mr.pibb
1 W
- Joined
- Sep 15, 2012
- Messages
- 58
Ok I have a curry trailz bicycle and I want a new motor. I want to upgrade to 48v. I want a replacement 48v motor ideally in the 1000 watt range because, I would like to see top speeds of aprox. 30-35 mph on flat ground.
Initally I gravitated to the 48v 1000w my1020 (11 tooth).
http://tncscooters.com/index.php?route=product/product&path=52_57&product_id=328
I did a lot of research and was about to purchase one today for $90 until I realized I would need like a 80T sprocket on the tire to get a decent enough ratio to maintain within 80% of the motors loaded rated 3000rpm. :?
Since theres no way that would possily fit and I am not going to make any more gearboxs or anything like that I am back to the drawing board. Unless there is a easy fix Im not seeing...
I was able to find 600W GEARED Motor - 36 Volts Style: MY1020Z3
http://tncscooters.com/index.php?route=product/product&path=52_56&product_id=337
This motor is essentially bolt on to the old trailz which I do really like. The transmission is the same overall dimensions ect. I just dont think it is powerful enough for 30+ mph. Please let me know what you think.
The stock oem trailz motor propells me at about 15.3 mph; geared at 9:20
This means I am actually doing about 440 rpm and the motor is rated at 470.(everything stock)
Building on those numbers...
If I get the 600w motor geared at 10:20 (stock wheel sprocket) not much will really change as far as top speed...
The rpm will essentially stay the same. The only gain is the 1T on the new motor.
440rpm @ 10:20 gearing only gets me to about 17 mph
Thats only a 1.7 mph gain...
(I imagine I will gain considerable acceleration though because of the higher amp draw)
Im looking to get 30-35 mph.
So I would have to change the gearing yet again. It appears that I cant enlarge the motor gear more than 1T. Or atleast I dont know where to find one. I would have to drop the wheel sprocket down to 16T.
440rpm with 10:16 gearing gets me a top speed of about 21.3 mph... getting closer
I have read that other people have put 36v to the oem 24v motor and seen 23+ mph and the motor doesnt fry.
If I put 48v to the new 36v motor I image I would end up with around 600 rpm(450*1.33). That would bump top speed to about 29
Not quite 30-35, but 29 isnt bad and I could probably live with it considering I would have to spend probably a lot more time and money for a better result. I could go to a hub motor and thats a good thought, but this upgrade would realistically only cost me around $150 for the motor, controller, and new 16T sprocket.
My questions are:
Can I get away with 48v to this motor? I would think yes because it is only 1/3 more voltage and people are doing 50% more going to 36 from 24.
Do you guys think that I will see in real life what Im thinking I will get?
Is this a good plan?
Should I go with another more powerful motor- and if I do how can I easily and cost effectively gear it to 30-35 mph?
Thanks!
(((I based all my calculations off of this calculator: http://www.arachnoid.com/bike/bike.cgi )))
My questions are:
Thanks!
