crossbreak
I'd like to have a rear hub with additional 6-hole disc flange on the right, to be able to mount a sprocket. Mounting it on the left (disc brake) side is not possible with many frames. Another reason is that I'd like to keep the brake dust away from the chain/belt, as well as keep chain lubricant away from the brake.
-the normal disc brake on the left
- 9-10 speed cassette freewheel on the right
-a belt sprocket or chain sprocket for the motor, bolted to another 6-hole interface on the right
I just found these dual brake front hubs that are mentioned several times in this forum, but these don't work for me since i'd like to use it with a 12mm through axle and a 10speed cassette. For bikes with normal dropouts I can simply use a simple (and commonly available) adapter.
That's what it should look like. I really don't want to make a custom hub if I don't have to. Any sources for something like this? anyone interested?
