Hummina Shadeeba
I want to put a rear hub motor in 120mm wide horizontal track dropouts. I also want to pedal a single gear with a freewheel. that's available right?
Hummina Shadeeba said:If u have any advice on bending the 120mm frame to fit the 135 hub or if I’m better grinding the axle I’d like to hear
SlowCo said:Widening the dropout:
https://www.sheldonbrown.com/frame-spacing.html
And use (hose)clamps for attaching the battery holder to the frame.
https://clamptitetools.com/collections/kitsHummina Shadeeba said:I’d rather make it look slick though. Can’t run a new shiny bike with those things. If u have another idea.
john61ct said:https://clamptitetools.com/collections/kits
Hummina Shadeeba said:As it is now will get some water bottle bosses (think they’re called) welded on for the battery.
The real big one will take 1/4-inch-diameter wire, as in clothes hanger gauge, and secure a wind genset mounted on a steel pipe to the top of a telephone pole on a cliff or hilltop, ready to withstand named storms.SlowCo said:john61ct said:https://clamptitetools.com/collections/kits
That's a great tool, thanks for the link!
Hummina Shadeeba said:after finding the sram apex brakes don’t reach the wheel brake track
Hummina Shadeeba said:Yea I know there’s longer reach brakes but one of many things. Schwinn 20” size rims being smaller I wonder if a problem for the hub and I’d rather get the slightly bigger rims instead.
Do I really need a torque arm if my dropouts are horizontal? Maybe could even shim it to be tight.
Hummina Shadeeba said:ive been looking to make 451 wheels and I wonder why you say they always do the smaller 406 with motors?
I assume doing the 451 rim with the hub will be fine.
any lacing pattern best for the motor? its 36h.
any recommended rivets for mounting the luna wolf battery on the downtube? would do 3 or 4 something steel. good idea or bad?
How thick are your dropouts? If it's a steel frame, the tabbed washers probably won't provide much. You could get away without them is my guess.Hummina Shadeeba said:Any other tabbed washers u could recommend that have longer tabs? The tabbed washers seem like they could be up to the job if longer and with more leverage.
Hummina Shadeeba said:The tabbed washer is 3mm thick. I’d like to get two made 5mm thick. and instead of 5mm long tab do 15. I could cut a sheet and bend it but rather buy it. Why wouldn’t that work?
