My custom mount Cyclone! :D [video]
Postby Memran » Sun Jun 17, 2012 1:55 pm
I've recently thrown together a "960W" cyclone kit.
Behold the mess!
Here is a video of it running on some flat lead-acid batteries, upside down. The very first test!
http://www.youtube.com/watch?v=TonScdbY0hM
I really don't understand why this is Supposedly 960W, since 36v * 35A = 1260W. Maybe the 35A sticker on the controller is peak? Don't know.
The wiring and battery mounting needs some tidying, and I must get a battery monitor before I can properly test it, but it is alive! :D
I am only running 10S lipo initially, and only 8Ah, so I have limited range, but I can add more cells later on. This bike is not for travelling over any real distance, it is meant for slower technical trails where more low speed torque is required. I will probably have to tweak the gearing a bit to make best use of the motor.
Such a shame this thing is so noisy! :(
Memran
Re: My super messy Cyclone! :D
Postby superz1983 » Sun Jun 17, 2012 3:27 pm
a really really interesting mounting solution .
compliments.
Is possible to see some detail's photos to understand how have you made this support?
ty
"...advice is a dangerous gift, even from the wise to the wise, and all courses may run ill..."
Gildor Inglorion
superz1983
100 µW
100 µW
Postby Memran » Sun Jun 17, 2012 3:57 pm
I don't have more photos of the mount, and it is too dark outside to take some today, but I will get some more pics soon. :)
In the meantime, here is a drawing of the 4-parts of the motor mounting.
It is perhaps overkill, but I made use of the materials I had to hand at the time. 10mm 6061 T6 aluminium, which I milled to shape, drilled, tapped and slotted.
The two side plates are secured to the frame by the bottom bracket cups. The middle is bolted to the sides by 12 countersunk M4 bolts. This part has some slots cut in it, though which the adjustable motor rail is bolted. This allows sideways adjustment to get a good chain-line between motor and chain ring.
The motor rail also has some slots which allow the motor to be positioned forwards or backwards, to tension the chain.
The mount for the controller is just some 2mm aluminium sheet cut by hand to clamp onto the frame at one end, and the other is bolted using one of the frame's "crud catcher" bosses.
I plan to refine the controller and battery mount to be attached to the main motor mount (somehow) so that it is all one unit.
Hopefully this makes sense! :D
Memran
Postby boostjuice » Mon Jun 18, 2012 12:28 am
So i was aprehensive to bother opening your thread with a title like 'messy'. glad it was tongue-in-cheek. Nice mount! 'CNC' and 'messy' never belong in the same sentence :mrgreen:
boostjuice
Re: My custom mount Cyclone! :D
Postby Memran » Mon Jun 18, 2012 1:28 am
Changed the title, so not to deter other visitors! :D
Memran
Postby knoxie » Mon Jun 18, 2012 6:58 am
glad you changed the title as it is a nice little build, it cant be that noisy? compared to a motorbike anyways, looking forward to seeing some video of it running. :D
Electric KMX 72V Lipo, USPD drive unit. BMX 72V, Puma BMC,
Raleigh 26 inch MTB Puma 50V Turnigy 25C Lipo 10AH, Trek MTB, X5 48V NIMH. Electric BMX
http://tinyurl.com/4vrmc8 http://tinyurl.com/3umm4n
knoxie
Postby Memran » Sun Jun 24, 2012 8:30 am
I've been out for a short test ride today. It was a little bit windy and cold, but not too bad.
Low speed torque seems good, and on some grassy slopes the rear wheel will lose traction before the motor stalls. It has taken me up a long, off-road, rocky path which I estimate is 30% grade. :D
Without a speedometer I can't be sure but when I shift into top gear it feels like about 23mph. This is more than enough for what I will use this bike for! :D
Here's a little video of some low-speed testing: (May need to turn volume down, because of wind noise...)
Big thanks to the random guy who agreed to shoot the video clip. :)
One thing of concern is the sparking that occurs when I connect the batteries. Any ideas how to stop it?
The pedal cadence is stupid. :( At full throttle, I'd need to pedal at about 112rpm! (based on 3300 rpm motor @ 37v)
My gear ratios are as follows:
14T motor > 44T chainring, 32T chainring > 12T-32T rear cassette.
I need to use a larger chainwheel, but it already looks stupid-big. :(
Memran
Re: My custom mount Cyclone! :D [video]
Postby knoxie » Sun Jun 24, 2012 9:15 am
superb! yes the sparking when you plug the battery leads in is the capacitors in the controller charging, you can fit a pre charge resistor or just live with it and replace the connectors when they wear out, thats what I do, you can put come vaseline in the contacts that will help reduce the arching and wear.
knoxie
Postby Memran » Mon Jun 25, 2012 7:55 am
Aside from the gearing / noise / sparky connectors, I need a better charging system. Having to disconnect the packs and charge one at a time is laborious - and I only have two batteries right now! I guess I can parallel charge the 2 packs, or buy a 10S charger, but it all seems messy.
What should I use to monitor the battery state to prevent the cells from dropping too low during a ride? Can I safely rely on the Cyclone throttle's LEDs? I don't want any 'splosions between my knees!
Memran
Postby kentlim26 » Mon Jul 09, 2012 2:47 pm
for my suggest, to know the lipos cells are not going a low voltage , you must have buy the cells LVC alarm. i bought from Ebay. so when the cells reach low volts, it will sound a loud alarm.
AS for the Loud spark Noise, you need a two way switch, One " ON " goes to a 10watts 110ohm resister... a little current goes to the caps.. and then You ON the second switch is a main current goes the the controller,. hence you will not hear nothing !!
kentlim
Conhis hub motor run on April 2010, 48v 1000watts hub motor distance run 5800km, and Re~alive cyclone kit bought in year 2009, Bought a greentime controller 18fets- 4110 , 48v~ 90v , 3-speed mode. Latest top speed I got for my greentime controller 76.8km/h ! , yet to reach 80km/h, or I will never reached 80km/h ?
kentlim26
Postby Memran » Sun Jul 15, 2012 10:42 am
Well it is fun to ride, and the torque gets me up some pretty steep off road trails ... but ... the noise! Everyone nearby knows it has a motor on it. The lack of stealth is a real downer for me.
Also I just can't pedal with the motor. I need to alter the gearing somehow, without using a bigger chainring, or run a lower voltage (don't want to run lower volts!).
Memran
Postby Memran » Mon Aug 27, 2012 3:00 pm
A little uphill test. Quite difficult to keep the front wheel on the ground! :D
Memran
Postby Memran » Sat Sep 01, 2012 12:14 pm
Another hill climb test! :D
This hill is VERY steep! Its difficult to tell from the picture, but given than the road down there is 10% grade, you can get an idea for just how steep the path is! The Cyclone motor got me to the top with no pedalling, and wasn't too hot to the touch either! :D
Memran
Who is online
Users browsing this forum: ecologymagnet, nikos7 and 8 guests
