Quite.darkangel wrote:shop master suggested getting new fixie wheel insead of buying all parts......
also he mentioned, that under so much torque fixie hub may unthread
DATABASE00 wrote:about the motor that is alot of amps needed. And weight isnt that pretty looks like my treadmill motors. But seems really strong.
4 HP 24 VDC ELECTRIC MOTOR
45 AMPS NO LOAD
140 AMPS FULL LOAD
8000 RPM FULL LOAD
32 INCH POUND OF TORQUE
¾” DIAM. X 1 ¾” SHAFT WITH KEYWAY
MOTOR DIMENSION 4” DIAM. X 7 ¾”
SHPG 24 LB (ESTIMATED)
Also lookup flip flop rear hibs.
it makes it so the back only has one gear on both sides. one side you always have to peddle other side you can coast, you could put the coasting side for you and the motor side for the motor.
darkangel wrote:amber is correct if you can get the good steel hub and lace the new spokes you should be kin my case the cost plays main rolle
Users browsing this forum: Google [Bot], Miles and 11 guests
