recumpence wrote:The crank will have a standard 130mm BCD bolt patern. So, the smallest chainring would be 39 tooth. I could add holes for 110mm BCD as well if I get requests for that.
Matt
recumpence wrote:My system requires a freewheeling crank. Of course, you could choose not to use a freewheeling crank. But, then the cranks will be driven when the motor is running.
Matt
j3tch1u wrote:recumpence wrote:The crank will have a standard 130mm BCD bolt patern. So, the smallest chainring would be 39 tooth. I could add holes for 110mm BCD as well if I get requests for that.
Matt
yes, 110mm BCD plleeeasse (i need to run a 32T)!
recumpence wrote:Yes, at this point, I am looking at changing the drawings to accomodate two 130mm BCD chainrings and one 110mm ring. That would allow two pedal and one electric ring. I think this would be perfect. The larger pedal ring would be good for road riding and the smaller ring for lower ratio off-roading.
Matt
The stock system will, most likely, come with a 56 tooth Origin 8 brand chainring.
Users browsing this forum: kozmoto, Mongoosed, rlouis48 and 7 guests
