Road ebike project
vagosofron
Road ebike project
Post by vagosofron » Dec 17, 2017 5:04 am
Hello everyone, i'm Vaggelis from Greece and i'm planning on byilding an ebike out of my road bike.
The problem is, that i don't know anything about motors, batteries (a friend is an electrical engineer, so he can help on that part) and basically everything besides the bike part! I've been reading a lot latelly though, but i'm still comfused.
My story really quick, i am 35 yrs and i used to live in a city totally flat, where i used my bike for everything.
For the last 3 years though, i moved to a city (damn wife!), where the road is fairly uphill towards the center of the city ( i live 3 miles outside). My house is 20 meters above sea level and the city center is 80 meters, so you can understand how steep the road is. I can ride there easilly, but on the hot/sunny months i get really sweaty. So i need something to get me there without or light pedalling, but on the way back i don't have to use the motor at all.
My bike is a Bottecchia duello and weights about 20-22 lbs. I weigh 187 lbs and i'm not planning on currying any weight on me when i use the bike. I saw a lot of project ebikes and i'm leaning towards a friction drive type, because it\s simple and i can take it off easilly. I want it to be smooth and clean, so i would like to use an outrunner brushless motor and place it on the bikes back triangle.
The motor. What motor do you suggest? Not something extremely expensive though. I've seen a couple of turnigys, but i don't know which one is wright for me. Can i go with one from the 50 range, or do i have to go bigger?
Controller. I guess it depends on the motor, correct?
Batteries. For starters, i would like to use the cheapest option ( if it is possible), just to see how everything works.
Throttle. That is pretty simple...isn't it?
Thank you all in advance and i'm really sorry for the huge topic and for my gramar mistakes.
Triketech
Re: Road ebike project
Post by Triketech » Dec 17, 2017 1:43 pm
So many options but with the power limits in Europe....
Mid-drives are often favorable but you'll loose multiple front sprockets.
Hills tend to favor geared hubmotors. One nice feature with geared hubmotors is no motor drag when pedaling with the motor off. You lose the regeneration feature but the higher efficiency of a geared motor allows you to travel further on a charge. Moreover with a geared hubmotor you'll only need a throttle and maybe a cruise control feature for the boost up a hill.
Your bike would favor a Rear wheel system due to front fork structure not being stout enough for a motor.
This system would work well, although you'll need to add a Freewheel to replace the cassette, and its likely to be something like a 36-11 gearing. That would probably be a better set of ratios considering your climb as well. 36V option, and 8-10 Amp-Hour battery should do - that should provide enough power to push you up over 300 meters of elevation so long as the speed remains above about 10kph.
http://www.goldenmotor.bike/700c-36v-re ... ion-kit-2/
A battery similar to this may be all you need.
https://www.bixpower.com/BAT-BX3632-p/bat-bx3632h.htm
vagosofron
Post by vagosofron » Dec 17, 2017 5:38 pm
Thank you for the response, i've seen those setups, but here in Greece they sell them really expensive and I can't order outside Europe, because we are having problems with the customs and their ridiculously high taxe fees.
I don't care about the limits, here in Greece ebikes aren't that common.
I found this motor in an auction on ebay.uk
"Turnigy HeliDrive SK3 Competition Brushless Motor 4956-1350KV (T600)"
Do you think it is suitable for my project?
Triketech
Post by Triketech » Dec 17, 2017 11:03 pm
Not sure how its any different importing from the UK.
Basically anything manufacture except clothing is under 1000 Euros its a 4.2% tax.
You will need to have a common law declaration (SAD, single administrative document), as well as the accompanying documents to allow their clearance. The SAD form can be obtained from Chambers of Commerce or an approved printer. You may need to send this to the vendor (in Canada for the link I sent) in advance.
You can also find dealers in Europe here:
https://www.goldenmotor.com/contact/dealer.html
As far as the Turnigy motor, after you add a 20:1 gearbox, a mounting bracket, a drive system, a BLDC controller, and a throttle you'll have spent a whole lot more. Not to mention the time and controller programming.
vagosofron
Post by vagosofron » Dec 18, 2017 2:10 am
I didn't see that it was a UK dealer, my bad. Even so, that will cost me way more than I want to spend.
What is a 20:1 gearbox? I haven't seen anything like that on other peoples projects. Also, I didn't know that the controller needed programming, I thought it was plug and play situation. I will build the mounting bracket. So you think that the specific motor is not for a project like this? Sorry for all the questions, but as I mentioned, i'm a noob.
ScooterMan101
Post by ScooterMan101 » Dec 18, 2017 4:05 pm
First of all since you say you are a noob, you are better off getting a complete kit, that is what we call " Plug and Play " .
That means get the Motor/Controller/Display/Throttle/PAS if wanting one/ etc from the same seller/vendor , and that all the above items plug into each other with the right plugs/connectors.
You were writing about you would like a friction drive for simplicity , however all the friction drives with the exception of one that is sold in Germany have many parts you have to put together from different sources.
The one from Germany is expensive , around $ 1,000 US or near that, don't know what that is in Euro's , but I do know you can achieve your goals for half that price.
For inexpensive plug and play systems that would work for you look into ...
1) the newest ( 48v/52v )(18 amp controller ) version of the TSDZ 02 the newest , and higher voltage versions are sold by recycles, if you look into the TSDZ thread you can find his information and allot of information on it. ( 48 volt pack is 13s , and 52 volt pack is 14s )
You can find allot of information on here , only need to read about the last 10 pages or so since there has been allot of versions, and improvements on the TSDZ 2
https://endless-sphere.com/forums/viewt ... start=1300
or
2) a Q128 complete system ( 201 rpm version motor) sold by BMS Battery.com
There are plenty of other options for hub motors , and even the Befang BBS02,
so you could look into those if you want.
That Turnigy SK3 motor is too fast , the KV is way too high for a easy project .
Best to just forget about that.
If you do want to still have a friction drive, Kepler is the person who has the most experience and does the best friction drive available at this time. Read his complete threads on his friction drives , especially his latest friction drive.
Kepler has said he will be back after the new year .
vagosofron
Post by vagosofron » Dec 18, 2017 4:49 pm
Thank you, you are correct! After a lot of reading, i saw that the motor i found, was wrong. You maybe wright about everything you wrote, but i still want a friction drive system. I will follow your advice and try to find everything from the same seller/store, but i don't know even then if everything "connects". There are so many motors and so many controllers! How do i know if they are compatible? What do i look? I will try to buy the same brand f.e. Turnigy, but what else? Do i have to check for the same amps/cell count?
ScooterMan101
Post by ScooterMan101 » Dec 18, 2017 5:45 pm
If you want a Friction Drive then Kepler is the person to contact, read everything on his thread, I think there is also a thread on his Friction Drive on the For Sale New section.
From a post a month or so ago, he said he will be back after the first of the year so you have time to do plenty of research. ( he does not , do this as a business only as a hobby so has to tend to his job that pays the bills , and perhaps is off on another business trip right now ? )
Kepler has done more research and experimentation with friction drives than any other person .
https://endless-sphere.com/forums/viewt ... 28&t=84905
https://endless-sphere.com/forums/viewt ... 31&t=86961
vagosofron
Post by vagosofron » Dec 19, 2017 12:21 pm
Thank you, yes i saw Keplers work and i like it. Maybe i will contact him.
vagosofron
Post by vagosofron » Dec 26, 2017 9:32 am
Can someone explain the basics on ESCs /motors/ batteries compatibilities? For example, if you have a brushless motor, what do you have to check in order to find the proper esc? The volts? The amps? The batteries? If the motor says 80amps, do you have to find an esc 80a, or a bigger/ smaller one can do the job? Can find those type of information in this forum?
vagosofron
Post by vagosofron » Dec 31, 2017 9:43 am
Ok, i ordered this motor from hobbyking
KEDA 63-64 190KV Brushless Outrunner 10S 2000W
Can someone suggest a compatible ESC? Since this motor supports up to 10s batteries, can i get a 36v speed controller like this one?
https://www.aliexpress.com/item/Free-sh ... eLevelAB=5
Please?
vagosofron
Post by vagosofron » Jan 13, 2018 3:53 pm
Update, I will build a Tom Stanton ebike and i'm looking for an esc. Has anyone ever tried enerton focbox?
