Are there any controllers that have a manually adjustable current limit? And, also, is it ok to use a "20 amp" controller with this motor?
Would a ping battery trip if it were used with a 20 amp controller(and it can sustain 25 continuous amps)?
Are RC controllers functionally equivalent to crystalyte controllers in terms of the relationship between v_motor and throttle and the current limiting region? That is, would 50% throttle convert 48 volts from the battery into 24 volts fed to the motor assuming the battery current isn't being limited? And do RC controllers limit the battery current or the motor current?
