fechter said:
Check out Peter's bike:
http://endless-sphere.com/forums/viewtopic.php?f=2&t=3423
He used a small brushed motor as a generator powered by the pedals. Not super efficient, but you can contribute energy at any speed.
Before y'all run away with the idea that this is inefficient read the paragraph on efficiency in the article that Miles pointed to:
quote:
Efficiency
The SH drive system does not compare with a purely mechanical chain drive e.g. of a racing bike but was not made to replace such drives, but rather to replace mechanically complex hybrid drive systems.
The first working models of the SH drive were equipped with brushed generators with peak efficiencies of between 55 and 70% and with brushed motors with about 80% peak efficiency. However we were astonished that we rode about as long and far as typical PH e-bikes. This was confirmed when Chapelle and collegues measured efficiencies of PH e-bikes of between 55% and 95%. Thus it is possible to build SH vehicles with better efficiencies than the poorer PH bikes.
So far we only discussed “peak†efficiency. If the average efficiency during the whole trip is considered, the efficiency of SHs compared to that of PHs starts to look interesting.
In urban traffic a vehicle is on constant speed only for a minor part of the travel time. Therefore the advantage of high peak efficiency at one operating point of a parallel PH remains advantageous only if the efficiency at other operating points is also good and/or if the gears are used effectively to stay in the optimal region.
People not trained in optimal operation of traditional bicycle gears often pedal off their peak efficiency because humans have a quite narrow peak of high efficiency at some power levels.
A major advantage of the SH is that the system can react more quickly than mechanical gears. The efficiency of the system can be maximized electronically at every moment. The human being can be optimally loaded: the "load-leveling" capability of SH's is very advantageous from a physiological point of view. This was borne out by the author and colleagues and by Daniel Couque (who constantly pedals a generator while manually operating the throttle of the electric motor of his velomobile). The experiences are too few to draw final conclusions yet, but it cannot be easily discounted that the physiological advantages of a SH could over-compensate the disadvantage of peak efficiency of a SH compared to a PH.
endquote.
