Achtung ! Cheap C8085 KV250 !
Re: Achtung ! Cheap C8085 KV250 !
Postby adrian_sm » Wed May 02, 2012 6:58 am
sn0wchyld wrote:you could always just reterminate it to save some time... that'd give you just under 150kv. close enough to the 80100?
+1 And exactly what I had planned for mine. :D
Build #1 ~28kg ~ 700w Avanti Hardtail Crystalyte 408, 48V10Ah Headway. ~5500 kms to date. (retired)
Build #2 ~30kg ~2000w Giant AC Dually Crystalyte 408, 48V10Ah Headway + 6s10Ah LiPo = 70V. ~15000 kms to date [SOLD]
Build #3 ~13kg ~2000w Commuter Booster <1kg Friction Drive in Beta testing (www.commuterbooster.com)
adrian_sm
Postby sn0wchyld » Wed May 02, 2012 7:23 am
Alas my good man, put your fears to rest, for they are back in stock! But best be quick for ye olde leaders hobby be sayin' there be less than 10 left in the holds!
Sorry. been watching pirates of the Caribbean ...
Dauntless wrote:That SkyHobby motor is NOT 8085, it's 80100. SkyHobby does not show the 8085kv250, but they do have the 8085 kv170 that's also still available at LeadersHobby, etc. (Wish THAT had been the $50/motor) And all I would mean by discontinued was that Leaders might not plan to carry the kv250 anymore. I'm sure there'll be motors of some similar style remaining available, but to replace a kv250 in the future with a kv170 would throw gear ratios out of whack.
The 80100 that you posted SkyHobby wanted $106 for, versus $122 at Leaders. HobbyKing was cheapest, but since there's no sign mine will ever come, it's worth a few bucks more if someone else will just SEND IT.
Just looking that this I impulsively ordered an $8 motor that's more powerful than any of the heavy metal motors in my current scooters, I'm sure replacements for them are all around $70-80. Plus a $12 RC controller. Let's see how this does on a bike.
Got questions? hit up the wiki!
http://www.endless-sphere.com/w/index.php/Main_Page
My builds:
http://endless-sphere.com/forums/viewtopic.php?f=3&t=29373
Norko Aline Park DH - Clyte HT3525 - 24s lipo
http://endless-sphere.com/forums/viewtopic.php?f=28&t=33657&p=534823#p534823
'02ish Avanti D8 - 8085 170kv - 5s 40ah lipo - ple80 recution
abject failure in september
http://endless-sphere.com/forums/viewtopic.php?f=12&t=43143
RC driven Electric mountainboard - New vids up!
sn0wchyld
Postby mauimart » Wed May 02, 2012 3:11 pm
Not a bad idea. I may give that a try although at 150kV that would still be about double of the rewound 80100 I am currently running at 72V. I could reconfigure the pack to 12S from 18S and run the reterminated 8085. I have the required gearing available as well. A good option nonetheless.
Thanks.
mauimart
Postby farmkid4 » Mon May 07, 2012 4:10 pm
Yes!! :!: The motor(C8085 KV 250) I ordered just got here i order it on April 20th and it arrived on May 7th although I prolly would have had it on Sat if some had been home when the mailman came. :roll:
Here are some pics:
(There was a box inside the bag)
Now all I need is batteries and a controller :lol:
Do you have the ability to read?
Do you use it to increase your understanding?
9C Buildlog: http://endless-sphere.com/forums/viewtopic.php?f=6&t=47608&p=698343#p698343
farmkid4
Postby pff7 » Tue May 08, 2012 7:11 pm
I don't get this...using a motor designed for a radio-controlled plane on a ebike? the specs don't list torque either or was this motor already used on an ebike? and tested
pff7
Postby sn0wchyld » Tue May 08, 2012 9:16 pm
pff7 wrote:I don't get this...using a motor designed for a radio-controlled plane on a ebike? the specs don't list torque either or was this motor already used on an ebike? and tested
oh yea, been done, and then some... torque is a function of rpm's and power output. And since you can (within reason) gear the motor down to whatever rpm's you want on your bike, then a 6kw RC motor like these can output the same torque as any other 6kw motor. Do a search for 80100 or 8085 or 6374 builds, theres dozens on 'ere.
My builds:
sn0wchyld
Postby farmkid4 » Wed May 09, 2012 6:19 am
farmkid4
Postby pff7 » Wed May 09, 2012 5:20 pm
Thanks farmkid4 and snowcynia...now that I think about it it does look pretty big next to the keyboard....not being into RC planes(don't mind watcing though) I bet the RC plane is a monster of a plane....
pff7
Postby sn0wchyld » Thu May 10, 2012 9:58 am
pff7 wrote:Thanks farmkid4 and snowcynia...now that I think about it it does look pretty big next to the keyboard....not being into RC planes(don't mind watcing though) I bet the RC plane is a monster of a plane....
nah these only go on planes with <1.5ft wingspans. they do go fairly fast though... :wink:
and who are you calling snowcynia? thats snowSIR to you! :P
My builds:
sn0wchyld
Postby Thud » Thu May 10, 2012 10:59 am
5 more for the royal treatment.
we'll see if we can make a suitable bottom bracket drive with one of these babys..
get some......
Thud
Postby farmkid4 » Thu May 10, 2012 1:53 pm
Thud wrote:5 more for the royal treatment.
:shock: I sure hope so! So thats where they all went :lol:
farmkid4
Postby Zigger2k » Mon May 28, 2012 7:25 am
Mine package with 2x 8085 arrived ))
So, what about re-terminating to WYE ? Anybody tried to disassemble ? What about glue on windings ?
Zigger2k
Postby Thud » Mon May 28, 2012 7:48 am
Ive stripped a couple for re-winding.
They have the typicle super glue on the endwinds. re-terminating to wye is doable. (but still not acceptable for my standards)
I really think these are some aged shelf stock, or a lot of assemblies from odds & over runs of previous stock. The flux can end bells are the older machine pattern we saw branded as HXT motors(pre-skirt bearings) & the stator cap is a transitional part that has the wire chanell flaw the old HXT's had that will let wires touch the flux can & get sawn in 1/2, yet has the newwer machining pattern we saw on the Turnigy branded motors (that held wires captive to stop the potential contact)
A couple with notchy feeling bearings in them also (typicle quality from this factory)
over all I am happy with the lot....I will blueprint the Lot & flip em.
get some......
Thud
Postby Johi » Sat Mar 23, 2013 5:57 am
WARNING!! BEWARE OF THIS SCAMMING COMPANY.
Don't order from leaderhobby (http://www.leaderhobby.com/). They won't refund you when they cannot deliver their items. You only get meaningless e-mails. I'm now waiting for much more than two week for refunding on my PayPal account and reminded them at least every 2nd day. Also don't order from dealmetic.com because this is the same people. If you are interested in more details, write me an e-mail: jvogel@vetphys.uzh.ch
Johi
Postby sn0wchyld » Sat Mar 23, 2013 9:50 am
Johi wrote:WARNING!! BEWARE OF THIS SCAMMING COMPANY.
wait... a scamming company that sends people the motors they order? often very quickly? what? I've never asked for a refund (never had too) but I've ordered about 8 motors from these guys over about 3 or 4 orders, all have been delivered quickly and in good order. So NO, they are not scammers, and in my experience their customer service has been fine when it came to cancelling a wrong order I'd made.
And you wont win yourself many friends here being that your first post was to bag a well known good source of motors.
My builds:
sn0wchyld
Postby thepronghorn » Sat Mar 23, 2013 5:25 pm
not sure how good a source of motors they are anymore, have you taken a look at their prices recently?
thepronghorn
Postby Dauntless » Sat Mar 23, 2013 8:19 pm
Yeah, I brought that up a few weeks ago. I can't help but wonder how it is their site is still there, seems like there would be ZERO sales at this point. I guess it'll take months to see what comes of them. And they never did get the 8085 kv250 in stock again.
Any sufficiently advanced technology is INDISTINGUSHABLE FROM MAGIC!
- Arthur C. Clarke
Dauntless
Postby sn0wchyld » Sat Mar 23, 2013 9:28 pm
thepronghorn wrote:not sure how good a source of motors they are anymore, have you taken a look at their prices recently?
:shock: :shock:
Fair call mate! There prices have always gone up and down but over 200 for a 6374 is insane! So glad i stockpiled a handfull of 63 and 80 series motors now! I notice too that ebay, which was another good source of 63 size motors now has very few selling, and those that do are about 190. Ive seen minimum prices over 120 before, and its come back down... Hopefully its not the end of the cheap big outrunners.
My builds:
sn0wchyld
Previous
Who is online
Users browsing this forum: stEVe and 5 guests
