Thud wrote:Which motor?![]()
I haven't rulled the idea out....
Thud wrote:I really think a re-wound & terminated 80/85 would make a awsome BB drive set up & I will test that on my old FS Marin some time this summer.
Thud wrote:The motor linked in adrian's thread is now back to $90.00
Thud wrote:I have posted a couple pictures of a little reducion unit that powers my buddys kid hauler bicycle around with a 6374 turnigy & CCice100 controller. bike is starting is 3rd year of service & he still loves it,(kid is getting heavyer & it still pulls hime & her all over town) & from my experiance, this is my favorite "assist" to ride as a bicycle. It make you feel like superman. properly geared for the bike (road or mountain) it is pure enjoyment.
Thud wrote:& the biggest plus is the ease of maintaining a 6cell set up over chaining a pack in series...then parallelling them up for capacity.
adrian_sm wrote::evil:![]()
So freewheeling cranks. Where? How much?
See also: viewtopic.php?f=28&t=25153Thud wrote:why? the Dicta has a pr of weak pawles but with dual angular contact bearings it remains a fairly true set up...(till the pawles fail & you smash your nads on the top bar!)
The white industries unit is great under pedal power & with 3 pawles it is rock solid....the fault there is the single bearing suport when it is freewheeling.(under motor power & not pedaling) it gets very flopy very fast. does not insire confidence.
the Crossfire is a huge step up from the Dicta & still keeps the sprocket running true, has 3 pawles for secure pedaling & are reasonably priced. I haven't actually used the crossfire in this application yet....but I have nothing but confidence it is the solution.
Unless recumpence shows his full bearing supported freewheeling crank design....That would be the ultimate fix.
Adrian wrote: Unfortunately the 6374-200kv never went on sale,
adrian_sm wrote:Now you have me thinking about a BB drive through the gears on my FS bike with this reduction unit. Damn you.
Thud wrote:the wide BB are actually offset far more on the left, for clearance of the china girl 2-stroke engine kits.
Thud wrote:As far as compairing the 63mm to an 80mm motor.....apples & oranges. The 80mm motor starts out with a 27% size advantage directly in the leverage ratio that makes outrunners so atractive.
As I understood it, Thud was just stating a fact. If the offset isn't needed for the freewheeling mech, it doesn't matter that it's on the left-hand side. In any case, it's easy enough to rebuild them with the offset on the right-hand side.deVries wrote:Any thoughts, comments, opinions, or recommendations about this......
Why not drive the front crank on the left side then?![]()
Too complicated or too expensive to do or ?
Advantages vs disadvantages?
adrian_sm wrote:So freewheeling cranks. Where? How much?
recumpence wrote:I am pushing to make the highest quality crank drive that uses the stock derailer and pedal system that I can while keeping an eye on the cost. It looks like the kit consisting of motor, drive unit, FW cranks with chainrings, all mounts, motor and all hardware will come in at around $1,500.
recumpence wrote:#4 The freewheeling crank. This is one thing I am really excited about! It will use a second support bearing to eliminate the overloaded freewheel bearing issue that is so common with freewheeling cranks. It will also use standard 130mm BCD chainrings for multiple ratio options. I am very excited to have come up with a solution to the FW crank bearing issue. I am not the first to do this, but I think it is the first to be readily available. My system will come with this new FW crank system and a new lengthened bottom bracket.#4 The freewheeling crank. This is one thing I am really excited about! It will use a second support bearing to eliminate the overloaded freewheel bearing issue that is so common with freewheeling cranks. It will also use standard 130mm BCD chainrings for multiple ratio options. I am very excited to have come up with a solution to the FW crank bearing issue. I am not the first to do this, but I think it is the first to be readily available. My system will come with this new FW crank system and a new lengthened bottom bracket.
recumpence wrote:#1 Motor. This system will be compatible with Astro motors, but for those who are looking for lower power, lower cost, and lighter weight while retaining quality, it will also be compatible with a small outrunner based on a standard Maxx Products outrunner. This motor will retail for under $200. The normal motor is $180. However, my motor will use a longer shaft and a few other minor changes. Also, this motor is readily available and I can pick them up 15 minutes from my house! And if someone manages to smoke the motor, the stator/windings retail for $50 and are easy to replace! This motor uses high-end bearings and is, overall, a very high quality motor! I am thrilled to find this option so close to my house. Also, these motors have been tested in very dirty environments. So, I am confident it will run well in this application. It is also a very quiet motor.
Why not drive the front crank on the left side then? Too complicated or too expensive to do or ? Advantages vs disadvantages?
Users browsing this forum: hekdude, Knowledgethirst and 5 guests
