This is exactly how I did it :
You may notice I removed the thick steel flanges, this saved an impressive amount of weight! and it makes the motor quite small. To anybody searching for a big mofo outruner that makes huge torque and is drivable with any cheap ebike controller at only 5,5kg... search no longer :
220 mm external diameter and 32mm stator, this ends up as a 32x200mm motor, this is a lot of motor!
I tryed something on this frame, with dynema kites lines and marine grade PPU 100 glue. It is an experiment but I am quite confident!
Anyway if this thing holds together while i build a real frame (No tubes yet!!! it's been a while) I'll be happy enough to have something rideable.
Adam
