i was just told by some guy that i need the run capacitor,
the engine keeps shuting down, goes and shuts then throtle again it goes then it shuts i just cant figure why
do you guys know why?????
darkangel wrote:i got 4 bateries on it so thats 48v motor is 60v
11t and 16t sprocket bike is 45lbs less on weight so total of 220 lbs versus
300+ i had
didnt ride it with full throtle but half when it started smoking
the motor will run under load for couple of seconds before it shuts, then throtle again it runs and shuts
remember i had 44 t sprocket when same thing happened, now i have 16t
so i cant see anything other then controller being just underdeveloped for what it is ment to run correct?
darkangel wrote:in conclusion
3000 rpm
under load 900rpm
900rpm x 60min x 48T/11T x 29" wheels x 3.14 / 12" x 5280' = 94mph - 38mph wind and additional cause of resistance = 56mph safe speed
94mph /250lbs estimated weight = .376 * 29" wheels =11mph
38mph + 11 mph = 49mp - 94mph = - 45 or 45mph estimated speed total
26" wheels you need 11t -44t or 48t is good
27" wheels you will need 12t - 52t
700c wheels you will need 11t -48t
Users browsing this forum: No registered users and 8 guests
