irv wrote:Inspired by the RC builds here, I got a TURNIGY AERODRIVE SK3 – 6374-149KV outrunner from HobbyKing for my BladeZ electric stand-up scooter. I installed internal halls and went through all 36 combinations for the hall and phase wires. However I can't find a really low current draw when testing, the lowest I got was over 11A under no load (which compared to what I read here seems really high). I got the motor to turn smoothly when there is no load, but when I ride on the scooter it doesn't turn anymore (or turns really slowly when I do a running start). Here are additional details about the build, wondering if anyone can spot if there's something wrong with my setup:
batteries: 48V Turnigy lipos, 15C
controller: 48V conhis motor controller rated for 1kW (I also have a 72V huatong but haven't wired that yet for the scooter)
motor: Turnigy Aerodrive SK3, rated for 12S, 149KV, 2kW+. I think it has 14 magnets, 12 "gaps" on the windings.
halls: SS413A, installed internally, 120 degrees apart
rider: 147lbs
My hypothesis is that the halls may be shot, I had to cram them in really tight spaces. But I wouldn't know if the symptoms above (high no-load current, wouldn't turn when I'm riding on it) support this. And if so, what would be my options? Would going with external halls solve this? Or is it the controller that's the constraint? Thanks for any help!
gwhy! wrote:Have you got a link to the motor ( im guessing this is the new type of motor )
Bluefang wrote:To me that sounds like either you have the halls in the wrong order or one is shot.
Tench wrote:I think your hall positions are wrong, you have them sapced 120 physical degrees around the rotor when they should be spaced 120 deg in relation to one electrical rpm or cycle, with 14 magnets this motor has 7 electrical cycles per one whole revolution of the rotor. This would equate to the hall spacings being at (360/7=51.42/3=17.14 deg) that is one whole physical rotation divided by 7 (7 pairs of magnets) one electrical rpm, then the remaining number of degrees divided by 3,(3 being a third or 360/120) Repositon the halls at 17.14 deg intervals and it will behave correctly.
Took me awhile to get my head around this, it is easy to misunderstand the meaning of 120 deg spacing for halls.
Simon.
John in CR wrote:That spreadsheet should be deleted and forgotten. Trying only 6 combos of halls, or 6 combos of phase will get you a good forward or a good reverse. If not, then something else is wrong with the system.
gwhy! wrote:the best trade off is having the halls external at either 60d m but with the middle hall flipped or 68.5d m with all the halls facing the same way.
gwhy! wrote:with the older aerodrives sk3 that I have ( which are around the same spec as your one ) The no load current when the halls are setup correctly and the controller is working 100% will be around 2-3A, and on a scooter throu the grearing I gestimate the current no-lopad current should be no more than 3.5A ( this is what it is on my bikes ), the new type motors have a support bearing and these have been known to suck a addition 2A ( in my case anyway ).
HumboldtRc wrote:Uhh.... 20amps is your problem. That motor can pull 80-100 amps easily. Try it with a 6s 100-150amp car esc and you will feel the toque the motor reply can produce.
irv wrote:gwhy! wrote:with the older aerodrives sk3 that I have ( which are around the same spec as your one ) The no load current when the halls are setup correctly and the controller is working 100% will be around 2-3A, and on a scooter throu the grearing I gestimate the current no-lopad current should be no more than 3.5A ( this is what it is on my bikes ), the new type motors have a support bearing and these have been known to suck a addition 2A ( in my case anyway ).
Thanks for sharing! Based on your numbers, I think my halls are properly setup testing with no load. It's good to know you were also able to make the SK3s work. Do you have a build thread or website I can check out to learn a thing or two? What kind of controller or ESC are you using? And what kind of gear ratios do you run the motor through just so I can compare notes. On mine it's 16T front, 70T rear sprocket, and 10" tires.
irv wrote:@gwhy!, I checked out the links you posted and watched the videos too. Very cool and inspiring. Great job on all the gearing and the very polished custom work too.
I'm curious about the controllers, you mentioned they are just 6 and 12 fet controllers but you get 80A or something out of them. What kind of controllers are they and how much were they? Were they setup to deliver that or did you have to modify them heavily? And how difficult is it to modify? My soldering skills is only good until connectors and hall sensors, is it a big step to modifying controllers? My controllers include a a ConhisMotor and a HuaTong.
I saw the thread about the controllers cutting out. So far I have only encountered the LVC problem in the past, but I'll keep the thread in mind for future reference once I get the amps up.
nieles wrote:the problem is, even with your 70/16 gearing you are geared for a topspeed of ~70km/h (no-load speed) this gearing is way too tall
is it possible to go with a 13t sprocket? this will lower your gearing to ~55km/h (no-load)
nieles wrote:if you have access to a lathe, or know someone who does. you can buy the sprokets way cheaper here:
http://www.surpluscenter.com/sort.asp?c ... yword=PH25
you can just buy the sprockets with the smallest bore and machine it to the size hole you need (8 or 10mm i think?)
irv wrote:nieles wrote:if you have access to a lathe, or know someone who does. you can buy the sprokets way cheaper here:
Thanks for the link, those sprockets are way cheaper! I don't have access to a lathe but I was able to buy a drill press on craigslist for some change. I'm guessing that could work if I can center the sprocket being drilled and keep it in place. I only need 8mm, so 5/16 bore should work. At this price I can try different-sized sprockets
The simulator is pretty interesting. It doesn't seem like there's a straightforward equation that I can use for my motor, but maybe the data points from this can help with making estimates.
