Luke's commuter bicycle. What Non-hub is all about.
Re: Luke's commuter bicycle. What Non-hub is all about.
Postby liveforphysics » Thu Dec 15, 2011 2:27 am
RWP wrote:I found some individual encoder chips on line.
Is it a trivial thing to mount them like we do hall's, or is this not possible?
OH...a $50 encoder...good enough!
You gotta drill a pocket into the back of the motor shaft for the encoder magnet to get glued in. Then just some structure you can afix the encoder package to sit over that magnet. Then you need to clock the encoder to be aligned properly, which requires an o-scope tinkering. Then you make sure you've got which is which for sine/cosine sorted out, send that to the sevcon's encoder input, and you're ready to begin configuring the sensor to the controller and start dyno tuning.
For ebike parts, don't be a douche, buy from http://www.ebikes.ca or http://www.MethTek.com
Justin saved the forum at great personal expense! The man is a legend and a hero!
liveforphysics
Postby Kiwi » Thu Dec 15, 2011 2:31 am
have you got a NZ guy working with you, thought I caught a kiwi accent in the video?
Its great to see an electric bike with some power that doesn't leave you yawning.
Nice work.
Kiwi
Postby RWP » Thu Dec 15, 2011 2:41 am
Thanks Luke - You da MAN for your manly bike!!! :mrgreen:
OK then...is the encoder signal anything like a hall signal that would connect to a controller that is more common to what we are currently using?
Guess I am trying to find a way for a mere mortal to do this :roll:
My electric vehicle projects Home of the eTownie & eCortina
Cortina V3 Turnigy 80x - HV 160 - 48v 15Ah
Cortina Revisited Turnigy 80x - HV 160 - 48v 15Ah
Cortina Hard Tail Build Cortina Triton DS - eFlite 160 - 36v 10Ah LiPo - TURNIGY K-Force 120A-HV - Nexus 3 speed internal hub
RWP
Postby amberwolf » Thu Dec 15, 2011 3:39 am
RWP wrote:OK then...is the encoder signal anything like a hall signal that would connect to a controller that is more common to what we are currently using?
No, not if you're talking about common ebike controllers like the Infineon/Lyen/Crystalyte/Ecrazyman/XieChang stuff; that's the problem I am asking about in my post on the previous page and in my powerchair thread. ;)
You'd have to convert the sin/cos into the hall-per-phase types those are expecting. Can be done with either analog electronics or with an MCU and some programming, but it won't give you the resolving power of directly using the sin/cos signals, AFAIK--you're still limited to whatever the controller itself accepts for input. It does let you use encoding outside the hot motor, at least (but really, you could do that with the regular halls, too, if you add a second set of magnets just for the halls to detect. Or you could use optical sensors to do the same job the halls did, and a light/dark ring in the pattern of the magnets).
House Fire Updates Thread
http://endless-sphere.com/w
DayGlo Avenger, MkII
amberwolf
Postby Spacey » Thu Dec 15, 2011 4:08 am
Luke that bike is awesome, damn your making me want to get rid of my frock motor on my Greyborg now lol
Spacey
Postby jingles98 » Thu Dec 15, 2011 4:39 am
I think we've all updated our Christmas list for one of these bikes Luke. Like i said before mate, you are a God.
jingles98
Postby gensem » Thu Dec 15, 2011 9:32 am
How much thrust this thing puts on the ground?
300 pounds?
A decent 25mph bike will cost around $1000.
A decent 35mph bike will cost around $2000.
A $1000 35mph bike will get you killed.
Justin we really appreciate what you did!
gensem
Postby Jozzer » Thu Dec 15, 2011 12:22 pm
:mrgreen:
Mazda MX-5. 300KW power. Soliton 1 controller, 11" Kostov motor, 20KW/H Turnigy Lipo for 60-100 miles range. 120mph top speed.
Hudson Kindred Spirit 3 wheeler. Twin Agni setup, 300KG 80KW. 100mph top speed (maybe more, but no-one has the guts to try!)
Aprilia RS125, Agni motor, 600A 96v Kelly controller, 6kw/h Turnigy pack.
www.Jozztek.com
Jozzer
Postby liveforphysics » Thu Dec 15, 2011 12:27 pm
Jozzer wrote::mrgreen:
Thanks Jozz. I always value you work and input.
liveforphysics
Postby Whiplash » Thu Dec 15, 2011 3:23 pm
Hey Luke,
just a crazy question, what would you need to get to setup a drive system like this, say if one of us sent you the motor/controller and had you set it up similarly? I would LOVE to build a frame and just be able to slap a drive into it like this!!
Power is a fascinating thing, the more you have, the more you want, but the real power is having the restraint not to use it all at once...............Um...Yeah..
The harder you work.....The luckier you get!!
"People who say it can't be done are often interrupted by those that have already figured out how to do it!"
Email me @ currentcycles@gmail.com
OR check out http://www.CurrentCycles.net
Whiplash
Postby liveforphysics » Thu Dec 15, 2011 3:39 pm
Whiplash wrote:Hey Luke,
Its just too much time. Hundreds in labor to do the machineing to mount the sine/cosine, hours of time on the scope and dyno. I couldn't do it cheaply, and the parts cost is high all ready.
liveforphysics
Postby Ypedal » Thu Dec 15, 2011 3:39 pm
I think u should have to earn this the hard way!
ES site status page, for when "things" happen...
Always Staying Busy !!
http://www.ypedal.com/Projects.htm
Ypedal
Postby Whiplash » Thu Dec 15, 2011 3:49 pm
Ypedal wrote:I think u should have to earn this the hard way!
Awe, coome oooon! LOL! I want it the easy way! :D
Thanks anyway Luke! I figured as much but I thought I would ask...
Whiplash
Postby liveforphysics » Thu Dec 15, 2011 5:00 pm
My ticket price to get here was around $10,000usd in parts turned to smoke. That includes ~$2,000usd in wasting my time with RC controllers alone, never having something that lasts more than a couple of minutes of my riding. Then going to bigger ebike controllers, of which, the only ones I never killed were the original hand-built Method's controllers, but my quest for power went beyond there limits. Smoked a number of motors that cost over $1,000usd each along the way, went from brushless to brushed, and then back to brushless. Went from 5lbs motors to 15lbs motors to 25lbs motors, each time finding that while the POWER could be similar, the LIFESPAN and DURABILITY just increases directly with the size of the things. I could achieve the same performance with a motor 1/5th the size, but I've all ready played that game more than anyone else, and it just ends in fickle designs that constantly break and smoke.
In the end, the simplicity and durability is just worth it to carry an extra 10-15lbs of motor around.
liveforphysics
Postby gor. » Thu Dec 15, 2011 5:46 pm
Luke, why such strange choice of motors? Agni - twice more powerful and much lighter - 11kg vs. Golden 17 kg; rpm range about the same
- to test encoder?
gor.
Postby liveforphysics » Thu Dec 15, 2011 6:02 pm
gor. wrote:Luke, why such strange choice of motors? Agni - twice more powerful and much lighter - 11kg vs. Golden 17 kg; rpm range about the same
- to test encoder? or price-vise?
I have plenty of Agni motors, including silver-brush fitted custom motors, and motors setup and tuned by Cedric himself, and made a couple of Agni bikes. This is simply more power than an Agni is able to achieve, and this is coming from a guy who has run them on 120v with a 1200amp controller and Cedric Lynch doing the dyno tuning himself.
This is the creator of the Agni motor, Cedric Lynch, personally helping me setup my BLDC motor harness. :-) Cedric is such an awesome and unique guy, I have nothing but love, respect, and awe for the man. If he gets a motor to me that can put down more power than what I'm currently laying down without melting in 10seconds, I will very happily swap over to it in a second.
One of my early Agni bikes in action:
liveforphysics
Postby Alan B » Thu Dec 15, 2011 7:09 pm
I see my video is doing well there (the first "launch" video). I have a bunch of hi resolution stills from the Marin trip I should get to you sometime.
Alan B
1.21 GW
1.21 GW
Postby Kurt » Thu Dec 15, 2011 7:31 pm
Luke,
when you get that new smart phone you posted about. I would love to see some G readings and perhaps some acceleration times 0 - 60. There is a ton of free Programs available for smart phones.
Usually loud bikes-cars give the sensation of speed and the quite smooth ones look slow even if they are fast. Your bike is dead quiet and still looks dam fast on camera so must be FAST!
Making the torque at the motor and keeping the gearing Simple is the way to go. It sounds so smooth and quite with just enough zing to remind you its a beast :D .
Well done
ps, Not to take anything away from your home made bike. But I wonder how that motor-controller combo would go in a 125 - 250 modern light weight aluminium sports bike frame - stripped down? That way you get the frame geometry, tyre selection , brakes and suspension package designed to handle the power. Not to mention it would look nice to . You could most likely fit more battery in the frame to. Yes it would become a motor bike and I understand the benefits of keeping it as a peddle bike but for people looking for a light weight E motorbike it looks like a good option.
Kurt
Kurt
Postby liveforphysics » Thu Dec 15, 2011 7:47 pm
You end up with a TTXGP bike, but you also enable the ability to melt your motor down from sustained high speed aero loads that seldom occur in practice on a bicycle. :-)
liveforphysics
Postby mr.electric » Thu Dec 15, 2011 8:07 pm
Luke,
Do you have an opinion of the stock golden motor controller for use in a low -mid power set up
http://www.goldenmotor.com/Dimensions-300A.jpg
I imagine it uses hall sensors that come installed in the golden motor.
-Fat Sand Bike with 9c and 29ah pack
-Giants mascot scooter
mr.electric
Postby Kurt » Thu Dec 15, 2011 8:08 pm
I guess it just goes to show one advantage of ICE is. Sustained hi power handling.
Kurt
Kurt
Postby liveforphysics » Thu Dec 15, 2011 8:48 pm
mr.electric wrote:Luke,
I've got one. It's 6x6 of TO220 package fets (36 fets), with a good layout and good power busing. Crappy caps, and sadly, the control firmware is glitchy and they occasionally just explode.
The Sevcon on this bike is 16 x 6 fets (96 fets), and it's rock solid an reliable, ONCE TUNED. It's like a death in the family to get tuned, it's going to leave you with a week of frowning and restless sleep, and thousands of dollars in labor with an expert dyno tuning your setup to get it to operate. Once you have it operational, it's like stepping into heaven everytime you operate the vehicle.
Which is like exactly backwards of a Kelly, which takes about 20minutes to get everything hooked up and adjusted and tuned, followed by a lifetime of hating all it's glitchy crap performance, ending in it's death at some random moment when you need it most.
liveforphysics
Postby Kiwi » Thu Dec 15, 2011 9:22 pm
I haven't laughed out loud for a while, but the first scene cracked me up.
Nothing like a validating a disclaimer.
..."you know this bike is dangerous"...."yes".....
Kiwi
Postby mr.electric » Thu Dec 15, 2011 9:24 pm
Wow good explanation.
I just heard the Golden motor and mars motor are almost exactly the same.
I also heard the mars motor will have an encoder version very soon, some samples already shipped.
Since mars and golden are in direct competition golden will probably come with an encoder sooner or later as well.
If one person figured out the settings for a certain model golden motor with a certain model sevcon would the setting work for another identical motor controller combo?
mr.electric
Postby voicecoils » Thu Dec 15, 2011 9:26 pm
gor. wrote:Luke, why such strange choice of motors? Agni - twice more powerful and much lighter - 11kg vs. Golden 17 kg; rpm range about the same ...
Nice to see your bike continue to evolve, looks like heaps of fun! Precise motor control over full RPM range and any motor loading seems to still be just out of reach for most of us.
Can you recap your dyno results for the HPM-10KW and Agni 95R? What peak and continuous power outputs are realistically achievable?
Jozz has posted some preliminary dyno results for the Agni 111RDR and thinks 15kW cont. output will be possible. I wonder if it could meet the performance you're getting from your current setup. They weigh 11.9kg, a bit more then the 95R due to thicker magnets. For high power ebikes (or low power e-motos) brushed motor setups still offer appealing simplicity for DIY builders.
Any thoughts?
voicecoils
PreviousNext
Who is online
Users browsing this forum: acn49, kunting and 3 guests
