electric Velokraft
sk8norcal
San Jose, CA
http://www.recumbentblog.com/2009/11/26/electric-assisted-velokraft/
Apparently Kamil of Velokraft in Poland in focusing more on the e-bikes rather than the high zoot carbon recumbents.
According to this thread: http://www.bentrideronline.com/messageboard/showthread.php?t=79493&page=3 This is Kamil's personal e-bike transportation. Very cool!
Yes, it has pedals!
-Warren.
Pedal input at high speeds .... look at that pedal sprocket.
-Warren.
video here,
http://endless-sphere.com/forums/viewtopic.php?f=7&t=35306
These type of recumbents peek my interest, I just wonder if ride comfort suffers when you go to such a small front wheel.
I have a 16" front with suspension and it rides fine
see avitar
Interesting motor.
TYPE BLM-15Z
Nominal / peak 4/12kW
Nominal Voltage 50V
Continuous current 100A
Peak current 300A
SIZES
A-140mm
B-118mm
D-10mm (Hard to read, but there's a D for the shaft diameter.)
WEIGHT 2550 g
But apparently that's not the one in use, it's this one.
TYPE BLM-N30Z
Nominal / peak 10/30kW
Nominal Voltage 100V
Peak current 300A
Speed ​​without load ok.8000
SIZES
A-230mm
B-139mm
C-130mm
D-25mm
E-54mm
A small gear - 22 teeth
High gear - 110 teeth
