Ebike
Jp88   10 mW
Ebike
Post by Jp88 » Dec 22 2019 2:16am
Hi i got a ebike and put a bigger and better wheel on buy it going backwards and ideas would be great it a dayun ebike
Jp88   10 mW
Re: Ebike
Post by Jp88 » Dec 22 2019 2:31am
Any help would be appreciated
dogman dan   100 GW
Re: Ebike
Post by dogman dan » Dec 22 2019 6:38am
The wires on the new motor are not colored the same as the old one. Try swapping around the big fat wires to find a combination that makes it run good forward. There will be one good forward, and one good reverse combination, the other 7 will run shitty, or not run at all.
There are threads that explain this in more detail.
TommyCat   1 kW
Re: Ebike
Post by TommyCat » Dec 22 2019 10:06am
If this is a BLDC motor with hall sensors, perhaps this would be easier to use. If it runs well, but just in reverse. Just the changes in the lower right blue box would be necessary.
Regards,
T.C.
See my completed Magic Pie V5 rear hub E-Bike build Here!
MadRhino   100 GW
Re: Ebike
Post by MadRhino » Dec 22 2019 11:43am
Well, if it is running fine backwards, half the job of finding the proper combo is done. Swap any two (only two) of the big phase wires, then swap one of the 3 other possible combinations of the (blue, green, yellow) hall wires. One of them will give you a perfect forward motion.
Current bikes
Street: https://s20.postimg.org/ewrvugywt/Session_04_2015.jpg
Dirt: https://s20.postimg.org/lbqwr55ml/IMG_0157.jpg
Jp88   10 mW
Re: Ebike
Post by Jp88 » Dec 22 2019 12:26pm
It going backwards when you twist the throttle
E-HP   100 kW
Re: Ebike
Post by E-HP » Dec 22 2019 1:56pm
Jp88 wrote:
Dec 22 2019 12:26pm
Ahh, with that clarification, I think the best advice would be to read the 3 posts above.
spinningmagnets   100 GW
Re: Ebike
Post by spinningmagnets » Dec 22 2019 3:37pm
There is a possibility that this scooter has a reverse switch, and it is not wired properly. Meaning, the reverse switch is now always "on"...
Jp88   10 mW
Re: Ebike
Post by Jp88 » Dec 22 2019 4:38pm
So what would be the best thing to do
Re: Ebike
Post by spinningmagnets » Dec 22 2019 4:48pm
Find the model number of the controller, and post it here.
docw009   100 kW
Re: Ebike
Post by docw009 » Dec 22 2019 5:15pm
It;s right there in the flow chart.
You have three heavier wires - Yellow, Blue, Green
You have three thinner wires - Yellow, Blue, Green plus two more, Red and Black?
1) Swap the thick Yellow and Green wires.
2) Swap the thin Yellow and Blue wires.
If the chart is correct, Zoom ZOom.
Jp88   10 mW
Re: Ebike
Post by Jp88 » Dec 22 2019 5:23pm
That is my controller box
E-HP   100 kW
Re: Ebike
Post by E-HP » Dec 22 2019 6:50pm
Jp88 wrote:
Dec 22 2019 4:38pm
Since it's not going to fix itself, print out this thread and bring it and the bike to a shop that can swap the wires for you, per the advice provided.
amberwolf   100 GW
Re: Ebike
Post by amberwolf » Dec 23 2019 12:51am
Jp88 wrote:
Dec 22 2019 4:38pm
Follow the advice already given.
Or try giving the complete information others already asked for, that you haven't bothered to do yet.
Jp88   10 mW
Re: Ebike
Post by Jp88 » Jan 14 2020 3:37pm
Hi could any one help me my bike had a new back wheel everything working fine then yesterday had a adicent and still everything working fine then last night but the batteries one charge and just gone down today and but the batteries back in and it all comes out but still saying the batteries flat when it isn't and not moving at all any help would be great full
markz   100 GW
Re: Ebike
Post by markz » Jan 14 2020 4:35pm
get a digital multi meter and measure the voltage
E-HP   100 kW
Re: Ebike
Post by E-HP » Jan 14 2020 4:43pm
Jp88 wrote:
Jan 14 2020 3:37pm
Ah so does this mean that you solved the earlier problem? Thanks for following up. What finally worked?
Jp88   10 mW
Re: Ebike
Post by Jp88 » Jan 14 2020 5:49pm
Yh we got the back wheel working been all gd up till today when I charge my batter when downstairs put the batteries in and not it saying battery flat when it not and it not working
E-HP   100 kW
Re: Ebike
Post by E-HP » Jan 14 2020 6:37pm
Jp88 wrote:
Jan 14 2020 5:49pm
Yup, the beauty of the forum is that a person can ask a question and receive lots of support and great advice. And the same user can then contribute to the forum by coming back afterwards and letting people know exactly what they ended up doing to fix the problem, so the next guy that reads the thread benefits. So what worked?
mark5   100 kW
Re: Ebike
Post by mark5 » Jan 14 2020 6:50pm
A long time ago before web browsers existed people used to get help from others through mailing lists. It was expected that they'd post a recap after they got their problem solved. Otherwise they were less likely to get helped the next time.
Jp88, what was the problem before and how did you fix it?
Jp88   10 mW
Re: Ebike
Post by Jp88 » Jan 14 2020 7:19pm
The problem was the back wheel was not working before it Coz it was not clouer code.
