For those wanting a lower cost, lower power, higher weight solution- I have a feeling Matt could put a kit together once the drives are tested. Next time we talk I have a really good idea for you, Matt
recumpence wrote:sn0wchyld wrote:cant wait to see some pics, i'd be very interested in the reduction only product if not the whole kit at a later date... you already know matt that im starting my own mid drive build, but depending on my success in that this could be a good alternative for future builds.
any chance we can see the design pics, at least to get a better idea on how it mounts to the bike? i'd be interested to know if I could fit it on my aline...
Actually, I don't have any pictures of the frame mount that I can show. However, I can describe it for you;
It will consist (in a very basic sence) of two 3/16" thick plates that will capture the bottom bracket on each side. Those plates will capture a 5/8" thick aluminum plate between them. That plate will be retained to the frame downtube with a stainless strap (possibly a high quality hose clamp such as used on tubo kits). The drive unit, itself, will recess into a large slot in the center of that thick plate and will be able to slide forward or backward for chain adjustment.
Yes, I will be open to selling individual parts. However, right now I am very focussed on finishing the innitial prototyping as well as production. Some parts do not require prototyping and can go directly into production. Some parts are already produced and a couple need to be prototyped first. However, this system is much further along than that may make it sound. I have been designing and doing all research on this for some time now. I am quite confident that there will not be any major hickups. I have a couple concerns that I need to do some prototyping to figure out. But, nothing major.
This system is the culmination of all of the work I have done so far. I am opening up all of my bag of tricks for this. It is taking all of my knowledge to work this out, not because it is complicated, but because I am trying to simplify an otherwise complicated system.
Production and prototyping are moving faster than I originally thought. I will have something decent to show in 3 to 4 weeks with production in about 2 months at this point.
Matt
recumpence wrote:#4 The freewheeling crank. This is one thing I am really excited about! It will use a second support bearing to eliminate the overloaded freewheel bearing issue that is so common with freewheeling cranks. It will also use standard 130mm BCD chainrings for multiple ratio options. I am very excited to have come up with a solution to the FW crank bearing issue. I am not the first to do this, but I think it is the first to be readily available. My system will come with this new FW crank system and a new lengthened bottom bracket.
johnrobholmes wrote:It will be made to work, because my Pugsley is getting a kit too!
recumpence wrote:#4 The freewheeling crank. This is one thing I am really excited about! It will use a second support bearing to eliminate the overloaded freewheel bearing issue that is so common with freewheeling cranks. It will also use standard 130mm BCD chainrings for multiple ratio options. I am very excited to have come up with a solution to the FW crank bearing issue. I am not the first to do this, but I think it is the first to be readily available. My system will come with this new FW crank system and a new lengthened bottom bracket.recumpence wrote:freewheeling crank is crank arms, bottom bracket, spindle, retainer, spacer, bearing, sprocket adaptor, White Industries freewheel, two chainrings, bolts, etc.
johnrobholmes wrote:What a trick way to incorporate the mounting foot into a tensioning device!
deVries wrote:johnrobholmes wrote:What a trick way to incorporate the mounting foot into a tensioning device!
Even more trick is how to get chain alignment?![]()
Do you see and understand how it can move laterally to get chain-line alignment?![]()
Use spacers or is there a tracking slot to move it?
recumpence wrote:Lateral adjustment for sprocket alignment is accomplished by loostening the mount foot clamping screws and sliding the whole jackshaft bearing tube left or right in the assembly.... the bearing tube will be about an inch longer than (the drive foot and motor plate). For chain alignment, the whole jackshaft is moved side to side to make infinate alignment adjustments.
Matt
recumpence wrote:Do not be afraid to make suggestions or ask questions.
mdd0127 wrote:The slipper clutch is set to prevent too much wheelie action and the acceleration is brutal.
The bike must be pedaled up to 4 mph to engage the drive to make life easier on the motor controller.
Mitch wrote:I'd like to know how your drive forces 4 mph pedaling to engage the drive and how that works in conjunction with the slipper clutch.
mdd0127 wrote:The CA-LRC has a minimum speed setting that allows the motor to sync up and avoid the super high amp surges from attempting to start the motor from a dead stop. The slipper clutch is just a mechanical torque spike limiter and I usually set it tight enough that it doesn't slip unless the throttle is totally pegged or I land the bike with the throttle engaged.
It's a pretty cool setting. On this bike, I have to make two pedal cranks to get to 4mph and then the throttle comes in. It lets the motor sync up before there's a load on it.
Users browsing this forum: d-_-b, daniliver, Whiplash and 10 guests
