My BBS02 have 100% throttle on all PAS levels from 0 to 9. Is there a way to limit the speed or current for throttle on different levels of PAS, so i go like 30-40-50% of max speed, when the thumb throttle is all the way down? I want to have something like cruise control.
Update. I found that if i set By Display Command in the Throttle handle, it uses the setting from the pedal assist tab. But in that way i cant use much throttle on lower levels of PAS. Any wya to make only 3 modes use 25-50-75% throttle?
