This first post is under construction as an index. Each motor will have a concise paragraph with common name, basic details, and links to threads with more detailed information for each. Discussion and suggestions may continue to be added to the end of the thread.
Unless otherwise stated, all listed geared hub motors below are brushless, have a disc brake flange on the left, they use an approximately 5:1 geared reduction, they have a threaded freewheel flange on the right, and the wires exit a hollow axle on the left.
_____________________
These top two have a 22mm wide stator (135mm diameter), and are widely regarded as the most powerful available.
MAC
BMC
The eZee and BPM have a 17mm wide stator (130mm diameter), and are popular as a mid-powered choice.
eZee
Bafang BPM2
Bafang BPM
Bafang CST
I will try to organize the order of the motors below according to approximate size, the listed order may change over time as details are identified. The names below are generally from the smaller end of the physical size scale. Many parts of Europe and Asia have low power limits (250W is often cited) so, there is a lot of selection and innovation in this size class.
XOFO
Xiongda 2-speed
Q128H
ebikekit
Conhis
MXUS
Fusin
Bafang SWXH
Bafang SWXK
Cute Q100H
Outrider
Heinzmann
Tongxin
Ananda
MBG
Q85H
Bafang SWXU
Q75
Keyde
________________________________________________________
MAC
spoke pitch circle diameter is 172mm.
http://endless-sphere.com/forums/viewtopic.php?f=16&t=51310
The most often cited vendor is Paul @ http://em3ev.com/store/
laminations are 0.35mm thick (As of summer of 2014)
stator is 22mm thick, 135mm diameter
Magnets: 32
Poles: 36
Kv is available as 6T, 7T, 8T, 10T, 12T
BMC
The most often cited vendor is Ilia @ http://www.ebikessf.com
Magnets: 32
Poles: 36
Kv is available as 8T, 10T (called speed and torque)
eZee
The most often cited vendor is Justin @ http://www.ebikes.ca/
stator is 17mm thick, 130mm diameter
BPM2
The disc-brake-side spokes have a PCD of 171mm, and the sprocket side are 168mm
This unit has a sideplate that must be unscrewed for access to the internals, which requires a special tool.
http://endless-sphere.com/forums/viewtopic.php?f=2&t=62777
Bafang BPM
spoke pitch circle diameter is 168mm
http://endless-sphere.com/forums/viewtopic.php?f=16&t=51237
laminations are 0.50mm thick
Stator is 17mm thick, 130mm diameter
magnets:16
poles: 18
Kv available in 9 versions, 8T to 16T
Bafang CST
spoke pitch circle diameter 164mm
Reported to be identical to the BPM, but fitted with a cassette freehub
http://endless-sphere.com/forums/viewtopic.php?f=3&t=4892&start=150#p810105
http://ecopedelec.com/pic/other/2012-07-06-01-18-336.jpg
XOFO (cassette freehub)
spoke pitch circle diameter:______
http://www.endless-sphere.com/forums/viewtopic.php?f=3&t=46608#p705884
This motor has an integrated torque-sensor inside the motor-shell.
Laminations are 0.50mm thick.
Stator is 20mm wide, and 104mm in diameter
magnets: 20
poles: 18
Xiongda 2-speed
spoke pitch circle diameter: 121mm
http://endless-sphere.com/forums/viewtopic.php?f=3&t=58490
This motor has two internal gear-sets, and by reversing the internal motor on the fly, the motor is provided with two gears that it uses to propel the wheel. Using 46V in a 26-inch tire provides 22-kph in low, and 36-kph in high gear (14-MPH and 22-MPH)
The stator width and diameter is 17mm X 96mm
Q128H
spoke pitch circle diameter is 128mm
Available in two Kv's
No disc brake flange
http://www.bmsbattery.com/rear-driving/641-250w350w-q-85100sx-motor-e-bike-kit.html
Ykick has one at 16S voltage http://endless-sphere.com/forums/viewtopic.php?f=2&t=55477&start=50#p891603
https://endless-sphere.com/forums/viewtopic.php?f=3&t=74945&p=1131640#p1131567
ebikekit
ES senior member dogman is a customer service rep for http://www.ebikekit.com/
Conhis
spoke pitch circle diameter:_______
http://www.conhismotor.com/ProductShow.asp?id=439
http://endless-sphere.com/forums/viewtopic.php?f=3&t=4892&start=150#p939995
cassette freehub
Stator diameter: 114mm
Stator width: 21mm
Lamination thickness: 0.50mm
magnets: 20
poles: 18
MXUS
As of 2014, the new small MXUS geared hub has a cassette freehub, and the geared reduction uses helical gears (which should run very quietly)
Fusin
Bafang SWXH
spoke pitch circle diameter: 120mm
http://www.greenbikekit.com/catalog/product/gallery/id/128/image/256/
This unit has a sideplate that must be unscrewed to access the internals, which is difficult and requires a special tool.
http://endless-sphere.com/forums/viewtopic.php?f=6&t=47139&p=732717#p732717
http://endless-sphere.com/forums/viewtopic.php?f=2&t=9969&start=25#p154389
The small hub from Ampedbikes appears to be identical to the SWXH
http://endless-sphere.com/forums/viewtopic.php?f=3&t=62056&p=926839#p926939
Bafang SWXK (SWXK5 is better for a disc brake)
spoke pitch circle diameter is 121mm
4.7-Kv (170-RPM @ 36V)
http://daniel.weck.free.fr/BromptonBafangTongxin/IMG_3818.jpg
http://endless-sphere.com/forums/download/file.php?id=55353
This 350W front-only hub locates its wire exit in the side plate on the right, as opposed to the common route through a hollow axle.
http://www.pedelecs.co.uk/forum/threads/diy-stage-1-received-bafang-tongxin-kits-photos.4682/
poles: 18
diassembly video: https://www.youtube.com/watch?v=kpBXKPdPAfY&list=UUk49CL_1nnuKdg86L5_-4Fg&index=32
Cute Q100H
spoke pitch circle diameter: 108mm
sideplate unscrews
http://www.endless-sphere.com/forums/viewtopic.php?f=2&t=50840
http://endless-sphere.com/forums/viewtopic.php?f=3&t=13998
Pics comparing freewheel version with new 2015 cassette
http://endless-sphere.com/forums/viewtopic.php?f=2&t=70369
Good pictures and information on the internals:
https://endless-sphere.com/forums/viewtopic.php?f=2&t=86991&p=1271611#p1271611
Outrider
http://www.ebikes.ca/moutrider-fst.html
Heinzmann
http://endless-sphere.com/forums/viewtopic.php?f=2&t=4190
http://www.ebike.heinzmann.com/en/
brushed, no disc brake flange, two stages of geared reduction with the high-RPM half using helical gears. The two tiny wires exiting the motor are a temp sensor that trips at 145F / 63C, rare axial flux configuration.
Tongxin
The Tongxin uses smooth rollers for the reduction instead of gears, which provides an unusually high amount of reduction. This means it runs very quietly, but it also means it cannot take many amps or it will start slipping.
http://static.electricbike.com/wp-content/uploads/2014/03/tenKits4.png
https://endless-sphere.com/forums/viewtopic.php?f=2&t=25188
https://www.youtube.com/watch?v=ymQyvh0L6iE
Ananda
Identical to the Keyde/Tongxin
MBG
http://endless-sphere.com/forums/viewtopic.php?f=3&t=4892&start=125#p652141
Cute Q85H
http://endless-sphere.com/forums/viewtopic.php?f=3&t=14109&start=75#p361123
Bafang SWXU
The wires exit the sideplate instead of the axle.
Q75
Stator width and diameter:_______
Keyde
https://www.youtube.com/watch?v=xelWE1FWa54
Please PM corrections and additional details to spinningmagnets @ http://endless-sphere.com/forums/memberlist.php?mode=viewprofile&u=5883
Here is a pic of a DIY tool for removing certain common types of sideplates, which screw onto the center section:
MAC
BMC
eZee
Bafang BPM2
Bafang BPM
Bafang CST
XOFO
Xiongda 2-speed
Q128H
ebikekit
Conhis
MXUS
Fusin
Bafang SWXH
Bafang SWXK
Cute Q100H
Outrider
Heinzmann
Tongxin
Ananda
MBG
Q85H
Bafang SWXU
Q75
Keyde
MAC
Magnets: 32
Poles: 36
BMC
Magnets: 32
Poles: 36
eZee
BPM2
Bafang BPM
magnets:16
poles: 18
Bafang CST
magnets: 20
poles: 18
Xiongda 2-speed
Q128H
ebikekit
Conhis
cassette freehub
Stator width: 21mm
magnets: 20
poles: 18
MXUS
Fusin
Bafang SWXH
poles: 18
Cute Q100H
sideplate unscrews
Outrider
Heinzmann
Tongxin
Ananda
MBG
Cute Q85H
Bafang SWXU
Q75
Keyde
