First i want to say hello to all of you. My name is Morten, I`m 43 years old and live in southern Norway.
Motorcycle/moped building has been my great passion the last years, but now My son is 5 years old and I want to build him a trials bike.
He has been riding his Peewee 50 for two years. Thrustable, but noisy bike with terrible suspension.
I have been lurking around here and other places on internet for recearch.
This is what I`ve ordered and what My plans are:
- Steel framed full suspension 20" mountain bike.
- Onza 19/20" bike trials wheels with Maxxis tires.
- Pit bike USD front fork.
- Turnigy Aerodrive SK3 - 6374-149kv Brushless Outrunner Motor.
- TURNIGY K-Force 120A-HV OPTO V2 5-12S Brushless ESC with program box and servo tester to run it.
- Turnigy nano-tech 8000mAh 5S 25~50C Lipo Pack
- Self made primary timing belt gear box 12/48T 4:1
- Secondary. 11/22T 2:1 chain driven.
I hope this will give me what I want. A light bike with good torque and top speed around 30km/h (18mp/h)
Please feel free to comment this setup, as i said: I`m a newbie..... and I dont want to fall into any traps..
Specs:
Kv (rpm/v) 149
Weight (g) 840
Max Current (A) 70
Resistance (mh) 21
Max Voltage (V) 44
Power(W) 2250
Shaft A (mm) 8
Length B (mm) 86
Diameter C (mm) 59
Can Length D (mm) 61
Total Length E (mm) 113
Specs:
Output: Continuous 120A, burst 180A up to 10 seconds.
Input Voltage: 5-12 cells lithium battery or 15-36 cells NIMH battery.
BEC: None.
Control Signal Transmission: Optically coupled system.
Max Speed;
2 Pole: 210,000rpm
6 Pole: 70,000rpm
12 pole: 35,000rpm
Size: 88mm (L) * 55mm (W) * 15mm (H).
Weight: 125g
Specs:
Capacity: 8000mAh
Voltage: 5S1P / 5 Cell / 18.5V
Discharge: 25C Constant / 50C Burst
Weight: 924g (including wire, plug & case)
Dimensions: 194x45x47mm
Balance Plug: JST-XH
Discharge Plug: 5mm bullet-connector
For you who like motorcycles, this is My blog, please do not comment in this thread. http://midgardfactory.blogspot.no/
Please excuse my bad english.....
Specs:
Kv (rpm/v) 149
Weight (g) 840
Max Current (A) 70
Resistance (mh) 21
Max Voltage (V) 44
Power(W) 2250
Shaft A (mm) 8
Length B (mm) 86
Diameter C (mm) 59
Specs:
BEC: None.
Max Speed;
2 Pole: 210,000rpm
6 Pole: 70,000rpm
12 pole: 35,000rpm
Weight: 125g
Specs:
Capacity: 8000mAh
