John in CR
100 TW
I need multiple drivetrains to test for my coast-to-coast without recharge ride in early '09. While I wait on Matt's gearbox along with delivery of a number of hub motors, I want to try a simple one that's been nagging me. The reduction of a single chain and sprockets just won't do without a big heavy motor, but I have a nice little angle grinder 90° gearbox with strong helical gears and a 3.5:1 reduction. The only imperfect thing about it is that it spins CCW looking at the end of the shaft, so requires left side mounting. All I have to fabricate is a mounting plate to mount the gearbox to a motor face, and an adapter to mate the motor shaft to the gearbox input shaft. I'll just put a cassette and derailleur on the gearbox output shaft, and chainring(s) at the wheel. The mounting plate will incorporate the means of mounting to the bike.
This isn't for high power or high speed, but instead a test for efficiency compared to hub motors. I want to run the best speed I can at 300-500W on the flats, which is about 150 miles of the ride, but I have some mountains to contend with which I believe may be the downfall of hub motors for this ride. I have a few sub 1kw brushed motors to try, plus my little Kohlmorgen's that I've been waiting for just the right use. With the relative ease of changing gearing and sprockets, along with the ability to change and fit different motors along the axis of the bike frame this should prove to be a worthwhile and quick project for comparing non-hub to hub motors. I could even attach an RC motor to it, since in it's design use the gearbox accepts a 35krpm input.
I've also been thinking that I may need a second motor with freewheel ability to help climb the mountains even if the hub motors prove better for the flats. Then if it works well, it may prove to be a viable option for a high powered addition for a downhill bike to make it able to race uphill too, another idea nagging me.
Pics of progress to come this week.
John
John
