etard
Ok, so I have not been able to use the Gates belt calculator, is there something I need to download before I can access this?
Either way, I need suggestions for my friction drive. I am only doing one reduction from motor to roller. I have a 10mm axle on a 300kv motor good for about 2.5 kw. My tire is a 26 inch slick, and the roller is 1.3 inches in diameter. The motor will be powered by 48 volts. What gearing would be most efficient for the motor and still get about 25-28 mph? Which belt pitch, belt width, pulleys?
Any help will mean much progress, as this is the last part I need.
thanks
thanks
