - 2 12v AGM - 1000 watt inverter - 600w dimmer for throttle, wicked torque!
48.2mph/77.8kph Club
Tommy L
Postby waynebergman » Fri Apr 19, 2013 12:07 am
Can you tell me please where you got the wheels and tires? ......they look real nice!
Are they intended for trials?
How much for the rims and tires do you remember?
Thanks Wayne
Link to first build Giant DH-------- viewtopic.php?f=3&t=33849
Mid Drive work in progress--------- viewtopic.php?f=28&t=49467
waynebergman
PreviousNext
Who is online
Users browsing this forum: j3tch1u and 9 guests
