EstebanUno
- Joined
- Feb 23, 2011
- Messages
- 38
I'm wondering how low the voltage can go without damaging the motor, controller or battery? Can I run it until the controller shuts off? Is there a built in safety cutoff? Would the bms on the battery shut down discharge at some low value as well? My primary interest is to learn what the actual usable amp hours is so I can estimate range. A second question is what voltage value should trigger a charge cycle from the perspective of battery life and number of charging cycles?
Battery is 48v Lion 13s 5p samsung 29e, 15 ah nominal. It powers bbs02 750w.
