Component list:
2012 Specialized SX trail
Lighting rods mid drive kit
Power Pole connectors
10 Ga wire
ebikes.ca: controller, throttle,CA-DP plugs, and Cycle Analyst
Hobbyking: Batteries, 6 8400mAh 3S2P 30C LiFePo4 + charger
Total cost:$3700 including the bike
Here are some pictures of my progress.
http://i.imgur.com/KQd2tzIl.jpg[/i
mg]
[img]http://i.imgur.com/4dYyLUGl.jpg
Had to slightly modify the the bottom bracket, ground about 6 mm off the outer diameter to clear the lower suspension mounting point. Otherwise the 73mm kit fits quite well I just need a chain breaker because the 219 chain has a few to many links even at full adjustment.
10 Ga wire
mg]
