Hermes eMTB kit 2017
knurf
Anyone have more info about this kit?
https://www.youtube.com/watch?v=gmUIu9PuEnc
https://paradoxkinetics.com/
Maybe. At least they also got a cover for those mean gears, don't have to run them bare like in the screenshot.
Doesn't sound too bad in this ride vid.. Probably far from a chain saw but it's never gonna be BBSHD sound levels either.
https://www.youtube.com/watch?v=hWmbtRVzywc
Wow I didn't know you needed a motor to go downhill on a bike...its quiet because there is not much load on it in this video
Thanks! I tried a few searches here first, but it seems my forum search game is weak
well it has a 63mm motor its powerfull 1500w and its perfectly built the engineering in that thing is way beyond everything else in the market right now , the throttle is excellent programmed and its reliability is way better than the bafang as far as i know (i've ridden it many times)
Did you ride other ebike kits...for give us some comparative whith the ermes?
Looks like a very well design kit :)
Well I've driven some , the paradox kinetics it probably the best o n the market right now it's 100% stable no controller or motor errors , it uses metal gears and not nylon like bafang (except the crank gear) everything is perfectly engineered with high quality materials plus the kit comes with 600wah battery as far as I remember 12s Sanyo cells. The throttle is progressive it's not like bafang plus it has a small button than works as last time throttle position) it's expensive like 2500 with the battery and the backpack but indestructible and it has issis BB not the square like bafang , definitely with the 2600~
