damonjackson_spl wrote:Great sounding product but the most important aspect that seems to be missed is the price. Your volume could exponentially grow to massive production if you made a product better than cyclone but not as exxy as ecospeed or ego.
Still seems like a boutique type drive, need something around $800-$1000
With lower power can't you go cheaper and smaller belts?
sn0wchyld wrote:cant wait to see some pics, i'd be very interested in the reduction only product if not the whole kit at a later date... you already know matt that im starting my own mid drive build, but depending on my success in that this could be a good alternative for future builds.
any chance we can see the design pics, at least to get a better idea on how it mounts to the bike? i'd be interested to know if I could fit it on my aline...
recumpence wrote:sn0wchyld wrote:cant wait to see some pics, i'd be very interested in the reduction only product if not the whole kit at a later date... you already know matt that im starting my own mid drive build, but depending on my success in that this could be a good alternative for future builds.
Actually, I don't have any pictures of the frame mount that I can show. However, I can describe it for you;
It will consist (in a very basic sence) of two 3/16" thick plates that will capture the bottom bracket on each side. Those plates will capture a 5/8" thick aluminum plate between them. That plate will be retained to the frame downtube with a stainless strap (possibly a high quality hose clamp such as used on tubo kits). The drive unit, itself, will recess into a large slot in the center of that thick plate and will be able to slide forward or backward for chain adjustment.
Yes, I will be open to selling individual parts. However, right now I am very focussed on finishing the innitial prototyping as well as production. Some parts do not require prototyping and can go directly into production. Some parts are already produced and a couple need to be prototyped first. However, this system is much further along than that may make it sound. I have been designing and doing all research on this for some time now. I am quite confident that there will not be any major hickups. I have a couple concerns that I need to do some prototyping to figure out. But, nothing major.
This system is the culmination of all of the work I have done so far. I am opening up all of my bag of tricks for this. It is taking all of my knowledge to work this out, not because it is complicated, but because I am trying to simplify an otherwise complicated system.
Production and prototyping are moving faster than I originally thought. I will have something decent to show in 3 to 4 weeks with production in about 2 months at this point.
Matt
recumpence wrote:#4 The freewheeling crank. This is one thing I am really excited about! It will use a second support bearing to eliminate the overloaded freewheel bearing issue that is so common with freewheeling cranks. It will also use standard 130mm BCD chainrings for multiple ratio options. I am very excited to have come up with a solution to the FW crank bearing issue. I am not the first to do this, but I think it is the first to be readily available. My system will come with this new FW crank system and a new lengthened bottom bracket.
johnrobholmes wrote:It will be made to work, because my Pugsley is getting a kit too!
Users browsing this forum: DrkAngel, kifukarider, mabman, RustySpokes and 5 guests
