100mm BBS02 for fat bikes due at end of August
jonathon
Raleigh, NC
I'm planning a build with a BBS02, so I reached out to Bafang to see if they had any new versions in the pipeline since we're so close to Interbike 2015.
Here's the response that I received from Beck Feng:
Yes,Bafang is planning on releasing the updated version of the BBS02 for 100mm B.B before the end of Aug,the moror can be used in fat bike.
So cheers to those of you planning a BBS02 fat bike build!
Lectric Cycles in Tempe, AZ offers a 100mm BBS02 kit. Machined locally and assembled in house.
But it's not stock so costs a lot more than it needs to like the one I bought from Cal ebikes. It's a great bit of kit but if Bafang can come out with a stock 100mm model it will save us all a lot of money.
This came directly from Bafang or a reseller?
Matt
Its true I have been told the same thing. Will see what they say at Eurobike that seems like a probable location for launch.
It's a shame because I am a reseller of the 100mm adapter kits.
Finally a 100mm BBS02 but now so many fat bikes are using a 120mm BB. Wonder if Bafang will offer a 120mm any time soon?
Here is what I know so far, if you want images and links that work check out http://electric-fatbike.com/2015/09/01/bafang-finally-releases-a-1000w-mid-drive-bbs02ish-that-fits-a-68-120mm-bb-with-giant-fins
Bafang Finally Releases A 1000W Mid-Drive Codenamed BBSHD That Fits A 68-120mm BB With Giant Fins
Rumors have persisted for more than a year now that Bafang was working on a BBS02 that would be shipped from the factory with support for a 100mm+ fat-bike bottom brackets. I haven’t covered this at all out of respect for the three companies that have spent a lot of time and effort making their own 100mm axle conversions for the BBS02. Now Bafang has updated their website with specs for their newest drive unit listed as the G32.1000 located here that will be called the BBSHD. It won’t be available stateside for at least another couple of months (est availability for US consumers is Nov 1st), I’ll post a review as soon as I get one.
Lectric Cycles will have one mounted on a full suspension Salsa Bucksaw for your demoing pleasure this year at Interbike, so go seek them out if you want to try it before you buy it. There are only 6 pre-production units in the entire universe and Lectric has 2 of them.
Bafang has this to say about the new drive unit
With an integrated speed sensor, this mid-drive motor, which is compatible with a 68-120mm bottom bracket, has a rated power of 750-1000W, a reduction ratio of 1: 21.9 and a maximum torque of 160 N.m, will provide the rider with great explosive force when starting the system. Highly strong and efficient, this motor greatly enhances riding joy and is suitable for mountain bikes and sand bikes which are the favorites of riders who love challenges as well as transport bikes. This motor is black.
I’m not sure what I’m the most excited about,
That this unit works with 68-120mm BB
The increased power to 1000W nominal
Increase in torque 160Nm
Bigger fins to keep the drive unit running cooler
The fact that the drive unit is still black. I guess their market analysis said there was no demand for a bright pink drive unit.
BBS02100mm
The RPM is increased to 130-150RPM from the BBS02 750W which ran at around 120RPM which is way faster than you could ever pedal even if you were on high on drugs. Drugs are terrible, just because your parents do them doesn’t mean they are OK.
The nominal wattage rating is 1000W and I’m guessing that it will peak out at around 1500-1600W which puts it firmly into Lightning Rods Small Block territory. More power is better, and the motor is still small enough that you could lie to the cops and say it’s 750W … hopefully before they beat you senseless and throw you in the paddy-wagon. It turns out this motor has the same amount of copper as the old 750W motor but is wound and wired to take 1000W continuous power.
4.8kg = 10.6 lbs which is about what the 100mm BBS02 kits weigh so it’s nice that it’s not as heavy as a large geared hub or direct drive. A comparable DD motor like the MXUS would be 20lbs or more and would eat a lot more watts than this one will under load.
I have confirmation that the BBSHD controller will be able to support a max of 45 Amps opposed to the 25 Amps that the old BBS02 controller would max out at. From the factory it will ship to max out at 30 or 35 Amps, frankly we just don’t know yet.
160Nm means more wheelie popping power over the 120Nm of the 750W BBS02. More Nm = More fun. 160Nm is about 2.1 times the maximum Nm of force of the most powerful Bosch drive unit you can buy the Performance CX. *Yawn*
I’m almost certain that their controller will be running the newer IRF3077 mosfets that they have been charging an extra $20 premium from the factory for on the BBS02.
I’m guessing that the cost for the new unit will be about $150-200 over what you are paying now for the 750W BBS02 from reputable ebike vendors. I also would assume that this drive unit will heavily eat into the sales of the 750W BBS02 since who really is going to want to buy a US legal mid drive when they can get away with 1000W instead? Expect the price of the 750W BBS02s to start dropping in the coming months as dealers try to dump their existing stocks.
So what will the top speed of the new drive unit be? I’m guessing at full throttle on level ground with a 170lb rider and a 44T front ring and 12T cog the top speed would be around 30mph-ish. Going downhill with a very large chainwheel like a 52T you should be able to get close to 45mph. The place this motor should really shine is on steep uphills which should be around 20mph or so depending on the grade. With a similar power level on a DD motor or geared hub motor you won’t get anything close to the hill climbing ability of this mid-drive system.
There is a new motor coming soon, we're still working out the kinks but they will be in production in the not too distant future. Lectric Cycles will have operational drive units at Interbike (we already have them) along with a bunch of killer builds that use the existing e-RAD products we have for the various BB standards out there including 92-120mm bottom brackets. The HD motor won't be for everyone as there are some drawbacks from the existing 100mm kits we have including size, weight, and some packaging issues in fitting many of the fat bike frames that have flared out chainstays. We will be releasing more information about price and availability by the time Interbike begins.
