High power RC motor and drive unit production
Re: High power RC motor and drive unit production
Postby recumpence » Thu Oct 30, 2008 4:10 pm
etard wrote:I think alot of us are going to put this system on DH bikes, so my concern is what to do about a rear brake. Looking at my bike, if the drive unit where to feed from the top of the rear tire to a gear on the rear disk mount, it could be possible to have a disc caliper between the chain, inside the drive. What I am proposing is that the gear and the braking could be done on the same piece of metal. However, oil and brakes do not seem to be an ideal combination, if you used a belt and made a custom brake caliper that left room for a fairly wide belt on the inside, this could be done and still be bolt on to original brake mount without frame modification. (breath in)
Matt,
Is it possible to use belt drive for final drive? Or could I use a chain wax instead of grease and just add teeth to my disk brake caliper?
CNCAddict,
Do you think you could machine a custom brake caliper that fits around a belt drive sprocket?
The way I see it, is if everybody contributes something, the end product could be available sooner. Oh by the way, I have access to a waterjet (is that what its called?) if that would help to make custom sprockets, gears, calipers, etc...
One of the best solutions would, indeed, be a Sproder (sprocket/rotor). The chain lube is not a huge concern for them. There are non-greasy lubes out there. Also, it is possible to get a sprocket and a rotor side-by-side in that area.
I am going with chain final drive. I may move to belt on my recumbent at some point. But, for width concerns with a rear brake, chain is best.
Of course, there is also the option of a small disc on the output shaft of the reduction unit. I just want to get the reduction done first.
Matt
E-tard, I live the avatar pic. I am watching the Aptera with great interest. Heck, I am looking at building a "Neighborhood Electric" slightly oversized tadpole trike. It would basically be a full suspension version of a typical pedalled trike with double wishbone front suspension and a much wider front end for stability, no pedals, and a steering "Wheel" like a Cessna yoke that uses mostly (or all) hand controls. I am looking into the laws regarding this right now.
1% of the world's population can think "Outside the box". The rest are firmly stuck within the box. Where are you?
recumpence
Location: On Earth right now. That can change at any time, though..........
Postby CNCAddict » Thu Oct 30, 2008 4:31 pm
Haha, yeah I guess I'll officially be CNCaddict here and not Dave, lol. Anywho, I personally am going to stick a gates carbon 12mm on my bike to see how it goes. These belts are ridiculously strong, but I only have a reinforced plastic pulley right now borrowed from the ixi bike. It is designed for the poly chain belt, but I worry it will explode when I put over 100ftlbs of torque on it. Anyway, I got 3 8mm polychain pulleys for $125 with some haggling which isn't too bad. You can check them out here. http://www.ixibike.com/
More belt fun http://www.youtube.com/watch?v=FHMChA0M ... re=related
CNCAddict
Postby deecanio » Thu Oct 30, 2008 4:56 pm
I'll be going with belt drive too, it may need a little more space to run alongside a disk but i think fitting won't be a problem especially if you can gear so that the pulley is smaller than the rotor.
Good to hear your on the case guys - realistically when do you think we will see the motor CNCaddict?
I'm basically hanging on to see what you guys come up with but if its a way off i may try off the shelf first.
Cheers,
D
Kona Stinky 2004
Marzocchi JNR T's 2004
72V 10ah lipo
Xlyte HS3540
Lyen 12 FET Jozz mod
deecanio
Postby recumpence » Thu Oct 30, 2008 4:59 pm
The only reason I am not running a belt final drive right now is drag. Under power, a toothed belt is very low drag. But, when a large pulley spins a small pulley in a freewheeling condition, there is a bit of drag present. I like to pedal without any discernable drag. Also, a chain final drive is basically silent as long as the small sprocket is not spinning to fast. :wink:
I am at the shop tomorrow afternoon CNC programming for the reduction drive. However, I am stuck waiting on some mechanical tubing to arrive before I can start machining.
Matt
recumpence
Postby deecanio » Thu Oct 30, 2008 6:00 pm
Hi Matt,
thanks for the info, maybe i should reconsider chain drive, i had ruled it out due to noise, mmmmmm.
looking forward to seeing what you come up with and more so what your going to do with that mean dh :twisted:
Cheers<
D
Kona Stinky 2004
72V 10ah lipo
Xlyte HS3540
deecanio
Postby recumpence » Thu Oct 30, 2008 6:02 pm
I am not trying to sway you on your final drive choice. However, again, if sprocket RPM is kept low enough, noise is not an issue.
I cannot hear the chain on my recumbent at all.
Matt
recumpence
Postby CNCAddict » Thu Oct 30, 2008 6:47 pm
Yeah, the belt vs. chain decision is really preference. For a high powered setup where no pedaling is done, I would take the belt because there is no maintenance, belts are cleaner, and the slight decrease in efficiency shouldn't really matter.
The motor will be done at earliest in a month. I have to order all the parts first (not quite done with the design). Then it takes a while for the magnets and stator to be made up and sent to me. The other parts I can make really quick since I've got the CNC lathe and milling machine here at the house. If you know a fast/affordable way to have custom magnets made up..please let me know :)
CNCAddict
Postby deecanio » Thu Oct 30, 2008 8:03 pm
Hi Guys,
i wish i did know a fast way for custom parts CNC, i might be a bit closer to finished than "just needs a drive" :)
belt vs chain is tricky (don't worry matt, no swaying felt), chain is much easier to mount but imo belt is a slicker look,but i dont want any drag (with all belt drives?) , anyway i guess it doesn't really matter as long as it hauls ass whilst not blowing my stealth, something i had no problem keeping with my hub.
i think i might try something in the interim as long as its not too expensive, did either of you look at the magmotor and box i posted? Miles mentioned that it wasnt very good for efficiency but other than that no one commented? i would like to know what you think of that in particular matt and eplain its shortcomings.
i Think my problem is i need to bone up a bit on motors and gearing, i could look at 100 motors online but not understanding their specs how would i choose one?
Anyway enough of my bleating, crack on gents, you guys rock 8)
Cheers
D
Kona Stinky 2004
72V 10ah lipo
Xlyte HS3540
deecanio
Postby MitchJi » Thu Oct 30, 2008 8:36 pm
deecanio wrote:Hi Guys,
i think i might try something in the interim as long as its not too expensive, did either of you look at the magmotor and box i posted? Miles mentioned that it wasnt very good for efficiency but other than that no one commented? i would like to know what you think of that in particular matt and explain its shortcomings.
Cheers
D
Hi D,
It sounds like one of Matt's 2 stage might be ready fairly soon.
You might want to consider using that drive with an interim motor. That might be easier than building your own gear box and when you build your more permanent system you would only need to mount a new motor on your existing box plus maybe change a sprocket or two to tweak the drive ratios.
Best Wishes!
Mitch
The best quality batteries and lowest priced batteries for DIY EV's are tier 1 OEM Quality Cells from salvaged (wrecked) EV packs. Two examples are Chevy Volt and Nissan Leaf packs.
Nissan Leaf Module specs are here
Chevy Volt Pack Info - Salvage 16kwh Packs Under $2k here
The cells are rated conservatively by GM at 7.8C, Yabert's tests of Volt packs on the DiyEv car forum suggest a higher C rate, 15+ C!.
$1,400 plus $360 freight. Still over $1k less than new lead!
MitchJi
1 GW
1 GW
Postby etard » Fri Oct 31, 2008 12:45 am
Sproder, huh... Now your making things up Matt. Haha
The cessna yoke sounds like something I was contemplating. So what, you pull back to go faster and push foward to brake. That would add a whole new experience to those trikes. What if you rigged the seat to sit up a lil when you push foward, and swing back (better aerodynamics) when you pull back on the stick.
I was joking with one of my friends as I was explaining the RC application on bikes, I told him I'm going full fly-by-wire. I'm just gonna get the rc car wheel controller to steer, gas, and brake. But, it got me thinking, and I think on a tadpole, or trike you could actually do that, if you had the right servos.
CNC,
There are alot of guys that build thier own motors on the forum : http://www.rcgroup.com. Those guys special order magnets and windings, etc... all the time. I would be willing to pay more for better magnets though.
etard
Postby CNCAddict » Fri Oct 31, 2008 1:14 am
etard wrote:CNC,There are alot of guys that build thier own motors on the forum : http://www.rcgroup.com.
Haha, yeah I'm one of them! I started off in RC and moved into electric vehicles about 3yrs ago with a brushless powered outback mountainboard. I was more or less kidding about the magnets. I'm getting them custom made, but nothing ever happens fast enough :wink:
CNCAddict
Postby deecanio » Fri Oct 31, 2008 6:05 am
Cheers
D
Hi D,
Hi Mitch,
yes i'll definately be looking at Matts gearbox as he is the best we have by a long shot, however Matt is making the reduction unit with Davids motor in mind and that motor wont be ready for a while yet.
I was considering the magmotor as i can get the reduction box from them too and its all plug and play, it wont be as good as matt and davids solution for sure but it may do unil next year when all the testing is done and dusted and the motor is done and available and also castele release their new monster esc.
Half my problem is im impatient, but after a two year build who can blame me?
Bottom line is i want to buy my drive from matt and david but it wont be done for a fair while, im just considering options off the shelf so i can have a blast over winter and test the robustness of the bike once the drive is seatpost mounted, trouble is to buy an interim setup will cost more than buying from our guys but being as i have to revert to a standard wheel anyway it's tempting to see if will work :)
R&D takes a while, as does shipping from the states for replacement parts if anything breaks, i'm trying to do the sensible thing and wait it out but the snippet of fun we had at jozzbikes meet tells me my bike is close to where i want to be and all i need to do is revise the drive system, im not even that worried if it's alike for like swap as far as power is concerned, just need to get the weight out of the wheel and regain the ability to ride the bike like its meant to be ridden :twisted:
Cheers,
D
Kona Stinky 2004
72V 10ah lipo
Xlyte HS3540
deecanio
Postby voicecoils » Fri Oct 31, 2008 6:34 am
deecanio wrote:I was considering the magmotor as i can get the reduction box from them too and its all plug and play, it wont be as good as matt and davids solution for sure but it may do unil next year when all the testing is done and dusted and the motor is done and available and also castele release their new monster esc.
I say buy the magmotor and gearbox, give it a go. At ~6.4kg for 6kW, it's got decent power to weight IMHO. Figure ~8kg to get it mounted and connected to the rear wheel.
If it doesn't work for you just flog it back off to the robot crowd.
Only concern I can see is the length of the motor and possible gearbox noise. I doubt it was designed to be quiet.
I've got the C40-300 magmotor which I've never used for anything (planned to make a powered bike trailer) but the motor quality looks top notch. It is a brushed motor, so you'd need to find an appropriate controller. What would you run it at, 36v? How many paralleled A123's does that get you? ie how many amps could you pull?
[edit] two links: http://www.robotbooks.com/robot-motors.htm
http://www.ampflow.com/ampflow_motors.htm
Read about overvolting in the first link. Efficiency may be an issue for these motors overvolted or at lower RPMs...
voicecoils
Postby recumpence » Fri Oct 31, 2008 7:47 am
My drive is being designed with David's motor in mind. However, David is also designing his motor with my drive in mind. So, I gave him the screw spacing I would like and shaft length.
The drive will work with a number of readily available RC motors.
The only "Perfect" RC motor for this that is currently available would be the Plettenberg. But at $1,100 who really wants to buy one (other than those of us who are insane and really impatient for the best)? :mrgreen:
I wish this stuff was easier to adapt to bike use. But, we are close, very close. The ideal setup would be an Astro Flight twist throttle, running a Castle SHV200 ESC, into a motor like David is making, with a silent reduction drive.
My recumbent is close to my ideal. Heck, if I could pull 160 to 180 amps through my HV110, I would be happy as a pig in slop! The "Perfect" system can be setup right now. The problem is price. There are a couple $1,000+ ESCs that work for this, and a couple $1,000+ motors. But, the ideal setup should be available to the average Joe. I am thinking as long as you can setup a 4,000 watt drive for $1,000 (motor, ESC, and reduction), that is ideal.
Anyway, I am doing some programming on the drive unit today.
I highly doubt there will be much R&D needed with the reduction unit. I have already learned what I need to know with my recumbent. I am, essentially, using the same rough drive setup in a very compact, variable layout structure. But, all the components have proven themselves. I have 600 miles on my recumbent so far. :mrgreen:
Matt
Matt
recumpence
Postby Ypedal » Fri Oct 31, 2008 7:54 am
Hey matt.. are you still using the original spoke adapter for the rear wheel or have you moved up to a disk hub ? ( I know it's in one of the threads somewhere.. but that's alot of reading i have not yet gotten thru.. )
ES site status page:
Ypedal
Postby deecanio » Fri Oct 31, 2008 9:05 am
recumpence wrote:My drive is being designed with David's motor in mind. However, David is also designing his motor with my drive in mind. So, I gave him the screw spacing I would like and shaft length.
Matt
Matt
Hi Matt,
well i am insane and really impatient for the best :)
i think i will take the plunge with a pletty and an svh200 (are they out yet??) with one of your new boxes.
did you have the terminator? specs? i know you have posted all this info but i'll have to wade through to find it.
will the pletty drop straight into the new box? that would be cool then i could just work out what gearing i need and go with 25chain and sprockets?
i think you run at 48v on that which i could do, if i reconfig my pack from 66v 6.6ah to 48v 8.8ah that would be fine for me.
Voicecoils,
i think (dont flame me if im wrong) that my 123's will do 80amps for 1s and then another 80 for every paralell string ?
does that sound right?
Anyway i know they kick ass and certainly my pack wont let me down for supplying power.
If i folow Matts lead i would be running 48v (or whatever the 123 equivalant is) so i guess that would make my pack 4p allowing me to draw silly amps, being as the svh200 is 200 amps? i will be fine to supply anything i put on really :)
mmmmmm, pletty and svh200 could be the ticket, i have the patience to wait for Matts second box but i doubt i have the patience to wait for davids motor.
damn this ebike lark, i cant think about anything but drive systems night and day !!!!! :evil:
Cheers,
D
Kona Stinky 2004
72V 10ah lipo
Xlyte HS3540
deecanio
Postby CNCAddict » Fri Oct 31, 2008 10:22 am
The SHV250 will be available soon for those who pre-ordered them. I was told they would only be making enough to fill current orders, so if you really want 85V and 250A, you might want to call them up and get on the list.
CNCAddict
Postby deecanio » Fri Oct 31, 2008 10:31 am
Hi CNC,
Thanks for the heads up - up looking at the plettys now when i should be working lol
i guess i'll work out max power rqd and go from there.
ok time to start looking to buy :) i'll post in my thread proposed setup and hopefully all the guys will holla if im making a big mistake :)
Cheers,
D
Kona Stinky 2004
72V 10ah lipo
Xlyte HS3540
deecanio
Postby MitchJi » Fri Oct 31, 2008 2:18 pm
Hi,
recumpence wrote:
swbluto wrote:What's supposed to be functionally different with the new outrunner motor being designed and the existing RC motors?...
A few things;
#1 HUGE shaft. The internal shaft diameter is huge on this motor (I believe 15mm). The output portion of the shaft will probably be 12mm.
#2 Far better efficiency. RC planes and helis ahve alot of airflow available. So, effiency is not a big deal. But, we want the best efficiency possible. This new motor will have thin laminations and be taylor made for our application. That (among other factors) will give better efficiency.
#3 Super beefy bearings to handle the high shaft side loading a belt drive will have.
#4 Ability to handle FAR higher voltage than typical RC motors.
My Plettenberg maxes out at 50 volts. These new motors will handle 100 volts mor more!
Also, the can (bell) will be tapered to tolerate the shock loads imparted on it in bike use.
Matt
CNCAddict wrote:...the motor should work at any PWM you give it, and should produce a really clean BEMF signal unlike some of the other motors out there, so if you don't like the squealing just crank it up to 24khz.
Also, I plan on getting things as corrosion proof as possible on the motor. Electrically, brushless motors can run underwater. It's just the corrosion that's a problem.
Thats a pretty compelling list of features. Some of the features are compelling by themselves but all of them is great :!:
I really like the 24khz PWM. Quiet is really nice/important.
Since Matt compared this motor to his Plettenberg I have a question. Three things that distinguish the Plettenberg are price, build quality and component quality. How is the X-era 60 going to compare with the Plettenberg on build and component quality?
Also any reason (doesn't require a oneway or freewheel) not to use 219 chain for the secondary reduction?
recumpence wrote: A hub motor is not in the cards right now. :cry:
When I saw the request for a hub motor drive for that motor I thought it was a bad idea.
That might have been correct but if someone could work out a high quality geared hub that used a motor similar to Davids I think the market would be huge. Why would anyone buy a Clyte 5 series if they could get a much more powerful and much lighter hub with massively better build quality?
I think in a large hub you could fit a two stage belt/chain drive similar to what Matt is building. SRAM already has a hub with dual RC (much smaller) motors:
http://endless-sphere.com/forums/viewtopic.php?f=28&t=4625&p=78344&hilit=sram#p78344
SRam Sparc
there are two version:
# the old one with gears (i have)
# and a newer version with belts (quieter)and higher voltage (i think still the same motors)
I think the sales volume would far exceed any chain drive option and I think both John and David would both like a popular product.
Best Wishes!
Mitch
MitchJi
1 GW
1 GW
Postby johnrobholmes » Fri Oct 31, 2008 2:49 pm
The issues with the hub motor design is space and total gear reduction available. If you want more power in a lighter package, you have to use more gear reduction. Unless somebody can come out with a rugged and small two stage planetary that fits inside a hub shell, I just don't think we will see hub motors with power to weight ratio equal to a divorced power train.
_______________________
Volt up, gear down!
http://www.HolmesBikes.com -- Custom 15 -12ga spokes and Moped rims
johnrobholmes
Postby recumpence » Fri Oct 31, 2008 2:52 pm
OK, lots of questions since I posted last!
Here is my perspective;
#1 A hub motor system would be (believe it or not) alot harder to engineer and manufacture. Though the market would be large. For my production capability, a hub motor is pretty much not doable.
#2 I just spoke with Castle Creations. The SHV200 is being released soon, however, the entire first production run is sold out. Second run is scheduled for 3 to 4 months from now. That stinks. But, I have found the HV110 to be fantastically stable if added capacitors are used on the input side. So, for anyone looking for up to 4,000 watts at 50 volts or less, an HV110 (with input caps added) is the most cost effective choice anyway. It is 1/3 the price of an SHV200. However, I am getting an SHV200 as soon as I can get my grubby hands on one. :wink:
#3 I absolutely LOVE my Plettenberg! The way I feel about my Plettenberg is the same way Jay Leno describes the McLaren F1;
"The F1 is the most incredible car ever built up to that point. It is light, fast, powerful, refined, FANTASTIC! The down side is the cost. The car is crazy expensive!"
That is the way I feel about my Plettenberg. I am absolutely in love with it! The motor is smooth, powerful, tractable, cool running, VERY high quality, and just plain sweet! The down side is............. gulp, $1,100! :shock:
I have a local guy who wants me to order one and setup a drive for him with it. So, it looks like I may be doing that for two people now. :wink:
#4 No reason why a 219 chain can not be used for final drive. I am not using it for the secondary on the reductions because it is not needed (.25 is perfect for that stage and will be taking far less load than the final drive) and 219 is just a bit too bulky to fit the reduction unit well. I see no reason why it could not be used for the final drive to the wheel, though. My mountain bike will be running #35 chain for higher torque handling, though.
Basically, both David and I are not operating with huge budgets. I am just working with play money. Also, this is not my main business. So, I cannot devote the enormounse resources to a hub motor or a turn-key E-bike system. There will still be a bit of fabrication (minor stuff) required for installation and what-not.
Anyway, I am looking forward to the future on this stuff. I think next summer will be exciting for the E-bike world!
Matt
recumpence
Postby CNCAddict » Fri Oct 31, 2008 3:31 pm
The quality of my motors is pretty good, it may not have quite the fit and finish of the Plett, but as for reliability in a dirty E-bike environment it will be way better since I'll use sealed bearings and plan on making it fairly corrosion proof. Also, while there may be no squeal from the PWM frequency, it'll probably groan a little during hard acceleration. But that will go away when up to speed.
CNCAddict
Postby MitchJi » Fri Oct 31, 2008 3:48 pm
Hi,
CNCAddict wrote:The quality of my motors is pretty good, it may not have quite the fit and finish of the Plett, but as for reliability in a dirty E-bike environment it will be way better since I'll use sealed bearings and plan on making it fairly corrosion proof. Also, while there may be no squeal from the PWM frequency, it'll probably groan a little during hard acceleration. But that will go away when up to speed.
Slightly less fit and finish but more reliable and less noisy sounds like a better choice before factoring in the price.
recumpence wrote:That is the way I feel about my Plettenberg. I am absolutely in love with it! The motor is smooth, powerful, tractable, cool running, VERY high quality, and just plain sweet! The down side is............. gulp, $1,100!
They don't have the Heli model listed but the price here is:
http://www.icare-rc.com/plettenberg_pricelist.htm
Terminator 30-8 US$ 929.00
Thanks!
Mitch
MitchJi
1 GW
1 GW
Postby recumpence » Fri Oct 31, 2008 3:56 pm
Yup, the heli version has an output shaft and an aluminum fan on the end of the bell. That motor is $1079. I actually bartered them down to $1000. Aparently they liked my project. :wink:
Matt
recumpence
Postby etard » Fri Oct 31, 2008 5:16 pm
Matt,
You guys seem to be working in the 4KW range, will this drive still be efficient at 1-3KW ? I plan on using the HV110 (gotta order that from Holmes) and maybe a Hacker 60 series setup. I want to stay in the 15 pound range, so battery weight is an issue.
Also, I ordered all the parts to make the servo tester throttle you posted in your recumbent build, is there anyway to wire in the signal from my magura throttle. I like how small yours is, but I think a proper throttle would be best for offroading.
etard
PreviousNext
Who is online
Users browsing this forum: Blanthegenius and 5 guests
