Stinky with 80-100 and Nuvinci. NEXT BIKE Teaser pic inside!
Re: Kona Stinky, 80-100, Nuvinci, and Hk lipo in the swing a
Postby knoxie » Wed Feb 22, 2012 5:51 pm
A really nice concept dude, I hope the nuvinci holds up under the power as folks that have tried this before have had issues with them slipping under load ,be interested to see how you get on :D
Electric KMX 72V Lipo, USPD drive unit. BMX 72V, Puma BMC,
Raleigh 26 inch MTB Puma 50V Turnigy 25C Lipo 10AH, Trek MTB, X5 48V NIMH. Electric BMX
http://tinyurl.com/4vrmc8 http://tinyurl.com/3umm4n
knoxie
Postby E-racer » Wed Feb 22, 2012 6:22 pm
Thanks! I'm hoping for the best with the NuVinci. Drewjet toasted his running 7.5kw cont and 15kw bursts. They are rated for 5kw sustained and I'm running a 100 amp controller at 50v so that's 5kw w/o losses. It should hold together, worst case though I can throw a fixed gear setup on it and it'll be fine.
Kona Stinky: custom swing arm w/ batteries
-13s3p Turnigy Li-po
-Turnigy 80-100 rewound 130kv (Burtie's optical board)
-Kelly KBL 48201
-Nuvinci Dev Kit
http://endless-sphere.com/forums/viewtopic.php?f=28&t=35341
Goped ESR750
-12s2p Turnigy Li-po
-Turnigy 80-100 HXT w/halls
-Kelly KBL 48201
http://endless-sphere.com/forums/viewtopic.php?f=35&t=20732
E-racer
Postby E-racer » Wed Feb 22, 2012 10:44 pm
Balance harness 1of3
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Postby Sacman » Thu Feb 23, 2012 1:44 am
Nice! So that's just your first 4s3p.
I like the balance harness. Did you make that or get it from somewhere?
Sacman
Postby E-racer » Thu Feb 23, 2012 2:49 am
Thank you. I made the harnesses(currently making). I'm taking my inspiration from laptops. I will be taping or using adhesive backed foam for most all of the wiring construction/routing. Here is all 3 harnesses ready to be taped to the packs.
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Postby sn0wchyld » Thu Feb 23, 2012 6:37 am
E-racer wrote:Thank you. I made the harnesses(currently making). I'm taking my inspiration from laptops. I will be taping or using adhesive backed foam for most all of the wiring construction/routing. Here is all 3 harnesses ready to be taped to the packs.
how are you keeping the individual wires so closely + tidily bunched? are they on a backing or something? looks great!
How are you wiring the discharge leads? after seeing how tidy your balance leads are I'm keen to see what you do!
Got questions? hit up the wiki!
http://www.endless-sphere.com/w/index.php/Main_Page
My builds:
http://endless-sphere.com/forums/viewtopic.php?f=3&t=29373
Norko Aline Park DH - Clyte HT3525 - 24s lipo
http://endless-sphere.com/forums/viewtopic.php?f=28&t=33657&p=534823#p534823
'02ish Avanti D8 - 8085 170kv - 5s 40ah lipo - ple80 recution
abject failure in september
http://endless-sphere.com/forums/viewtopic.php?f=12&t=43143
RC driven Electric mountainboard - New vids up!
sn0wchyld
Postby Sacman » Thu Feb 23, 2012 10:21 am
Yes very tidy!
Is that ribbon cable you're using?
Sacman
Postby E-racer » Thu Feb 23, 2012 4:57 pm
The leads are taped together. I will terminate the 4s banks with 4s plugs. The twin 6s harness will convert the 3 4s banks to 2 6sor plugs run up to the cell medics.
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Postby E-racer » Fri Feb 24, 2012 2:34 am
2/3 of the pack complete. here is 8s3p
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Postby izeman » Fri Feb 24, 2012 3:00 am
looking great! i just can't understand why noone seems to use RED heat shrink tube for positive wires. it looks wrong to me to see black tubes on red wires ;)
bmc trailfox, mac12t, 12s lipo: viewtopic.php?f=6&t=32267
klein mantra, hs3540, 24s lifepo4, 20" rims: http://endless-sphere.com/forums/viewto ... =3&t=38848
izeman
Postby AussieJester » Fri Feb 24, 2012 3:07 am
izeman wrote:looking great! i just can't understand
If you use male/female connectors so the positive and negative leads can't be connected incorrectly doesn't really matter what color the wires are, that said, I agree it looks odd..I do like the above layout though looks pro great job e-racer...
KiM
AussieJester
Postby E-racer » Fri Feb 24, 2012 3:23 am
Thanks for the support and compliments. oddly enough I even bought red shrink tube but compared to the red turnigy wire it looks pink.
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Postby sn0wchyld » Fri Feb 24, 2012 4:04 am
looking great mate
are the packs permanently connected? doesnt look like they're using bullets any more...
My builds:
sn0wchyld
Postby E-racer » Fri Feb 24, 2012 4:27 am
They are permanently connected. I accidentally ordered 10 bullet connecters (5 sets) meant to order 10 sets, OOPS. Regardless I've built a couple things with these lipos now and have not ever needed to disconnect at that point so I think its going to be ok. Worst comes to worst I will desolder/resolder.
Here is the entire left side pack completed ready for instal in the swing arm (gonna be a tight fit):
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Postby Wheazel » Fri Feb 24, 2012 10:02 am
To consider when setting up parallell packs like this with permanent balancers are 2 things i have experienced:
1. Use thick enough wires to allow some currenttravel.
2. Be careful to not discharge all the way to lvc.
I melted the black wires due to the above points.
Also the matching of the parallell cells matters. In my case it might have been a less than ideal match and one cell got "empty" earlier.
One cell out of 20 died aswell. Hard to call what was the egg and the chicken tho.
Regardless, I am more careful about not discharging too deep now.
Wheazel
Postby E-racer » Fri Feb 24, 2012 2:55 pm
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Postby E-racer » Sat Feb 25, 2012 10:26 pm
It is alive! pics soon
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Postby sn0wchyld » Sat Feb 25, 2012 11:48 pm
just pics? common mate we want VIDS !! good to hear its running!
My builds:
sn0wchyld
Postby E-racer » Sun Feb 26, 2012 1:34 am
yes! all forms of media will come. I've got to work on my nuvinci tune before I can show off. That's tomorrows project.
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Postby knoxie » Sun Feb 26, 2012 5:45 am
superb job! :D looking forward to seeing some vids
knoxie
Postby recumpence » Sun Feb 26, 2012 1:03 pm
You know, it just hit me [and maybe this was addressed already], but what about all the unsprung weight? The main reason to use a non-hub system (RC especially) is to reduce all the weight on the rear wheel. I absolutely love this setup. However, I am wondering about that aspect of it.
Matt
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
recumpence
Location: On Earth right now. That can change at any time, though..........
Postby kfong » Sun Feb 26, 2012 1:18 pm
I notice the weight with the batteries on a rear rack. With it on the swing arm, I would think it would compound the problem. Now it's more like sprung weight and a heavy hub motor as well. I assume this will be replaced with an RC setup since a Nuvinci hub was mentioned. Another problem I see is the excessive pounding the lipos will see with it installed in the suspension. Hopefully this all works out for you.
kfong
Postby E-racer » Sun Feb 26, 2012 1:26 pm
I'll do a full write up tonight after I loose the daylight riding/tuning time. The swing arm fully loaded came in at 28lbs. 50cc-150cc scooter swing arms weigh over ~90lbs. Dirt bike swingarm/wheels assembly's can weigh in close to 30lbs aswell. I truly believe that the weight being 12" off the ground is much better than the weight being 26+" off the ground. I can assure you this thing handles incredibly well, it feels great!Hadcase packs are built for taking shock loads in R/C vehicles. This bike will be mainly used on the street and trails so I'm not to worried about the vibrations. Remember that the full 28lb swing arm is not fully unsprung either the weight closer to the fulcrum is more sprung than the weight close to the axle. More to come later tonight +Media! Thanks for all the support on this build it really gives you inspiration to get things done!
-Kelly KBL 48201
-Nuvinci Dev Kit
Goped ESR750
-Kelly KBL 48201
E-racer
Postby kfong » Sun Feb 26, 2012 1:34 pm
I still ride with my battery packs in the rear along with the ones in the frame, since I want the distance and have gotten use to the weight. It's not ideal but distance wins out for me. Your setup probably is better with the mass being lower. It's all a compromise. Kudos for doing something different.
kfong
Postby Alan B » Sun Feb 26, 2012 2:04 pm
Interesting design!
28 pounds in the swingarm probably acts like 14 pounds in the hub and 14 pounds at the bottom bracket bearing.
Alan B
1.21 GW
1.21 GW
PreviousNext
Who is online
Users browsing this forum: J Barrie Wilkinson and 8 guests
