wiring RC - Cycle Analyst [ :) fixed]
Postby lostrack » Sun Apr 15, 2012 5:34 am
Hi,
I can't seem to get this right on my first try - can anyone shed any light onto why this is not working?
Esesntially I have doubled the reds and blacks to the same bits on the board, and just changed the throttle cable to PWM.
When I pull the throttle, I get a nice display-dimming effect. Not much speed though:)
thanks
Tom
CA_RC_wiring first go.jpg (234.39 KiB) Viewed 462 times
Tom Player
lostrack
Re: wiring RC - Cycle Analyst :(
Postby lostrack » Mon Apr 16, 2012 5:13 am
Can anyone help at all?
lostrack
Re: wiring RC - Cycle Analyst :( ?
Postby lostrack » Mon Apr 16, 2012 5:32 am
The 5V pin on the board measures 5V, so I know the power is getting to the throttle, and the CC HV160 arms, which means it can see a throttle is there and is at zero.
Throttle closed measures 4V between ground and signal, Throttle open measures 4.8V between ground and signal. Does that sound right?
lostrack
Postby bobc » Mon Apr 16, 2012 5:44 am
Sorry Tom - I have absolutely no experience with either CA or magura.... but the magura is a pot (innit?) so I'd expect it's output to vary between 5V and 0V if the pot is wired in the "conventional" way. Is it a 3 or 2 wire connection to the pot? The pictures suggest 3 wire - I can't see what the black wire is connected to, should it (or should it not) be ground?
bobc
Postby lostrack » Mon Apr 16, 2012 5:55 am
Thanks for chipping in Bob - yes it is wired to ground
I've been playing with the software settings and it seems to work (ie. move the wheel).
Getting some funky error beeps from the Castle Creations HV160 though.
If my shunt is 100A 75mv, does that make my mOhm 0.75?
lostrack
Postby drewjet » Mon Apr 16, 2012 6:06 am
Are you sure the Ca has the rc throttle function turned on/enabled?
ImageSuzuki SP200, Mars Brushless, 300 Amp Kelly Controller,(18S12P) http://www.evalbum.com/1511
3220 Mountain Bike viewtopic.php?f=28&t=16705&p=244317#p244317
Suzuki Lipo Upgrade viewtopic.php?f=10&t=23088&p=335986#p335986
Race Bike viewtopic.php?f=3&t=32486
drewjet
Postby lostrack » Mon Apr 16, 2012 6:14 am
drewjet wrote:Are you sure the Ca has the rc throttle function turned on/enabled?
Yep - it's in R/C mode.
It turned on, but went into the oscillation on/off for a while and then stopped.
Now it won't move - I'm sure it's not broken, but a matter of nailing some settings....hmmmmmm
lostrack
Postby drewjet » Mon Apr 16, 2012 7:01 am
Do you have an RC servo you can use to test it? I usually use a servo to test before plugging in the ESC, they are a lot cheaper if things go wrong.
drewjet
Postby lostrack » Thu Apr 19, 2012 3:14 am
I checked the wiring from a few forum posts and my assumptions were wrong. Everything is now plumbed in correctly.
I have made a few measurements as it occasionally jumps into life (when I short something on the board when measuring voltages) but not on the throttle yet. Would you mind a cursory glance at these readings?
5v = 4.94v
4.03v is float between the 5v and the throttle measured from the points in the board.
0.89v is between ground and wiper when throttle in stop position.
4.93 between ground and wiper when throttle fully pulled back.
(4.04v throttle range)
My Aux thresh is set to 0.87, is this correct? All other settings follow the posts from the RC CA thread.
Thanks for your help!
lostrack
Postby www.recumbents.com » Thu Apr 19, 2012 11:17 am
The RC CA has a steep learning curve.
This may help:
http://www.recumbents.com/wisil/e-bent/ ... nalyst.htm
http://www.recumbents.com/wisil/e-bent/ ... ttings.htm
See the "resistive throttle" settings.
It took a little while for me to get it to work too, and I thought it broke my ESC, but eventually I figured out how to make the beta version of the ebikes RC CA work with my Castle Creations Phoenix HV ESC. It didn't break it but apparently the RC CA sent signals to the ESC that caused it to flash error codes, so I had to do a full reset of the ESC using the CC management software to clear the errors.
-Warren.
www.recumbents.com
Postby lostrack » Sat Apr 21, 2012 6:22 am
www.recumbents.com wrote:The RC CA has a steep learning curve.
This may help:
-Warren.
Warren, you are the man. The reset got everything working and I've been able to fiddle with it a bit, so thanks so much. I had no idea anything was wrong as it seemed to arm and there were no indications on the software.
Out for a ride later, hope it's worth the hassle!
cheers
Tom
lostrack
Who is online
Users browsing this forum: boostjuice and 11 guests
